Marantz - Denon 13.1 - AV8805, AVC-X8500H
παρε κοσμε παρε :D
Strong points :
  • Precision and richness of multichannel decoding
  • High transparency rendering that is equally suitable for listening to music and home cinema
  • Audyssey XT32 Self Calibration Efficiency Allied with MultEQ Editor Application
  • Great versatility of speaker configuration up to 9.2.4 or 7.2.6 with Audyssey calibration up to 15.2ch
  • Complete management of the Auro3D until 13.1
  • Connectivity input / output complete with possibility of software evolution
Weak points :
  • Dolby Surround Upmixer that does not exploit the widescreen
  • Upmixer DTS Neural-X limited in 11.2ch which makes that in a context 13.2ch Front Wide no longer receive signal
  • Complex cohabitation between Dolby Atmos and Auro3D. A more advanced notion of mapping would have been welcome
  • Audyssey XT32 imposing the use of a pass-low filter upstream of the passive subwoofers on pain of obtaining a slight breath
  • Finishing the remote not at the height of a high-end pre-amp
θα εχει και συνεχεια το τεστ σε imax dts
2-3 πραγματακια
1) πλεον το multeq editor app δεν εχει θεματα επικοινωνιας κ.λ.π.
2)μια ενιαια εγκατασταση ηχειων καλα μετρημενη για ολα τα formats ακομα και του ερχομενου imax dts με κεντρικο υψους που θαχει....ειναι αποδεκτη ;)
και......
3)δεν μπορουμε να μην αναφερθουμε σε αυτο που ολοι λενε :p:D
On the Auro 3D demo disc containing various extracts, the three-dimensional effect is perfectly rendered!The feeling that the contribution of immersion is even more qualitative than the best Atmos demos that I could test. The rendering is equally convincing on film and concert clips. We can only regret that this format is so little exploited.
Where the DSU and Neural-X offer no adjustment, the Auro Matic upmix offers more flexibility depending on the listening room and the intensity of the desired effect. The "Movie" setting combined with the "10" level will prove to be a good starting point. The modes "Grande" or "Petite" room dispatch more the voices on the 3 frontals is thus suitable mainly to the music.
melina
Cargo 200
Νταξ', τώρα αυτό γιατί το συνεχίζουν; Σαν να μην θέλουν την άμεση σύγκριση Α/Β μεταξύ των δύο φορμάτ.
και αυτα που γραφουν παλι καλα αγαπη.....
...εξαλλου γραφουν οτι εχεις καλυτερο αποτελεσμα 3d στα demo disc atmos vs auro σε ταινιες και μουσικη....
οποιος καταλαβε καταλαβε....:)
...η συγκριση α/β δεν κανει καλο στους κριτες...;)
σημασια εχει οτι μπορουν να συνυπαρχουν και ο κοσμος να παιρνει αυτο που κανει κεφι......το μονοπωλιο οδηγει μαθηματικα σε κακη ποιοτητα προς τους καταναλωτες...
ωραιο demo room εχουν οι μαγκες !!!!! :hi:
https://forums.audioholics.com/foru...ith-new-features-11-1-18.112984/#post-1278675
  • eARC (Enhanced Audio Return Channel)—A feature introduced for HDMI 2.1, eARC will allow for additional formats to be transported including the below. Moreover, eARC includes a mandatory information channel telling the TV which sound formats are supported by the AVR so that the TV outputs best possible format automatically.
    • Dolby Digital Plus (up to 7.1 channel)
    • Dolby TrueHD (up to 7.1 channel)
    • Dolby Atmos
    • DTS-HD High Resolution Audio (up to 7.1 channel)
    • DTS-HD Master Audio (up to 7.1 channel)
    • DTS:X
  • IMAX Enhanced—The Denon AVR-X8500 and Marantz AV8805 will be the first receivers equipped with IMAX Enhanced technology. As IMAX Enhanced content becomes available, owners of these products will have access to one of the most advanced audio and visual formats available. With meticulous adjustments modeled on how the IMAX theatrical sound system operates, this proprietary IMAX audio mix is translated for home theatre environments and exclusively delivered using a special variant of the DTS:X codec technology integrated in home entertainment equipment to deliver immersive, powerful sound.
