Zeitgeist (2007)
Zeitgeist (2007)
ΑΠΟΚΑΛΥΠΤΙΚΟ ΝΤΟΚΥΜΑΝΤΕΡ
http://www.zeitgeistmovie.com/sources.htm
ZEITGEIST details the history of the current geopolitical structure, starting with the history of Christianity,
and developing through the formation of current Governments and their eventual goals.
Zeitgeist was created as a non-profit filmiac expression to inspire people to start looking at the world from a more critical perspective and to understand that very often things are not what the population at large think they are.
The information in Zeitgeist was established over a year long period
of research and the current Source page on this site lists the basic sources used / referenced.
Soon, an Interactive Transcript will be online with detailed footnotes and links so exact sources and further research can be relayed.
Now, it's important to point out that there is a tendency to simply disbelieve things that are counter to our understanding, without the necessary research performed.
For example, some information contained in Part 1 and Part 3, specifically, is not obtained by simple keyword searches on the Internet. You have to dig deeper.
For instance, very often people who look up "Horus" or "The Federal Reserve" on the Internet draw their conclusions from very general or biased sources. Online encyclopedias or text book Encyclopedias often do not contain the information contained in Zeitgeist.
However, if one takes the time to read the sources provided, they will find that what is being presented is based on documented evidence.
Any corrections, clarifications & further points regarding the film
are found on the Clarifications page.
That being said, It is my hope that people will not take what is said
in the film as the truth, but find out for themselves, for truth is not told, it is realized.
ΕΛΕΥΘΕΡΗ ΔΙΑΘΕΣΗ ΟΛΟΚΛΗΡΗΣ ΤΗΣ ΤΑΙΝΙΑΣ ΣΤΑ ΠΑΡΑΚΑΤΩ LINKS
http://video.google.com/videoplay?docid=5547481422995115331
TORRENT LINKS
http://www.mininova.org/tor/878003
http://www.mininova.org/tor/811686
GREEK SUBS LINK
http://subs4u.gr/download_Sub.php?id=7858
Αδιανόητο ντοκιμαντέρ !!!! Δείτε το οπωσδήποτε μέσω του google ή κατεβάστε το (υπάρχει σε torrent & rapidshare με ενσωματωμένους Ελληνικούς υπότιτλους)
Σηκώνει πολύ συζήτηση.....
Επίσης (το έχω δει). Επιφυλλάσομαι για άποψη αργότερα, θέλει χρόνο.
Να το δείτε οπωσδήποτε! Ακόμα κι' αν διαφωνήσετε εντελώς με τη συνολική παρουσίαση, κάτι θα δείτε-ακούσετε για πρώτη φορά.
Zeitgeist
Το ντοκυμαντερ ξεκιναει αναλυοντας την εννοια και σημασια του μυθου για να καταληξει μεσα απο μια πορεια ιστορικων γεγονοτων και χειροπιαστων στοιχειων να σου ανοιγει τα ματια για τον κοσμο στον οποιο ζουμε και το που οδευει αυτος. Δεν εχει υπαρξει κατι αναλογο που να με κανει να προβληματιστω τοσο πολυ, για πραγματα που νομιζουμε δεδομενα και άλλα που υποψιαζομαστε αλλά δεν διαθετουμε τα μεσα για να επιβεβαιωσουμε. Ειναι η απολυτη καταγραφη των φοβων μας! Ακομα και ο Michael Moore, τον οποιο θεωρω πολυ καλο ντοκυμαντεριστα, δεν εχει φτασει το εργο του σε τετοιο βαθος.
Προκειται για ακρως αμφιλεγομενο υλικο. Το γεγονος πως δε θα βρειτε και πολλες πληροφοριες στο internet (απο οπου γινεται και η μοναδικη διανομη του) γι αυτο το επιβεβαιωνει. Πολλοι θα ξενιστουν απο την εισαγωγη του και ισως να μην θελησουν να συνεχισουν. Η ταινια ομως δεν εχει σκοπο να προσβαλλει, ζηταει ανοιχτο μυαλο και τη διαθεση να δειτε καποιες αληθειες που συγκλονιζουν.
Η επισημη ιστοσελιδα απο την οποια γινεται και η διανομη του σε downloading και σε dvd. http://zeitgeistmovie.com/ . Κυκλοφορουν και ελληνικοι υποτιτλοι.
Δειτε το οπωσδηποτε!!!
HV
Αγορασα απο τον ανθρωπο αυτο την Special Remastered Edition που εχει αρκετα καλουδια περισσοτερα απο την πρωτη εκδοση....Ο τυπος ειναι ΠΟΛΥ ψαγμενος.
