EverSolo Z8
Ultra Audio
EverSolo Z8 DAC, open-box σαν καινούργιο.
EVERSOLO DAC-Z8
ESS Sabre flagship ES9038Pro 32 bits D\A chip converter.
The 3rd generation XMOS XU316 with higher performance and faster speed.
High precision, low jitter synchronous dual-clock oscillator processing.
I/V operational amplifier circuit OPA1612*8, 8-channel bypass compensation technology.
Up to DSD512 Native, PCM768KHz@32Bit decoding.
Optical, coaxial and USB support full decoding and MQA performance.
Qualcomm QCC5125 Bluetooth 5.0 module supports APTX HD/LDAC protocol.
Fully balanced audio architecture, differential amplifier circuitry and professional calibration.
High performance headphone amplifier output, 16-300 ohm headphone driver.
3-inch LCD display, with a variety of VU meter functions.
Low ripple power supply to ensure a cleaner power source.
Exclusive APP mobile phone controller for global control.
SPECIFICATIONS
  • Aviation chassis made of aluminium alloy DACES 9038Pro
  • Audio ProcessorXMOS XU316OPA ChipOPA1612*10
  • Power supplyLow noise switching power supply
  • Bluetooth audio inputQualcomm QCC5125 Bluetooth module, BT5.0
  • Bluetooth protocol support SBC/AAC/aptX/aptX LL/aptX HD/LDAC
  • USB-B DAC inputCompatible with Windows (7, 10), Mac, Android and IOS
  • Up to DSD512 stereo, PCM 768KHz 32Bit and MQAUSB-C DAC InputCompatible with Windows (7, 10), Mac, Android and IOS
  • Up to DSD512 stereo, PCM 768KHz 32Bit, MQAOptical Audio InputUp to PCM 192KHz 24Bit stereo, DSD64 Dop and
  • MQACoaxial Audio InputUp to stereo PCM 192KHz 24Bit, DSD64 Dop and MQAAnalog Audio OutputPreamplifier output:
  • XLR (balanced), RCA,
  • Headphone amplifier output: 6.35mm single-endedUSB PortUSB2.0*1(only for firmware upgrade).
  • Control MethodsRemote control, mobile APP control and button control
  • Headphone amplification16-300Ω (Lowest amplification mode: 16-32Ω/Highest amplification mode: 32-300Ω)
  • Audio characteristicsXLR Output level (Vrms): 4.1Vrms@0dBFS
  • THD+N@A-wt: 0.000062%@1kHz(-124dB@1kHz)
  • THD+N@No-wt:0.000069%@1kHz(-123dB@1kHz)
  • Noise@No-wt: <1.2uVrms
  • SNR @No-wt: 133dB@1kHz
  • Frequency response: 20Hz-20kHz (±0.1dB)
  • Crosstalk: -130dB@1kHz
  • DNR @No-wt: 133dB@1kHz
  • Audio characteristics RCA Output level (Vrms): 2.3Vrms@0dBFS
  • THD+N@A-wt: 0.000086%@1kHz(-121dB@1kHz)
  • THD+)@No-wt: 0.000097%@1kHz(-120dB@1kHz)
  • Noise @No-wt: <1.5uVrms
  • SNR @No-wt: 126dB@1kHz
Διατίθεται στα 679 ευρώ, επειδή ανοίχτηκε για στατική επίδειξη.
Και έως 12 ΑΤΟΚΕΣ δόσεις με κάρτα.
Πληροφορίες, τηλ. 2103839399
Δωρεάν αποστολή παντού.
Όχι ανταλλαγές.
Ultra Audio
🔻🔻🔻 🛬 LAST Last price 500 euros!!!!! 🔻🔻🔻🔻🔻🔻
Αχρησιμοποίητο!
και έως 12 ΑΤΟΚΕΣ με κάρτα!!!
thanos117
