AKTYNA SCM Cortex Master Reference
Ultra Audio
Διατίθεται το κορυφαίο RCA interconnect Aktyna SCM Cortex Master Reference
1meter.
Καινούργιο και αχρησιμοποίητο - Brand New
Τιμή Λιανικής 1.299 ευρώ --> Προσφορά μόνον 899 ευρώ!
Άνευ συσκευασίας.
Δωρεάν αποστολή παντού και έως 12 άτοκες δόσεις με πιστωτική κάρτα.
Όχι ανταλλαγές, δοκιμές.
Πληροφορίες: Τηλ. 2103839399.
Specifications Aktyna SCM Cortex Master Reference RCA Interlink
The conductors are made from extruded tellurium copper which is doped in 0.5% of gold during the process. This gold inclusion is done to reduce the crystal oxidation and allow for more flexibility. Of course this precaution ensures a high conductivity, for a long lasting usage.
After extrusion the conductors undergo seven cryogenic treatments. Each cryogenic process progresses from the last one and can take up to 48 hours.
Then the conductors are enamelled with a proprietary varnish for EMI/RFI rejection before the next step: the mechanical organization and geometry of the conductors to generate the “magneto supra” conductive effect. Additional elements are added to control the resonance phenomena, memory and microphonic effects.
Each conductor is then insulated with silk and cotton.
Finally all the elements are jacketed to the last cotton sheath.
Some of the conductors are shielded with tin foil, according to their application.
Ultra Audio
Λήξη προσφοράς, παρακαλώ να κλειδώσει.
Ευχαριστούμε για την φιλοξενία.
Manosmathiou
