JBL CONTROL NOW
Nick Arvanitakis
Audio Pro
JBL CONTROL NOW AW
All-Weather 2-Way, Dual 4" Bookshelf/Wall-Mount/Corner-Mount Speaker [FONT=Arial, Helvetica, sans-serif] 90 DEGREES OF PURE INGENUITY
For more than 60 years, JBL has been the clear favorite of leading recording artists and sound engineers around the world, providing best-in-class audio equipment for concert halls, recording studios and movie theaters everywhere. Now the company that sets the standards changes the rules, with JBL Control NOW™ AW speakers.
[/FONT]
[FONT=Arial, Helvetica, sans-serif] Incorporating innovative proprietary technologies into an ingenious and uniquely versatile design, JBL Control NOW AW speakers will deliver evenly distributed sound with minimal distortion at any volume level in any listening environment, indoors or out*. Media rooms, rec rooms, kitchens, decks, pool houses, patio – anywhere you want great sound and need installation flexibility – JBL Control NOW AW speakers are the high-style, high-performance choice.
JBL Control Now AW speakers are available in a white finish with white grille. Speakers sold individually.
*Please note that while the JBL Control NOW AW is an all-weather outdoor speaker, it is not waterproof. It should be sheltered from direct exposure to ice, snow and sustained moisture.
[/FONT]
OTHER CONFIGURATIONS:
WATCH THE VIDEO:
SPECIFICATIONS
General
Frequency Response (±3dB)80Hz – 30kHz Maximum Recommended Amplifier Power150W Power Handling (Continuous/Peak)50W/300W Sensitivity (2.83V/1m)90dB Nominal Impedance8 Ohms Crossover Frequencies2000Hz –
18dB/Octave (LF Driver)
36dB/Octave (HF Driver) High-Frequency Transducer3/4" (19mm) Titanium-laminate dome in patented Bi-Radial® horn, shielded Low-Frequency TransducerDual 4" (100mm) PolyPlas™, shielded TerminalsHigh-performance push connectors; removable for use of included multiunit wiring adapter Dimensions (H x W x D)5" x 14-5/16" x 9-7/8"
(127mm x 364mm x 251mm) Weight per Speaker6.6 lb (3.0kg) Accessories Included• Wall bracket and hardware
• Multiunit wiring adapter
• Floor-stand adapter and hardware
• Adhesive bracket covers (2)
http://www.jbl.com/home/products/pr...age=ENG&Country=us&Region=USA&cat=BFS&ser=COS
Nick Arvanitakis
Audio Pro
Nick Arvanitakis
Audio Pro
Απάντηση: JBL CONTROL NOW
Τιμη για την Ευρωπη δεν εχει ανακοινωθει ακομη.
Θα ειναι διαθεσιμο απο τον Αυγουστο και μετα.
Μαθαμε και την τιμη!!
199 ευρω το τεμαχιο για τα μαυρα και 229 ευρω για τα λευκα που ειναι all weather!
DAMBO
