Στην γωνια του antkots
Απάντηση: Στην γωνια του antkots
Tα επιπλέον του MK6:
1. High-quality materials OFC (oxygen-free copper wire) adopted by the S-shaped tone arm
Arm and arm contact point to the base of high precision bearings and pivot to set up the arm's next move (the horizontal axis of rotation) and the vertical movement (vertical axis of rotation) Central match the tone arm pivot point, arms control balance JINBARUSASUPENSHON sensitive method in addition to the excellent performance in certain trace sound reproduction possible to S-shaped tone arm mounted. To tone arm signal line OFC (oxygen-free copper wire) to adopt it in the signal transmission loss and distortion reduction and improved sound quality.
2.Further vibration damping to the realization of the three-tiered cabinet
T.N.R.C.(Technics Non Resonance Compound)、Cabinet high stiffness at the top of the middle part of our own TNRC (Technics Non Resonance Compound), a special heavyweight rubber at the bottom of a three-tiered arrangement cabinet adopted for the good vibration damping to achieve. Also seamless casting to it, at the top of the cabinet is an excellent robustness and durability, lower special in the heavyweight rubber antivibration and high resistance to degradation years has been to reduce the use of depleted.
3. Continuous pitch control accuracy improvement
Traditional established vertical control circuit can be added to a scale and the actual pitch and reduce variation in the pitch of accuracy improves, more accurate possible.
4. Long-life high-intensity blue LED needlepoint adopted
Needlepoint LED (light-emitting diode) adopted by the high-brightness long life to achieve. More beautiful blue LED light sheen of the stage to play DJ school director.
5. DJs from around the world will be supported by the SL-1200 high-performance high reliability
Unique Turntable monolithic structure motor antivibration of excellent special rubber molding of according to taste adjustable brake stop DJ playing to support needle-pressure regulator feature malfunctions to prevent power switch cabinet stands at the top of the shell spare equipment mounting Department to add scale, the needle pressure will be easy to reproduce. Pitch control instantly ± 0% of the reset switch can be set.
(Mεταφρασμένο από το Ιαπωνικό site της TECHNICS).
:107:
caravelle δωσε μου τα πληρη στοιχεια του βραχιονα του ΜΚΙΙ, θελω να υπολογισω κατι..
Οκ, αρα θελει 14αρα κεφαλη με περιπου 6 γραμμαρια βαρος.
Μετα χασαμε...
Αντωνη, ελευθερος, αν μπορεις συνεχιζουμε...
Μετα χασαμε...
Εγώ πάντως διαβάζω από 3,5 gr. (με το βαριδάκι το έξτρα), έως 13 gr., (με το βαρίδι το έξτρα. Άλλο αξεσουάρ αυτό.).
Ας πω και ένα ευχαριστώ!
:107:
Γιατί δεν κάνετε στο σπίτι του Αντώνη ένα τεστ πικαπακίων
αλλά..... να είναι κρυμμένα πίσω από παραβάν.
Θεωρώ ότι θα έχουμε πολύ ενδιαφέρουσες απόψεις
και συμπεράσματα και ειδικά από τον ιδιοκτήτη που
θέλει να πάει παραπάνω μεν , αλλά τον τρώει μέσα του
και αναρωτιέται δε, " λες εντέλει να έχουν δίκιο αυτοί οι παλαβομικαπαδύες "??
Άντε παλικάρια μου, άντε να δούμε πόσα απίδια πιάνει ο σάκος που λένε στα χωριά:116:
(πάντα φιλικά γιατί μερικοί είναι και παρεξηγησιάρηδες:144:)
Κώστα είναι universal general purposes type 1C, ιδανικός για βινύλια 7inz για τη δεύτερη αρμονική
Σε βινύλια 12 inz βγάζει αρκετή παραμόρφωση. Ολοι σχεδόν οι βραχίονες για επαγγελματική χρήση έχουν αυτή την γεωμετρία.
Για την ιστορία και μόνο η Linn αρνιόταν να βάλει 45αρια στο πλατό της λόγο γεωμετρίας 1Α των βραχιόνων της μέχρι πρόσφατα και κάποιες πατέντες είχαν να κάνουν με μια προσθήκη στο spidle των μοτέρ της πρίν περάσει στα αντίστοιχα PSU.
Στις παραπάνω photos βλέπετε την γεωμετρία των τεσσάρων τύπων ακτινικών βραχιόνων όπως ακόμα και σήμερα χρησιμοποιούμε χάρη του Stevenson. Τίποτα δεν έχει αλλάξει από το 1967.
