Marantz - Denon meets Dirac (?)
billpeppas
A/V Επαγγελματίας
Το επισυνάπτω ατόφιο....
Η καταγραφή εμπειρίας ενός user ART!!
Share a bit of my own ART experience with all ARTists~
DIRAC Live ART made EASY: Safe and SOUND!
With Dirac finally releasing ART to Denon and Marantz AVRs after an exclusive 19-month run with StormAudio, there’s little doubt this technology is about to spark a worldwide revolution in digital room correction. And the reasons are threefold:
1. ART is about solving, not just polishing. Instead of merely “beautifying” a degraded signal, ART actively tackles the real culprits—room modes and SBIR (Speaker Boundary Interference Response).
2. No more heavy acoustic treatment. ART frees listeners from installing bulky absorbers or panels, helping preserve the aesthetics of the listening space. The only “recommendation” is to keep soft furnishings like sofas or rugs in place for light absorption.
3. It unleashes the full frequency potential of your speakers. By neutralizing unwanted room effects, ART allows loudspeakers to perform across their entire designed spectrum.
How does ART achieve this?
Put simply: the system assigns specific support speakers to emit inaudible, inverse-phase energy alongside the direct audio signal. This “counter-energy” cancels out room modes and SBIR artifacts, effectively cleaning up the playback environment without physical treatments.
Getting Started with ART
Step Zero
: Analyze your room and speakers.
This is critical. Is your space large or small? Reflective (hard surfaces) or absorptive (plush and treated)? Then, confirm your speakers’ usable frequency range—ideally within ±2 dB—and, if possible, their SPL capabilities.
Step One: Level Matching.
Before running Dirac measurements, calibrate each channel with full-band pink noise so the main listening position (MLP) measures at least 75 dB (85 dB is better).
Step Two: Room Measurements.
Take at least 5 points (3 points can technically pass, though Dirac recommends 9).
Step Three: Check ART Points.
ART operates on a “points” system—each computation consumes DSP resources. The more powerful your processor, the more speakers ART can utilize. For example, my StormAudio MK2 allows for a generous 462 ART points.
Step Four: Assign Supporting Speakers.
• Keep the front LCR channels free of support duties—let them focus on reproduction.
• Homogeneous speakers support each other best.
• Subwoofers should support all groups.
• Given the high energy demands of low frequencies, subs should only be supported by other subs. (Strongly recommended: run at least two subs in the system.)
Step Five: Adjust Support Strength.
This controls how much output a support speaker contributes to cancel modes. The default is -18 dB. My advice:
• For mains in large rooms or with limited SPL (<95 dB), set around -6 dB.
• For smaller rooms with higher-SPL speakers (>95 dB), leave at -18 dB.
• Subwoofers should remain at -18 dB for consistency.
Step Six: Define Support Bands.
Match each support range to the speaker’s low-end response plus about 10 Hz. For example:
• Floorstanders: 50–150 Hz
• Bookshelf speakers: 80–150 Hz
• Small satellites: 100/120–150 Hz (or skip ART)
• Subwoofers:
• Supporting mains: 20 Hz (or subwoofer’s lower limit)–100 Hz
• Supporting themselves: 20 Hz (or subwoofer’s lower limit)–120 Hz
Final Thoughts
Configured this way, ART delivers safe, effective, and audibly transformative results. As you grow familiar with the system, finer tweaks can unlock even more performance—pushing your setup to its full potential. Consider this a solid foundation, with endless room (pun intended) for refinement.
Μιας και βλέπω πάνω κάτω το marketing material σε παπαγαλία mode... να κάνω μια πρόβλεψη ότι το βίντεο ΔΕΝ περιέχει μετρήσεις before-after με εξοπλισμό και ότι απλά δείχνει την διαδικασία ενός calibration με το Dirac app και πολύ μπλα μπλα και ενθουσιασμό; :D
Βασίλη δεν το είδα κάν αυτο το βίντεο!! Απλα το πόσταρα σαν πιο καινούργιο outhere in the field. Πιο καλο κ αναλυτικό είναι αυτό….
Το κείμενο που πόσταρα πιο πάνω είναι από άλλον μάστορα πιο σοβαρό..!!! Do you agree with him??
billpeppas
A/V Επαγγελματίας
Όχι σε όλα τα points, και σε αυτά που συμφωνώ είναι εν μέρει (θέλει και να πουλήσει ο άνθρωπος).
Step Zero
• Subwoofers:
Final Thoughts
Πιο πολύ σαν διαφήμιση φαίνεται παρά σαν εμπειρία απλού χρήστη.