Φαινεται πολυ ψαγμενος απο την ερευνα που εχει κανει. Τι παραπανω εχει αυτη η εκδοση?
HV
Εχει Intro απο τον ιδιο τον συγγραφεα, διαφορετικες εικονες και γραφικα και ειναι καποια λεπτα μεγαλυτερο σε διαρκεια. Και εννοειται λιγακι καλυτερο οσο αφορα την ποιοτητα εικονας. 5ευρω κοστιζει.
Το είδα χθες.
Πιστεύετε σε αυτά που λέει, ή τα θεωρείτε θεωρίες συνομοσίας;
MAD
Σιαρτάκιας
Απάντηση: Zeitgeist (2007)
Το 95% είναι αλήθεια!! Η γνώμη μου, και δεν προσβάλει κανένα με ανοιχτό μυαλό, τα κλειστά μυαλά δεν θα αλλάξουν μέχρι να πεθάνουν και να πάνε στον παράδεισο να κάνουν παρέα με τους αγγέλους!!!
Απάντηση: Re: Zeitgeist (2007)
Το είδα χθες.
Όπως το λέει ο Mad, το μεγαλύτερο ποσοστό είναι αλήθεια. Εξάλλου αν υπάρχει συνομωσία (λέμε τώρα) ποιός την κάνει; Αυτός που είναι απο κάτω ή αυτός που κυβερνάει; :116:
δεν υπάρχουν αλήθειες και ψέμματα.
υπάρχουν γεγονότα, μύθοι και απόψεις που σε κάνουν να σκεφτείς.
απευθύνεται κυρίως σε Αμερικάνους και σε όσους ζουν και ενημερώνονται σαν Αμερικάνοι!
Αφύπνιστικό!
Εξαιρετική αλήθεια αυτή asikamin.
Κατά τα άλλα, σε ένα τεράστιο ποσοστό αλήθειας, είναι πολύ δύσκολο να ξεχωρίσεις την χειραγώγηση, αν αυτή υπάρχει.
Κι εμείς οι "αφυπνισμένοι" όμως.........., απλώς το δεχόμαστε.
Δεν λέω να κάνουμε κάτι.
Απλά ποια η διαφορά του να ξέρεις και να μην κάνεις τίποτα, από το να μην ξέρεις καθόλου.
Μήπως είναι τελικά λιγότερο βασανιστικό το να έχεις άγνοια;
η άγνοια είναι ευτυχία , σίγουρα!
αλλά δες και το Λιακόπουλο, τα ίδια πράματα λέει (και πουλάει) με διαφορετικό "περιτύλιγμα".
δεν μπορώ να "εμπιστευθώ" κάποιον που πουλάει την "γνώση"...
η αληθινή γνώση δεν πληρώνεται...
(ούτε στέλνεται με μηχανάκι στον χώρο μας, αβίαστα!)
MAD
Σιαρτάκιας
Πάντως όταν δεν είμαι καλά, ακούω λίγο λιακό και μου φτιάχνει το κέφι, πρέπει να ομολογήσετε ότι αυτό είναι χάρισμα!! :142::142::142:
Μια χαρά παιδί είναι, στο κάτω κάτω με 20 ευρώ 10 βιβλία , ούτε στο μοναστηράκι δε βρίσκεις.
.......... Απλά ποια η διαφορά του να ξέρεις και να μην κάνεις τίποτα, από το να μην ξέρεις καθόλου.
Για να αποφασίσεις να κάνεις κάτι πρέπει πρώτα να ξέρεις. Σε πρώτη φάση τι συμβαίνει και σε δεύτερη πως πρέπει ν' αντιδράσεις. :126:
Αν κρίνει κανείς από την ελάχιστη συμμετοχή των μελών στο παρόν θέμα, υπάρχει κάποιο μεγάλο πρόβλημα. Και αυτό κατά τη γνώμη μου είναι, πως για να αποδεχτείς πως αυτά που περιγράφονται στην ταινία ισχύουν, πρέπει ταυτόχρονα να παραδεχτείς πως τόσα χρόνια,
ΚΟΙΜΑΣΑΙ ΟΡΘΙΟΣ ΚΑΙ ΠΛΗΡΩΝΕΙΣ ΞΕΝΟΔΟΧΕΙΟ!
Οπότε ο εγωισμός του καθενός δεν τον αφήνει.
Τόσο απλό. Αφού ο κλασικός ------- ο Έλληνας δεν ξέρει πως για να είσαι μέλος μιας κοινωνίας, μειώνεις λίγο τον εγωισμό σου και αυξάνεις λίγο τη συμμετοχικότητά σου. :110:
antavent