Οσο αφορά το extra βαριδάκι πίσω από τον βραχίονα ή το shell weight μπροστά δεν το κάνει για να αυξήσει την ενεργή του μάζα (που είναι ίδη υψηλή) αλλά για να διατηρήσει το κέντρο βάρους της συνεδρίας όσο πιό κοντά γίνεται στο κέντρο περιστροφής του βραχίονα (Pivot). Ενα πρόβλημα που έχουν όλοι οι S type βραχίονες καθώς δεν μπορούν να διατηρήσουν το κέντρο βάρους τους επί του σωληνωτού αλλά και να είναι επί του ενεργού τους μήκους.
Αποτέλεσμα είναι ο βραχίονας με την μεταβολή της VTF που έχουμε κατά την ανάγνωση ενός δίσκου να μεταφέρεται εκτός σωληνωτού με αποτελέσματα που δεν είναι της παρούσης.
Ακριβως ετσι Γιωργο μου, ακριβως.
Εγω βεβαια πριν μιλησα για το τι ειδος κεφαλη μπορεις να "φορτωσεις" σ αυτον τον βραχιονα για να πετυχεις τα 10 Hz.
Η τεράστια διαφορά των S shaped από τους straight είναι ΜΙΑ και μόνο ΜΙΑ.
Μπορούν να παίζουν ένα βινύλιο ανάποδα ή να κάνουν σκρατς χωρίς η βελόνα να πηδά.
Ο λόγος είναι ότι λόγο του σχηματός τους μπορούν να συμπεριφέρονται το ίδιο και στην ολίσθηση προς το κέντρο όταν ο δίσκος γυρνά clockwise ή στην ολίσθηση πρός τα έξω όταν γυρνά ο δίσκος από την ανάποδη.
Για αυτόν επίσης τον λόγο όλα τα επαγγελματικά έχουν S shaped ή βραχίονες χωρίς off-set ενός σημείου μηδενισμού (stanton πχ)
Λοιπόν παίδες peaceee!!
Ας κανονίσουμε μια συνάντηση για συγκριτικό πλατώ ίδιας κατηγορίας τιμής με ίδιες κεφαλές. Να δούμε τελικά αν καταρίπτοντε οι μύθοι..
Αν θυμάμαι καλά, κανένα περιοδικό ειδικού τύπου δεν έκανε άμεση σύγκριση ΜΚ2 ή ΜΚ... κάτι, με άλλο ίδιας κατηγορίας τιμής και με ίδιες κεφαλές.
Ας μην πιάσουμε τώρα οτι η κάθε κεφαλή μπορεί να μην ταιριάζει με ενδοτικότητες κλπ γιατί άκρη δε θα βγάλουμε....
Antkots, Manos58, Caravelle, Markou, Papas, Takis(με τα ρέστα), Κυριακού, GeoVaz, στη σέντρα!! Όλοι σπίτι μου! Θα σας πω πιο Σάββατο θα αδειάσει το σπίτι "τα παιδικά παιχνίδια" για να παίξουμε εμείς!
Δεν γινονται Σταματη αυτα τοσο ευκολα και απλα.
Πρεπει να υπαρχει μια κοινως αποδεκτη αναφορα και μετα να γινουν τα τεστ ως προς αυτην.
Ταυτοχρονα το συστημα πρεπει να ειναι μακραν περα του μεσου ορου αναλυτικο και αποκαλυπτικο.
Για δείτε τι λέει η KAB περί βραχίονα PAM 18201/2 K, (MK2), και των βελτιώσεων του, (δυστυχώς Αγγλικά):
"Myth Statement
The Tonearm Is The Weak Link, Replace It.
If you have been in this long enough, you know that the '1200 has come along way in terms of overall critisism. Why, at one time it was an accepted rule that the '1200 was not worthy of quality reproduction on any level, plinth, motor and arm. Well, times have really changed and as more learn what the 'table is all about, and more serious people use it and approve of it, the things left to criticize get smaller. These days it is down to the tonearm and in some cases just the wand wire.
Just like a turntable, the toneam is not a monolithic entity. When you read declarations like "Tonearm X is much better than tonearm Y", you should be skeptical and at least want to know more of what was truly compared. When you look at a tonearm, you have a the following items:
1. Headshell
2. Arm Wand
3. Bearing Sytem
4. Arm Base
5. Internal Wand Wiring
6. Interconnect
7. Phono Cartrtidge
There are certain things an arm must do well or else it will have an impact on the sound.
