Νέα Nvidia Shield (2019)
Kάποιες ψυχές εδώ στο Ελλάντα και ακόμα περισσότεροι χρήστες του εξωτερικού από ξένα φορουμς , facebook κτλ , δεν αγόρασαν Anthem AV90 λόγω έλλειψης AURO 3D.....πηγαίνοντας σε άλλες αξιόπιστες λύσεις!!
Εδώ είχαν φτιάξει και κάσα για το Auro-3D 😂
Δεν ασχολουμε πάλι γιατί θα εκνευριστω :biggrin:
Όταν ξεκίνησαν να φτιάχνουν το update το Auro ήταν καινοτομία. Άργησαν λίγο. :biggrin:
Κατέβασες το artist connection να πάρεις γεύση από πραγματικό 3D Audio? :biggrin:
Shield Experience Upgrade 9.2.1 (6/5/25)
Today we released SHIELD Experience Upgrade 9.2.1 (33.2.0.326) for all SHIELD and SHIELD Pro units. This update addresses many quality of life issues reported in the field, improving stability and compatibility with other devices in your home entertainment center. Thank you for being a part of the SHIELD community and as always, if you see any issues, please send feedback from your device and post your observations in this thread.
Upgraded Apps
  • Support to stream games on NVIDIA GeForce NOW at 120FPS up to 1080p resolution. GeForce NOW Ultimate membership required.
Resolved Bugs
  • Fixes night mode being skipped when DAP is ON.
  • Fixes Dolby Vision content stutters when frame match feature is enabled.
  • Fixes match content audio resolution while using an USB DAC.
  • Adds back HQS / Maxrate option for USB audio.
  • USB TV Tuner fix with Live Channel app.
  • Fixes playback issues in PLEX when using AAC 5.1 audio.
  • Fixes connection issues with third-party remotes after sleep or reboot.
hawkwind78
SHIELD Experience Upgrade 9.2.2
What's New in 9.2.2?
Enhancements
SHIELD TV is now more accessible to people with disabilities with design improvements and compatibility with assistive technologies:
A pairing alert sound to assist users when pairing the SHIELD Remote and Controller in both OOBE and Settings
Added Bounce Keys feature
Accessibility Key Repeat feature implementation
Added settings UI for accessibility timeout
Support TalkBack TTS in 23 European languages
Resolved Bugs
Audio dropout with Disney+
PPG
Πίπιτζι
Καλημέρα και χρόνια πολλά !!! Μια ερώτηση control για το Nvidia Shield από που μπορώ να προμηθευτώ? Εύχομαι καλές γιορτές !!!
Αν σου κολλάει και δεν είναι άλλο το πρόβλημα λύνεται σχετικά εύκολα, κατεβάζεις την εφαρμογή στο κινητό και όταν το ξεκινήσεις από το κινητό μετά ξεκολλάει και δουλεύει κανονικά. Εν τω μεταξύ ενώ μου το έκανε παλιά τακτικά σχετικά εδώ και σίγουρα ένα έτος δεν έχει κάνει κιχ. ίσως το έφτιαξαν με κάποιο update.
  • Like
Reactions: PPG
hamurabi
εχει καταφερει να βρει καποιος adapter για 2.5g ethernet για να δουλευει σε 2.5G δικτυο?
billpeppas
A/V Επαγγελματίας
Τα 2.5G, αν υποθετικά έπαιζε κάποιος adapter, δεν πιστεύω πως θα μπορούσε να τα κάνει saturate η CPU του
PPG
Πίπιτζι
Σε ευχαριστώ πολύ θα το κάνω και θα σου πω , ναι κολλάει συνέχεια και δεν ανταποκρίνεται.
Πωπω τι τράβηξα μέχρι να βρω άκρη και εγώ παλιά😀😀
  • Like
Reactions: PPG
PPG
Πίπιτζι
Φίλε μου καλημέρα λειτούργησε σε ευχαριστώ πολύ , ελπίζω να μην κολλήσει ξανά . Τώρα εάν θες να αγοράσεις το pro σε ποιο site να ψάξω ?
Δεν θυμάμαι καθόλου από που το είχα πάρει. Το έχω πολλά χρόνια.
  • Like
Reactions: PPG
Δυστυχώς τα links του amazon δεν εμφανίζονται .
Να δω μήπως και το καταφέρω με πμ.
  • Like
Reactions: PPG
Alkimos