Ο τυπος το τρέχει ήδη το ART στον Storm εδώ κ 18 μήνες έχοντας πειραματιστεί αρκετά κ καταλήξει σε αυτα π σας επισυναψα....δίνοντας προς τα τελευταία βήματα και ωραίες λεπτομέρειες....
Οποτε προσωπικά πιστευω πως το μηνυμα του εχει μέσα και καταθεση ψυχής πέρα από προωθητικά στοιχεία. ☺
Οι διαφωνούντες σε καποια σημεια , οπως ο αγαπητος Βασίλης , ας κάνουν "expand" τις σκεψεις τους για να ξερουμε τι ισχύει τελικά για το καλό του φορουμ κ των αναγνωστών του! 🙏🤓
billpeppas
A/V Επαγγελματίας
Δίχως μετρήσεις όλα είναι υποκειμενικά.
Εγώ θα αργήσω να κάνω δοκιμές. Σε χώρο πελάτη ίσως πιο γρήγορα από ότι στον χώρο δοκιμών μου.
Αλλά εξαρτάται από τον πελάτη και όχι από εμένα αν θα κάνουμε υλοποίηση.
Σοβαρά; Εσύ δεν το είδες, αλλά εμείς να φάμε την ώρα μας να το δούμε. Μήπως θες να σου κάνουμε και περίληψη; Αυτή η συμπεριφορά είναι κατακριτέα.
Καλησπέρα Πέτρο!! Προσπαθώ ακόμα να καταλάβω το θεμα π αντιμετώσισες !!🤓 😁
Ποστάρω ένα βίντεο π εχει σχεση με το ART , όπως γραφουνε κ όλοι εδώ σχετικά , σαν πιο καινούργιο π εχει γινει upload. Δεν ζήτησα ουτε περιλήψεις , ουτε ημουν κ υποχρεωμένος να το δώ όλο , ούτε φυσικά να μπειτε κ εσεις στον κοπο να το δείτε!! Τι φάση κ αυτη...!!!🥳
Dirac Bible Essential guide. Πλήρης αναλυτικος οδηγός 114 σελίδων. Ευγενική χορηγία ξένου μέλους.
"Check out my Dirac Live guide; I just updated it this past weekend due to all the new D&M users asking questions. There are six pages of condensed best practices staring on page 35, which should help everyone get to a really good starting point. "
DIRAC Live Guide 2025-10.docx - Έγγραφα Google
Τόσο δε διάβασα ούτε στις πανελλήνιες.....
Διατριβή κανονική φίλε!! 😁😁 Αμα το διαβασεις ολο κ το κατανοήσεις απ ακρη σ ακρη τότε επάξια μπορείς να να αναγραψεις στην σφραγίδα σου από κάτω Dirac Specialist Manager !!! Eπίσης θέλω περιλήψεις αν μπορείς...αλλιώς θα το αναλάβει ο Mr Dalipis που ψοφάει για τέτοια!!!! 😂😂
:drinks:
Ούτε εγώ.
Εριξα 'ομως πολύ περισσότερο στα πτυχία.
Μιλάμε για εφιάλτη .
Όχι για να δείτε πως εχει καταντήσει η διασκέδαση μασ με την τεχνολογία να καλπάζει...
Που ειναι οι εποχές..μπριζα , power on και φύγαμε....🙂
Είναι ιδέα μου ή ειναι 15% η εκτπωση οπως την δειχνουν στις τελικές τιμές?
Μπέρδεψα το bundle discount με το BF discount το οποίο μπαίνει χεράτα στο checkout.
20% στην ηδη μειωμένη τιμή του ART. (των 259 ευρώ κ ευτυχως όχιντην αρχική των 300€) .
Μέχρι Κυριακή 23:59!!! Ευτυχως πληρωνόμαστε στο ιδιο timing κ θα μας κατσει πιο καλά...🥳🥳
Ο Βασίλης το "βρήκε" με 25% και τα π.μ. θα πάρουν φωτία!!!😂😂 στα 193,5 ευρώπουλα!!! Τρεξτε να προλαβετε👌🥳😁
Εγώ είμαι κάτοχος minidsp flex 8 και το Dirac το βλέπω σταθερά στα 199 έχει κάποιος δει κάτι καλύτερο;
billpeppas
A/V Επαγγελματίας
Από deac απευθείας ότι σου το βγάζει με το 20% blush Friday, ή μέσω εμού με -25% αντί 20%.
Katerinanota
