Tweaks!!!
Tweaks
  • Total voters
    99
http://www.gryphon-audio.dk/images/products/exorcist/main.jpg
The entire signal path from preamplifier input to speaker drivers contains conductive parts that can be magnetized. Connectors, component pins and even circuit board copper traces may contain nickel or steel. In addition to being poor conductors, these materials may be magnetized by DC current.
Most electronic devices have constant DC leakage, ranging from negligible to considerable, depending on the design. Many preamps and power amps generate a DC pulse when switched on, before stabilizing. This is particularly true of tube equipment. It has also been suggested that even the copper in cables contains oxides that may be magnetized.
The application of DC current is precisely the technique employed in the manufacture of magnets. High end connector manufacturers and others are very much aware of this and subjective listening tests have often pinpointed the degrading sonic effects of nickel. We would estimate that 95% of all gold-plated connectors have a nickel base beneath the gold plating.
When an audio signal passes through a magnetic field, it is prone to magnetically induced distortion (MID) that manifests itself as a ?whiteness?, a lack of inter-transient silence and reduced soundstage depth.
The Solution
Those of you old enough to remember the venerable phono cartridge will also recall the indisputable benefits of frequent use of a cartridge demagnetizer. The Gryphon Exorcist applies the same principle to the entire audio system at line-level. (Do NOT use it on your cartridge or preamplifier MC/MM phono input. For cartridge demagnetization, contact your authorized Gryphon dealer to audition the Gryphon Black Exorcist.)
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Tweaks!!!
Λοιπόν μετά από πολύ καιρό με νέα από το μέτωπο!!!
Τα καθαριστικά επαφών όλοι τα ξέρατε. Τι θα λέγατε αν προσπαθούσαν να σας πουλήσουν ένα μικροσκοπικό κουτάκι με καθαριστικό επαφών αξίας 180€;;;
Και δείτε πως το περιγράφει ο κατασκευαστής του:
This is specially treated with a compound known only to Walker Audio, before being subjected to a 3 day 'slow liquid cryogenically treatment' futher enhancing it's conductive properties. Improves every aspect of your HiFi systems performance.
Αναλυτικός και περιεκτικός...
Όσοι πάντως δεν πτοούνται και θέλουν να δοκιμάσουν δείτε εδώ:
http://www.audiophilecandy.com/prodet.asp?pcode=CL-WAL-ESST&rel2=&0=More+Info
ΥΓ υπάρχει και η "απλή" έκδοση του καθαριστικού στα μισά περίπου λεφτά. Μην ρωτάτε τώρα τι διαφορές έχουν μιας που και αυτή υπόσχεται ότι κάνει τα ίδια με την "ενισχυμένη"...
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Tweaks!!!
Υπάρχουν και χειρότερα!!!
Loricraft L'Art Du Son CD/DVD cleaner
ένα θαυματουργό μπουκαλάκι, που με το υγρό που περιέχει θα πρέπει να περάσετε όλα τα cd/dvd σας (οπότε θες 5-6 μπουκαλάκια μέσα στο νερό).
Τα "καθαρίζει" και τους δίνει περισσότερη λεπτομέρεια και φυσικότητα στον ήχο, καθώς και πιο πλούσια και πιο φυσικά χρώματα, αλλά και καλύτερο μαύρο στα dvd...
Και η τιμή, μόνο 60€ το μπουκαλάκι...
http://www.audiophilecandy.com/prodet.asp?pcode=CL-LOR-SON-CD&rel2=&0=More+Info
ΥΓ αυτό με το καλύτερο μαύρο πως το μέτρησαν θα μου πει κανένας;
Re: Απάντηση: Tweaks!!!
Εκτός του ότι είναι γραμματικώς λάθος, είναι και επιστημονικώς. Δηλαδή με το "επιστημονικώς" τους απέδωσα κάποια αξία ας πούμε. Μιλάμε για τσαρλατάνους. Κρυογεννάται το υγρό; Και τι παθαίνει; Παγώνει; :p
I am speechless...
Είναι και ορθογραφικώς λανθασμένο: "it's"=it is.
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Tweaks!!!
Stop the press!!!
Το βρήκαμε, το βρήκαμε!!!
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]MachinaDynamica [/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Intelligent Chip!!!
Τι είναι αυτό θα μου πείτε και με το δίκιο σας...
Είναι αυτό το κουτάκι.
και τι κάνει θα μου πείτε;
Λοιπόν βάζεις μέσα την Intelligent card την ενεργοποιείς (ούτε ΑΤΜ να ήτανε), βάζεις μέσα ένα συμπακτό δίσκο (compact disc για τους αγράμματους) και πατάς το κουμπί στα δεξιά.
Και μετά γίνεται το θαύμα!!!