  • Smart Remote Management (SRM) and Web UI—Audio, video, speaker and input functionalities will support via web UI for the Denon AVR-X8500H, Marantz AV8805, and Marantz SR8012.
    • This Web UI and remote monitoring and management are made available by ihiji invision and Domotz pro
παρε κοσμε παρε :D
Strong points :
Weak points :
καλά όλα αυτά με την μούλτι τοποθέτηση...αλλά για εξπλέιν λίγο ρε Κωστή
τα front high γιατί είναι σαν atmos τοποθετημένα?(και τα έχουν και ανάποδα λόγω διασποράς...?)
+τα πίσω high του Auro ''κόβουν'' ανάμεσα από τις 2 σειρές καναπέδων (και αυτά ανάποδα επίσης)
+ αυτά γιατί κοιτάνε στον γάμο του Καραγκιόζη και όχι τις θέσεις ακρόασης?
+ back surround? γιατί τα rear high του Auro δεν είναι τοποθετημένα πάνω από αυτά?αντιδιαμετρικά με τα front high δηλαδή?
απο φωτο σε τετοιους χωρους δεν μπορεις να ξερεις 100%
σαν χωρος ειναι πολυ ωραιος παντως....εξαιρετικος θα ελεγα και στα γουστα μου
βοηθανε αυτες ;
και εχει την δυνατοτητα να αλλαζει θεσεις ηχειων ;)
[DOUBLEPOST=1541099427][/DOUBLEPOST]αυτος θελει αυτο το στησιμο ηχειων που το θεωρω λαθος οπως δειχνει στις φωτο.....
........εγω θα ειχα αλλο στησιμο ;)
βοηθανε αυτες ;
View attachment 108942 View attachment 108943 View attachment 108944
ακριβώς όπως η σοφίτα:party:....έτοιμος πρισματικός χώρος....
με την διαφορά ότι εγώ έχω και ένα κεντρικό ξύλινο κολωνάκι...μου βάζεις ανέξοδες ιδέες8-):D
Sugah
Ζαχαρούλης
Ωραίο,δωμάτιο.
Ένας σιδηρόδρομος χρειάζεται στα καδρόνια για να κάνει “masking” και στα ηχεία ανάλογα το φορμά!
https://www.stereophile.com/content/music-round-94-benchmark-marantz-page-2
• First, the low frequencies are handled a bit differently between Pro and the app. This is mostly attributed to an improvement to room-correction accuracy, but the app does apply a 3dB rolloff at a minimum of 20Hz, even for large, capable speakers. We're evaluating ways to improve how that is handled. Although reasonable in the majority of cases, it can cut the lowest lows just a little bit for some users.
Low-Frequency Rolloff
This is applied not only to Large speakers but to subwoofers, and at the moment can't be overridden. That's probably much more significant for home-theater users than for music-only listeners.
Αφορά ελάχιστους βέβαια.
Εμένα διαβάζουν αυτοί που το έκαναν...
Low-Frequency RolloffThis is applied not only to Large speakers but to subwoofers, and at the moment can't be overridden
Σοφή επιλογή. ;)
Ti ωραιες ληψεις στο #88 :) δεν πρεπει να εχει ''τρυπα'' πουθενα!!
Η πορτα δεν εχει χερουλι; με κουμπι ανοιγει;:unsure: μαλλον το στρογγυλο ειναι δε φαινεται καλα.
ε οχι ρε παιδια και 4 χρονια !!!
τα διπλά λεω εγω, ειναι τουμπανο το εργαλειο ...
...αν παιξει και σε ωραιο χωρο με καλα συνοδα, αντε γεια ;)
  • Like
Reactions: PPG
venar
