Ultra Audio
EverSolo Z8 DAC, open-box σαν καινούργιο.
EVERSOLO DAC-Z8
ESS Sabre flagship ES9038Pro 32 bits D\A chip converter.
The 3rd generation XMOS XU316 with higher performance and faster speed.
High precision, low jitter synchronous dual-clock oscillator processing.
I/V operational amplifier circuit OPA1612*8, 8-channel bypass compensation technology.
Up to DSD512 Native, PCM768KHz@32Bit decoding.
Optical, coaxial and USB support full decoding and MQA performance.
Qualcomm QCC5125 Bluetooth 5.0 module supports APTX HD/LDAC protocol.
Fully balanced audio architecture, differential amplifier circuitry and professional calibration.
High performance headphone amplifier output, 16-300 ohm headphone driver.
3-inch LCD display, with a variety of VU meter functions.
Low ripple power supply to ensure a cleaner power source.
Exclusive APP mobile phone controller for global control.
SPECIFICATIONS
Διατίθεται στα 679 ευρώ, επειδή ανοίχτηκε για στατική επίδειξη.
Και έως 12 ΑΤΟΚΕΣ δόσεις με κάρτα.
Πληροφορίες, τηλ. 2103839399
Δωρεάν αποστολή παντού.
Όχι ανταλλαγές.
EVERSOLO DAC-Z8
SPECIFICATIONS
- Aviation chassis made of aluminium alloy DACES 9038Pro
- Audio ProcessorXMOS XU316OPA ChipOPA1612*10
- Power supplyLow noise switching power supply
- Bluetooth audio inputQualcomm QCC5125 Bluetooth module, BT5.0
- Bluetooth protocol support SBC/AAC/aptX/aptX LL/aptX HD/LDAC
- USB-B DAC inputCompatible with Windows (7, 10), Mac, Android and IOS
- Up to DSD512 stereo, PCM 768KHz 32Bit and MQAUSB-C DAC InputCompatible with Windows (7, 10), Mac, Android and IOS
- Up to DSD512 stereo, PCM 768KHz 32Bit, MQAOptical Audio InputUp to PCM 192KHz 24Bit stereo, DSD64 Dop and
- MQACoaxial Audio InputUp to stereo PCM 192KHz 24Bit, DSD64 Dop and MQAAnalog Audio OutputPreamplifier output:
- XLR (balanced), RCA,
- Headphone amplifier output: 6.35mm single-endedUSB PortUSB2.0*1(only for firmware upgrade).
- Control MethodsRemote control, mobile APP control and button control
- Headphone amplification16-300Ω (Lowest amplification mode: 16-32Ω/Highest amplification mode: 32-300Ω)
- Audio characteristicsXLR Output level (Vrms): 4.1Vrms@0dBFS
- THD+N@A-wt: 0.000062%@1kHz(-124dB@1kHz)
- THD+N@No-wt:0.000069%@1kHz(-123dB@1kHz)
- Noise@No-wt: <1.2uVrms
- SNR @No-wt: 133dB@1kHz
- Frequency response: 20Hz-20kHz (±0.1dB)
- Crosstalk: -130dB@1kHz
- DNR @No-wt: 133dB@1kHz
- Audio characteristics RCA Output level (Vrms): 2.3Vrms@0dBFS
- THD+N@A-wt: 0.000086%@1kHz(-121dB@1kHz)
- THD+)@No-wt: 0.000097%@1kHz(-120dB@1kHz)
- Noise @No-wt: <1.5uVrms
- SNR @No-wt: 126dB@1kHz
Όχι ανταλλαγές.