Τα φωτόνια ,λέει ο κατασκευαστής, που παράγει το Laser (ποιο laser ρε παιδιά εγώ ένα led βλέπω όλο κι όλο) χτυπάνε πάνω στις βούλες που έχει η κάρτα, αυτές διεγείρονται και με την σειρά τους εκπέμπουν μια καραβιά φωτόνια (
[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]a load of photons). Αυτά με κάποιο τρόπο που δεν μας εξηγεί κανείς χτυπάνε στον συμπακτό δίσκο και μετά ανακλώνται πάνω στο μαύρο ακρυλικό στο εσωτερικό της συσκευής. [/FONT]
Τα φωτόνια τώρα που χτύπησαν πάνω στον συμπακτό δίσκο αλλάζουν την δομή του
[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]polycarbonate πλαστικού του δίσκου και ο θόρυβος του υποβάθρου χαμηλώνει όταν αναπαράγεται από εδώ και πέρα o συμπακτός δίσκος...
Διαβάστε πως το περιγράφει "επιστημονικά" ο κατασκευαστής...
[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]The metals ID'd by the electron microscope suggest the tiny metal discs inside the Intelligent Chip might be quantum dot arrays for the following reasons: (1) the manufacturer indicates the IC contains "quantum material;" (2) all of the metals ID'd at the lab except for Niobium are used in fabricating the metal layer of compact discs due to their very high index of reflectivity for infrared light. Highly reflective metals are used as cladding for Q-dot arrays to promote greater photon emission by trapping the photons longer, allowing the photon chain reaction to continue longer. Photons are emitted from the edge of the array. (3) The Q-dot array would allow production of programmable Intelligent Chips - i.e., specific photon wavelength.
So, what exactly are quantum dots and how in tarnation could they possibly improve the sound of a compact disc? Quantum dots are "nanometer-scale" metal crystals originally developed in the '80s for optoelectronic applications. The core of a quantum dot comprises only several hundred to several thousand atoms of a semiconductor material such as Cadmium Selenide (CdSe) or Indium Arsenide (InAs) in which "electron-hole pairs" can be created and confined. The Q-dot container (shell) is a different semiconductor material - say, Zinc Sulfide (ZnS) or Aluminum Gallium Arsenide (AlGaAs). Q-dots and Q-dot arrays can be fabricated with many combinations of pure metals/metal alloys.
When the electron-hole pairs in the Q-dot core are excited by laser light, they radiate photons (fluoresce). Energy is transferred between absorbed laser photons and the electron-hole pairs. Thermodynamic equilibrium is restored (as electron-hole pairs return to their ground states) via the emission of coherent light in a brilliant photonic bomb - analogous to the radiation of neutrons in an atomic bomb. Each photon emitted by an electron-hole pair causes 2 more photons to be emitted, and so forth, in rapid succession - literally a chain reaction of photons. The ratio of the number of radiated photons to the number of absorbed photons is called the Quantum Yield. Highly reflective metals/alloys in the cladding improve confinement of the electron-hole pairs by momentarily delaying photon emission from the metal disc, boosting Quantum Yield.
[/FONT]
Ο π@π@ρας, ε, ο δοκιμαστής του 6μουνου που το δοκίμασε συμπέρανε
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Audible results are very good and it is hard to listen to a non- treated disc after listening to an enhanced version of that same disc on any CDP. Once used, always hooked so to speak. [/FONT]
Και η τιμή τζάμπα μόνο $400. Συγκρινόμενο με άλλο ανταγωνιστικό προϊόν βγαίνει εντελώς συμφέρουσα αγορά...
Μετά από όλα αυτά πάω να πάρω ένα laser που έχω πάρει καβάτζα από το πανεπιστήμιο και να αρχίσω να βομβαρδίζω τα CD μου για να τα αναβαθμίσω...
Και να μην ξεχάσω, όποιος θέλει να γελάσει όλη η δοκιμή εδώ
http://www.6moons.com/audioreviews/machinadynamica2/ib.html
Κώστας Φ.
Απάντηση: Tweaks!!!
Τσκ, τσκ... Κάτι τέτοια κελεπούρια τα έφερε πρώτο στην Ελλάδα το "K.K. Fan Club"... Κλικ!
Πώς ακούς μουσική τόσο καιρό βρε Σπύρο?! :mrgreen:
Θυμάμαι κάποτε ενας φίλος αγόρασε ενα κομμάτι αλουμινόχαρτο της musical fidelity ,εάν δεν κάνω λάθος, που θα του βελτίωνε τον ήχο τελικά τα μάσησε ο μηχανισμός και έτρεχε στην αντιπροσωπεία
Mr Spock
demokratischer - sektor
Bose AR: Γυαλιά ηχο-επαυξημένης πραγματικότητας
Η Bose ως γνωστό έχει βαθιά ερεύνα στο χώρο του ήχου, έτσι με τον ερχομό των τεχνολογιών εικονικής πραγματικότητας (VR) και επαυξημένης πραγματικότητας (AR) βρήκε μια πρώτης τάξης ευκαιρία να τις εφαρμόσει στον ήχο. Σχεδίασε ένα ζευγάρι γυαλιά για να ακούμε.