1. The arm wand must not produce a resonant tone. This is easy, just taper it or curve it at 2 dissimilar distances. A simple test of tapping the wand with a paper clip, while in a stationary groove will let you hear the "sound" of the tonearm.
2. The wand wire must be sonically neutral. Most of what people hear in the upper registers can be layed at the feet of the wand wire. For the '1200, in the MK2 and MK5 models, this is a tin plated fine strand and is truly the achilles heal of the arm in the upper registers. the M5G uses OFC fine strand and is significantly better. Our Cardas rewire is likely to be the best overall choice for neutrality. Once the arm wire is neutralized, then you can concentrate on the true item of color, the cartridge.
3. The bearing system must do 2 things well, provide low friction and provide a good mechanical ground. The '1200 arm has friction specified at 7 miligrams. That may be the lowest friction specified in an owners manual. The gimbal type bearing has 2 mechanical grounding points. one on top, one on bottom. We believe the gimbal offers the best overall technical performance. Non gimbals produce higher friction and less mechanical grounding.
4. The Interconnect is important to the extent of distributed capacitance. If you are using a MM cartridge, this capacitance adds with the preamp to effect the response of the cartridge. It needs to be known.
When you look at improving arm performance, fluid damping is another key element. Fluid damping eliminates shock resonance. that is the woofer pumping that occurs on even the slightest warps. There are other ways of dealing with this like choosing an arm with high bearing friction or choosing a very low compliance cartridge, both of which are poor solutions in our opinion. Fluid damping is not a bandaid, it is a key element in good tonearm design. The more you stabilize the arm, the more still the sound picture that develops. Fluid damping does not increase arm friction and so does not increase groove wear.
Of course there are alot of non technical reasons to want to try a different tonearm. My only comments regarding that approach is, know what the technical or functional limitations are and don't do anything that cannot be reversed. Here is some food for thought:
• Changing to non gimbal fixed bearing, this will have higher static friction and groove wear.
• Changing to unipivot, these have poor lateral stability, and will increase rumble and woofer pumping. If you are insistent in trying these, look for one that incorporates some method of lateral stabilization.
• Changing to fixed headshell, you will be giving up the ability to quickly audition different carts.
• Changing to fixed arm base, you will be giving up calibrated VTA adjust.
The cost to add fluid damping and Cardas wire to a stock 1200 arm is $318.00. What other tonearm at anywhere near that price will give you that and all the flexibility of a '1200 arm?
Read online reviews of DIYers who rewired their arms with Cardas and see what they say about it. Is there any reason to doubt that if the '1200 arm was rewired in that way, it would benefit any less?
At KAB it is all about value and performance, you can spend lots of money on a monolithic item that someone else says sounds great, or you can break things down into their component parts and analyze what is really going on . It is your hobby. Get more involoved in what makes it go!
Myth Responded To."
:107:
Re: Απάντηση: Στην γωνια του antkots
Τι εννοείς με το "κοινώς αποδεκτή αναφορά"?
Μια χαρά αποκαλυπτικό είναι το σύστημα! Πιο monitor δε γίνεται!
Το παρεάκι έχει σημασία και η καλή διάθεση! Δε θα κάνουμε και τη δουλειά των reviewers! Να περάσουμε καλά και να βγάλουμε συμπεράσματα θέλουμε!
(Έλα εσύ κι αμα ξαναφάς γαλακτομπούρεκο εμένα να με χ..σεις! Άλλο θα είναι το γλυκό "αναφοράς"!!)
Δηλαδη πιο? Μπουρεκι γαλακτος? .... Ενταξει ειμαστε...
Εχεις δικιο οτι μετραει η παρεα...
Νομιζω οτι μπορει να γινει αυτη η συναντηση μετα πλατω.Ποιος ειναι διαθετιμενος να φερει πλατω και κεφαλη?
Εδω και μια εβδομαδα το σαιτ σερνετε (το εχω γραψει και σε αλλο ποστ),μου εχει σπασει το νευρικο συστημα,κανει 15-20 δευτερα για να φορτωσει,ασε για να παει πισω........καντε κατι βρε παιδια!!Για την υποβολη τα ιδια,και δεν μου βγαζει σκιτσα.
Να τωρα που φραφω δεν εχω σκιτσα.
Εαν δε βγουν (που ακομη δεν εχουν βγει) εινα σκορπια και αι γεια..
  • rose.athens
Quantic
