DACs - τελειωμό δεν έχουν
vlasis
Φωτογράφος!
Απάντηση: DACS....και τελειωμο δεν εχουν !!!!!!!!!!!!!!!
Acoustic Plan --
DigiMaster
http://www.acousticplan.de/html/digi..._english_.html
The D/A converter DigiMaster has probably the most consequent high resolution digital audio processing related to simplicity of all converters on the market nowadays. The USB as well as the SPDIF inputs have 192kHz/24 bit receivers and they pass on the data stream to the 24-bit R2R PCM1704U-K converter. Neither upsampling nor oversampling is used and this keeps the data as pure as possible. The USB data transfer works in an asynchronous mode, whereby the clock is determined by the high precision clock generator in the DigiMaster. To avoid ground loops between the PC and the DigiMaster, the USB receiver circuit is powered by the PC, whereas inductive couplers (iCoupler) provide the galvanic separation between the two units.
specifications:
inputs:
USB 192 kHz / 24 bit
galvanic separation via iCoupler
SPDIF 192 kHz / 24 bit
transformer coupled
I2S
output:
2V / 200 Ohm
dimensions (w x h x d):
106 x 125 x 260
weight:
2 kg incl. external power supply
finish:
frontplate blue, casing silver
others on request
vlasis
Φωτογράφος!
Playback Designs
MPD-5----Music Playback Digital to Analog Converter 5
http://www.playbackdesigns.com/mpd5.html
The next logical step in the Playback Designs' line of products is the release of the Music Playback Digital to Analog Converter 5, also known as the MPD-5. The Playback Designs MPD-5 is identical in every way to the MPS-5 SACD / CD Player except it does not have a transport mechanism. Also, thanks to the modular nature of its design, the MPD-5 can be upgraded to a fully functional MPS-5 CD / SACD Player. The MPD-5 is a world class DAC that can receive a variety of external digital sources, including PC based music servers – not only a unique and powerful combination, but also versatile in applications.
Connectivity
Analog outputs:
XLR: balanced, 4Vrms @ 1kHz full level, pin 2 Hot
RCA: unbalanced, 2Vrms @ 1kHz full level
BNC: unbalanced, 50Ohms, 2Vrms @ 1kHz full level
Digital outputs:
XLR: AES/EBU formatted for stereo linear PCM data.
The data on this output will be up to 24bits and up to 192kHz.
Data / Clock:
For future expansion.
Digital inputs:
AES: XLR connector for AES/EBU formatted stereo linear PCM data, up to 24bits and up to 192kHz.
S/PDIF: same as AES, but S/PDIF formatted on RCA connector.
TOSLINK: same as S/PDIF, but on optical connector.
PLAYLINK: Proprietary links to future Playback Designs equipment.
PC: Direct USB connection to computers for sample rates up to 48kHz.
PC: External USB-X connection to computers for sample rates up to 384kHz (PCM) and 6.1MHz (DSD)
System Control:
REMOTE: RS-232 wired remote control.
vlasis
Φωτογράφος!
Και ειναι δυο σε ενα ετσι..............Stereo Preamp Processor
vlasis
Φωτογράφος!
Isabellina
Digital-to-Analog Converter
Product Features
* Now in its 2nd generation
Upgrade available for previous versions
* Up to 3 types of digital connectivity (Coaxial, Optical and optional USB)
* Optional USB input converts to I2S, eliminating the need for S/PDIF conversion, a sound-degrading step found in many USB implementations
* USB input provides “galvanic isolation,” meaning it isolates your computer’s power bus from our internal DAC chip – an innovation that prevents computer noise from degrading the sound you hear
* Red Book (16-bit) playback ships standard
* Isabellina Pro Icon Optional Isabellina Pro adds high-resolution playback (24/192k)
http://redwineaudio.com/components/isabellina
vlasis
Φωτογράφος!
B.M.C. - Digital / Analogue Converter
http://
Furthermore there is a “Low” ( 32fs) and a “High” (128fs) oversampling rate available. Both options have their individual character and are suitable for decent sound tuning. “Low” has a more dynamic and detailed expression, while “High” is softer and smoother.
The digital signal performance is further optimised by a clock synchronisation circuit right in front of the DAC-Chips. All digital signals are re-timed to the local master clock and thus the point of lowest jitter is at the DAC-Chip where the analogue music signal is made.
The conversion is made by two 24-Bit / 192kHz TI/Burr-Brown PCM1792 chips with current output.
vlasis
Φωτογράφος!
DAC-040
Vacuum Tube Digital-to-Analog Converter
http://www.concertfidelity.jp/products/index.html
Based on an acclaimed Philips multi-bit processor, and with a vacuum tube buffer stage, extracts every bit of information from standard CD’s, without relying on any kind of up-sampling, over-sampling, etc. and raises expectations for red book audio CD’s to a new level.
