vlasis
Φωτογράφος!
Signature 1.1 Pre Amp
Battery operated true DC power supply
Specifications
Remote Volume:
Yes
Transformers:
100 VA and 300 VA
Filter Capacitance:
(2) 28,000 uF
Gain:
21 dB
Slew Rate:
100 volt uS
Input:
RCA type
Output Impedance:
50 ohm
Frequency Response:
5 Hz-300,000Hz =/- 0.1 dB
Distortion:
0.005%
Intermodulation Distortion:
0.007%
Approximate Weight:
69 pounds
NL Signature 1.1 Amp
Specifications
Chassis:
2
Transformers:
4
Number of Channels:
1 per chassis
Transformer Rating:
4 x 1500 va
Total Capacitance:
320,000 uF
Power Rating into 8 Ohms:
400 watts/channel
Output Impedance:
.013 ohm
Constant Current Capacity:
83.32 amps
Number of Lasers:
2
Input Type:
RCA
Approximate Weight:
115 pounds x 2
Dimensions:
19"d x 15"w x 9"h
NL Reference Amplifier
Specifications
Chassis:
2
Transformers:
4
Number of Channels:
Transformer Rating:
2000 va
Total Capacitance:
280,000 uF
800 watts/channel
Output Impedance:
.013 ohm
Input Impedance:
30,000 ohms
>100 amps
Input Type:
RCA, XLR
Approximate Weight:
220 pounds x 2
Dimensions:
18"d x 18"w x 33"h
http://www.edgeamp.com/products.html
ΠΑΡΑΚΑΛΩ ΟΤΑΝ ΔΕΙΤΕ ΤΙΣ ΤΙΜΕΣ ΜΗΝ ΤΡΟΜΑΞΕΤΕ.....................
Specifications
Remote Volume:
Yes
Transformers:
100 VA and 300 VA
Filter Capacitance:
(2) 28,000 uF
Gain:
21 dB
Slew Rate:
100 volt uS
Input:
RCA type
Output Impedance:
50 ohm
Frequency Response:
Distortion:
0.005%
0.007%
Approximate Weight:
69 pounds
Specifications
Chassis:
2
Transformers:
4
Number of Channels:
1 per chassis
Transformer Rating:
4 x 1500 va
Total Capacitance:
320,000 uF
400 watts/channel
Output Impedance:
.013 ohm
83.32 amps
Number of Lasers:
2
Input Type:
RCA
Approximate Weight:
115 pounds x 2
Dimensions:
19"d x 15"w x 9"h
Specifications
Chassis:
2
Transformers:
4
Number of Channels:
Transformer Rating:
2000 va
Total Capacitance:
280,000 uF
800 watts/channel
Output Impedance:
.013 ohm
Input Impedance:
30,000 ohms
>100 amps
Input Type:
RCA, XLR
Approximate Weight:
220 pounds x 2
Dimensions:
18"d x 18"w x 33"h
34,6 KB Προβολές: 30
37,8 KB Προβολές: 30
31 KB Προβολές: 18
36,5 KB Προβολές: 19
17,7 KB Προβολές: 28