Προς το παρόν τα ονομάζει Bose AR και απευθύνονται στο χώρο του mobile ήχου. Μάλιστα θα υπάρχει και SDK κιτ για όσους θελήσουν να αναπτύξουν εφαρμογές για αυτά. Τα Bose AR δεν αλλάζουν τον τρόπο που βλέπουμε τον κόσμο, όπως άλλες διατάξεις επαυξημένης πραγματικότητας, εδώ αντί να παίζουν με την εικόνα τα γυαλιά προσθέτουν ηχητικά επίπεδα με πληροφορίες και εμπειρίες στην καθημερινότητα μας.
Bose AR έχουν ενσωματωμένα ακουστικά και μπορούν να ενσωματωθούν σε άλλα γυαλιά, κράνη ή αλλού, λειτουργούν με χειρονομίες του χρήστη αλλά και με φωνητικές εντολές. Βάζουν ήχο στο περιβάλλον που βρισκόμαστε, ηχητικές πληροφορίες για το μέρος που βρισκόμαστε, μουσική ή ακόμη και soundtracks.
Είναι συμβατά με Bluetooth συσκευές και μικρόφωνα για κλήσεις, όπως και με το Siri ή Google Assistant. Ο ήχος εδώ είναι προσωπικός και εντελώς ιδιωτικός. Εμπεριέχουν αισθητήρες, GPS και πολλές εφαρμογές. Είναι κατάλληλα στο ταξίδι, εστιάζουν στην επιθυμητή πηγή ήχου και επαυξάνουν τους ήχους που θέλουμε όπως ένα κελάιδισμα ενός πουλιού ή το πέρασμα τη φωνή ενός φίλου μας… σε μια παρέα.
Οι εφαρμογές είναι απίστευτες και πάρα πολλές. Η ανάπτυξη των ηχο-γυαλιών έγινε με την συνεργασία του MIT και του NYU Future Reality Lab, ενώ ήδη η Bose άρχισε συνεργασίες με μεγάλες ιστοσελίδες πληροφοριών όπως είναι η TripAdvisor.
http://www.hxoseikona.gr/nea/6218-bose-ar.html
. . . There are no distracting and awkwardly opaque visuals floating above your eyes as there are in other augmented-reality concepts that have generally underwhelmed (think Google Glass). With Bose’s glasses, there’s just a small voice, almost like a personal assistant, in your ear. It’s easy see how this technology would be extremely useful in museums, on walking tours, for the visually impaired, or in any situation where you want to know more about the world around you as you move through it . . .
https://qz.com/1227480/sxsw-2018-bose-announces-ar-sunglasses-and-a-50-million-venture-fund/
Bose AR Glasses Hands-On at SXSW 2018
Π
Π.Α.Η.
Aς αναφέρω μερικά τέτοια "tweaks" που βγήκαν κατά καιρούς :
Ultra Clarifier "Dual Beam"
NOTHING TREATS DIGITAL MEDIA BETTER
Bedini has just developed the new DUAL BEAM Ultra Clarifier which significantly improves the playback quality of all digital media recorded on compact disc. Through continued research Bedini's new DUAL BEAM technology can take your system to a new level of performance. With the arrival of the DVD and the need for a superior beam penetration, the Ultra Clarifier's DUAL BEAM configuration further enhances the treatment process of the compact disc. Nothing can prepare you for the absolute impact on your senses when your discs have been treated with the new DUAL BEAM Ultra Clarifier.
The home theater enthusiast and audiophile alike can now truly experience the reality of the recorded media on the DVD, Compact Disc, Multimedia CD-ROMs and Photo CDs. With the use of the new DUAL BEAM Ultra Clarifier all pictures will be brighter and sharper, audio is crisper and cleaner. With its patented Electro Magnetic Beam Configuration, the Clarifier polarizes the polymer in such a way as to maximize the laser's ability to retrieve stored data. By using the DUAL BEAM Ultra Clarifier to treat your CDs before playing, you will discover a distinct improvement in video and audio quality.
Independent reviewers have praised the qualities of the Ultra Clarifier and anyone who has an investment in their audio/video system should not be without this superior technical solution. This is the only electromagnetic product designed specifically to treat and enhance all forms of CD media. Experience sound and picture so real you'll think that you've upgraded all your components. You owe it to yourself to take a test spin on the new DUAL BEAM Ultra Clarifier. We guarantee the results will be the most impressive forty seconds in your audio/video experience.
http://www.stereophile.com/asweseeit/822/index1.html
http://www.tubedepot.com/cryovalvestory.html
Aυτά προς το παρόν.....
Τα συμπεράσματα δικά σας.
Την τελευταία τριετία που το χρησιμοποιώ,το συμπέρασμα μου είναι ότι δε διανοουμαι να παίξω cd αν δεν περάσει πρώτα απ' αυτό.Ηδη ένας φίλος και δύο γνωστοί έχουν συμφωνήσει σ' αυτό ακούγοντας τα δικά τους δισκάκια,ο φίλος στο σύστημά του.
symos
You're not worthy!
Η γειτόνισσα τι λέει;
(περίμενα τόσες ώρες, δεν το είπε κανείς, το λέω εγώ :laugh:)
roberto_portale