Advances the state-of-the-art of CD reproduction, just as we celebrate the 25 years since introduction of CD Audio. Access to vacuum tubes from outside rear panel encouraging tube rolling.
Specifications
Inputs 1-S/PDIF Co-Ax Inputs (RCA)
Output 1-Pair single ended (RCA)
D/A Converter Dual Philips Multi Bit DAC
Sampling Frequency 44.1kHz
Tube Complement 12AU7 (2) for gain (tube-swapping possible, NOS tubes preferable)
6CA4 (1) for rectification
Phase Polarity Non Inverting
Power Reqiremants 110-120VAC / 60Hz
Dimensions 450mm (W) X 100mm (H) X 310mm (D)
Net Weight 6.5KG
Manos58
εγχειρισμένη
Τα λαμπάτα απορρίπτονται ως μαϊμούδες ψηφιακές
Το άλλο με το 1 στρέμμα πυκνωτίδια δείχνει ενδιαφέρον:107::107::107:
Κώστας Φ.
Βάλε και το "ταπεινό" Accuphase DC-901.
4 Σαβρίδια συνολικά, δηλ. 2 τσιπάκια (= 16 DAC) ανά κανάλι. Ευτυχώς δεν ξέρουμε τιμή.
Καλό καλοκαίρι... :p
Απάντηση: Re: DACS....και τελειωμο δεν εχουν !!!!!!!!!!!!!!!
δυο τσιπακια βλεπω δηλ. 8/καναλι.
Είναι γνωστό οτι τα ic"s δεν κάνουν τη διαφορά ναι?
Δεν πα νάχει και 128 ανα κανάλι , ?
Μην λέμε οτι θέμε ε?
:116:Η μαγκιά έγκειται στο πως χρησιμοποιείς τα ic"s , και οχι στο ποιά έχεις.
Νομίζω?:119:
Re: Απάντηση: DACS....και τελειωμο δεν εχουν !!!!!!!!!!!!!!!
http://www.avsite.gr/vb/showthread....F5%F3%E1-%F3%F5%ED%DD%ED%F4%E5%F5%EE%E7/page3
The Sabre DAC chip has 8 channels. In the DAC202 we use 2 DAC channels per audio channel because we have the headphone output which has separate DAC channels for the volume control. So that’s the only reason. In the MAN202 we don’t have any headphone output, so we use 4 DAC channels per audio channel.
-What is it that becomes better?
You can parallel the DAC channels and add the output of those and for every doubling of channels you get 3dB more signal to noise ratio, in theory. Of course you reach some thermal noise level in the end.
Εκτός και αν έχω καταλάβει κάτι λάθος :203:
Ναι καλά ο κάθε κατασκευαστής? λέει οτι θέλει.
Και εγω μπορώ να πω οτι εχω noise floor -126db, ε και?
Απάντηση: Re: Απάντηση: DACS....και τελειωμο δεν εχουν !!!!!!!!!!!!!!!
Στην θεωρία όλοι καλοί είναι.
Ο παραλληλησμός είναι παλιό κόλπο που ούτως η άλλως χρησιμοποιείται.
Οπως επίσης και οι παρενέργειές του.Ε και?
Ο δικός μου denon avp a1hd , εχει επίσης 4 dacs , ανα κανάλι , ε και?
Το καλό είναι οτι τα εχει -χρησιμοποιεί σε διπλή διαφορική λειτουργία., η αλλοιώς double differential cirquit.Εκεί είναι η μαγκιά , οχι στο πόσα έχεις , αλλά στο πως τα χρησιμοποιείς .
Κώστας Φ.
Re: Απάντηση: Re: DACS....και τελειωμο δεν εχουν !!!!!!!!!!!!!!!
Mόνο που η πλακέτα που βλέπεις είναι για το ένα κανάλι... :116:
Εμένα πάλι μου είναι γνωστό ότι και τα IC's κάνουν τη διαφορά, μεταξύ άλλων... :136:
Όσο μπακαλίστικο είναι να κρίνεις μόνο από το τσιπάκι που "φοράει" μία συσκευή (ακόμα κι αν έχεις κάνει τον κόπο να διαβάσεις - κι έχεις το υπόβαθρο να καταλάβεις - τι innovation προσφέρει το Χ τσιπάκι), άλλο τόσο μπακαλίστικό είναι να λες ότι το τσιπάκι δεν παίζει ρόλο...
Όλα παίζουν τον ρόλο τους στο τελικό αποτέλεσμα. Τόσο "απλά". :444:
ολα τα συγχρονα dac chip εχουν τετοιες εξοδους πλεον οποτε ειτε παραλληλα τα χρησιμοποιησεις
ειτε differential το αποτελεσμα ειναι ιδιο.
ακουγεται ομως πιο ωραια(οχι ο ηχος το ονομα):114:
υ.γ. ο denon εχει 4 το accuphase 16 εκτος αν εχει 4 σαβριδια και o denon.
Manosmathiou
