GRAN TURISMO 5 Prologue
Re: Απάντηση: GRAN TURISMO 5 Prologue
Είμαι......... :107: :107: :107: :107: :107: :107: :107: :107: :107: :107: :107:
Σε μια ώρα θα είναι σαφές γιατί!!!!!
sorry ρε φίλε.. στο χάλασα??????
Πηγή: http://ps3.qj.net/Sony-PS3-firmware-2-16-found-on-PAL-GT-5-Prologue-/pg/49/aid/116446
The latest update from the underground Sony PlayStation 3 scene puts a mysteriously unreleased PS3 firmware into the spotlight. Firmware version 2.16, just one minor spot shy from the latest version of Sony's next generation console software, was allegedly found to exist in PAL versions of Polyphony Digital's Gran Turismo 5: Prologue.
This development came after the fact that many have pondered over the significance of firmware 2.17. It was said that 2.17 came with complementary network code for GT 5 Prologue, though tangible evidence wasn't provided at the time.
Previously, members of the underground have believed that the latest firmware version should have been version 2.15 after they had probed a debug leak of that firmware much earlier.
Speculation that version 2.16 may have been the prototype firmware to be best for GT 5 Prologue have risen, but then claim that Sony discovered holes that could be exploited and decided to update the software to 2.17.
In order to best analyze the code, the team at PS3Hax has released the full firmware package of version 2.16 and 2.17, which are targeted at budding and experienced PS3 hacking teams to experiment with. More updates as we get them.
Αλήθεια δεν βλέπεις τις φωτό Κωστή???
Εντύπωση μου κάνει γιατί τις ανέβασα στον δικό μας server!! :108:
EDIT......
Αμάν!!!!!!!
Δεν φαίνονται!
Το φτιάχνω τώρα!!!
Βρε τι πάθαμε.....
Μπραβο Γιανναρα και καλοριζικο !!!!!!!
Θα τα πουμε μεσα οπως σου ξαναειπα ..... τσαγακι τσαγακι :142:
Ωωωωωχ.
4 10postες σελιδες MONO επειδη εβγαλε την ζελατινα . :138:
Σκεφτειτε τι εχει να γινει αν πατησει και το start. :136:
Κρυφτειτε χριστιανοι.
Ο Δημητρο εχει το GT5 στα χερια του. :142:
Μεγειες ρε !!!
Αντε.......... αργει η εγκατασταση ?
Και εγώ το αγόρασα χθές από το πλαίσιο σε προσφορά με τιμονιέρα logitech...
Λιώσιμο....και σερί μέχρι να αρχίσει το grand prix....
Απίστευτα γραφικά...αλλά και μεγάλη απογοήτευση το ότι έχει μόνο 6 πίστες και μάλιστα μετριότατες σε μέγεθος. ( θα έχει "πράμα" στο κανονικό παιχνίδι αλλά ποιός έχει την υπομονή....)
Τα 3d μοντέλα των αυτοκινήτων είναι από άλλο πλανήτη...πραγματικά τέλεια.
Αλλά επίσης ένα μεγάλο μειονέκτημα το πολύ έντονο frame drop σε στροφές απότομες με αυτοκίνητα στην πίστα σε in car view..
Πχ στην πίστα στο βουνό είναι τρομερά ενοχλητικό...
Όπως και μικροκολλήματα στο replay.
..όχι σε όλες τις πίστες αλλά ικανό για να χαλάσει την τελειότητα του παιχνιδιού....
Πάντως όπως και να έχει είναι μεγάλο βήμα εμπρός για τα racing videogames.....
Ωωωωωχ.
Μεγειες ρε !!!
Η ηρεμία πριν την καταιγίδα :143:
Είχε και F1 σήμερα, θα αναστενάξει ο server...
"ουαί τοις ηττημένοις" ... :137:
:142::142::142:
..that's the way it works the games industry my friend..
Παρ'όλα αυτά το παιχνίδι σαν παιχνίδι δεν είναι σε καμία περίπτωση simulation αλλά ούτε και 100 %fun...
Αν δεν είχε τα πιο απίστευτα visuals θα πήγαινε άπατο...
Χωρίς damage και physics επαφής μεταξύ των αυτοκινήτων , απέχει χιλιόμετρα από " the real driving simulator" που αναγράφεται στο κουτί του..
Πάντως έβαλα αμέσως μετά το gotham4 και λίγο το forza και τα έβγαλα σε 2 λεπτά...Φαίνονται video games...
Στο gt5 prologue υπάρχουν στιγμές που χάνεσαι κανονικά και νομίζεις πως βλέπεις βίντεο...
Το πήρα κι εγώ σήμερα!!! απο mediamarkt μόνο 40 ευρώ!
Φθηνό είναι για παιχνίδι του PS3 ...
Μου βγάζει όμως μύνημα οτι "cannot establish connection to the server" γιατί????????
Grigoris1966
