Mede8er ….UFO aka MED1000X3D
Απάντηση: Mede8er ….UFO aka MED1000X3D
Eβγαλαν εχθές το 1ο firmware update για το med1000x3d που διορθώνει κάποια bugs.Αν και δεν νομίζω να το έχεις κανείς ακόμη,μιας και μόνο στη Νότιο Αφρική έχουν αρχίσει οι πρώτες παραδόσεις και κάποια μεμονωμένα κομμάτια για test ανά την υφήλιο,ωστόσο ας το βάλουμε ενημερωτικά:
V1.0.2 -- 24 July2012
Changelog
1. Fixed Secure Samba Login
2) Fixed 'WORKGROUP' name change - must reboot after making this change
3) Fixed HDD Spin Down
4) Added support for USB Keyboard Text input in Web Browser and Jukebox Search
5) Fixed folder.jpg showing about.jpg when using VIDEO_TS structure in Movie Jukebox
6) Fixed Info bar when using mp4 files on DNLA DMR
7) Fixed showing default embedded subs MKV files
Fixed Hebrew text mirror
9) Auto Play 3D BDISO in 3D (BD Menu must be 'off')
10) Added toggle function on 'F3' button for BD Menu
Download Firmware
V1.0.2 --24July2012
v1.0.2
USER MANUALS
MED1000X3D
v2
AFTER THE UPDATE WE SUGGEST YOU UNPLUG AND REBOOT THE X3 AND THEN CONTINUE
If you installing a new Hard Drive then it should be formatted in the X3 for correct operation. After the format the Hard Drive should be shown as HDD: in the Media Library. (Not the Devices Page) If it not shown as HDD then you must format the Hard Drive a second time)
Emergency Procedure
Download the latest Mede8er Firmware from www.mede8erforum.com. UnZIP or UnRAR or join with HJ Split and will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Unplug the power to the X2. Plug the power jack back in and hold the ON/OFF button on the Mede8er (not the remote) down for 15sec and then release. After the firmware has been checked (+-5-10sec) it will start to update. You will see the update progress on your TV. Do not remove power during the Firmware Update procedure .
PASSWORD PROTECT NETWORK SHARES -- NAS SETUP
Use the My_Shortcuts method as shown in this demo
Demo
PUBLIC SHARES -- PC / NAS
Username: Guest
Password: Guest
IP: xxx.xxx.xx.xx
Το κάνω copy/paste από το Mede8er forum γιατί έχει ιδιαίτερο ενδιαφέρον:
For general info
We have added Auto Frame Rate detection for 25fps and 29.97fps via a new Setup Option in the X3 Setup Menu. This is in Beta testing at the moment. We think this will be well received as its possibly the first Realtek based player to do this. We also did tests on 2D 23.976 and cannot see any micro stutter on the end credit scrolling. So either we getting old or its not visible on our setup or the SDK is outputting 23.976fps. Have not checked this on 3D BDISO as yet.
Mede8er1
Αρχισαν οι πρώτες παραλαβές στην Ταϋλάνδη.Αντε και στα δικά μας!:116:
Τελευταία εβδομάδα του Αυγούστου και κοντά στο 200αρι!
Οπως πάντα θα τα δούμε όλα και θα τα πούμε όλα!
Stay tuned!:126:
όσο αφορά το τσιπάκι που έχει..είναι κάτι καινούργιο και είναι υπό εξερεύνηση η είναι γνώριμο από πριν που το φόραγαν κάποια αλλα?
Re: Απάντηση: Mede8er ….UFO aka MED1000X3D
Φοράει το 1186 chip της Realtek που είναι περσινό.
- Ποιό ειναι το πιο πρόσφατο τσιπάκι της Realtek ;;;;;;;;;
- Ποιό ειναι το πιο πρόσφατο τσιπάκι της Sigma ;;;;;;;;;
Αρχικές εντυπώσεις για το ποιό ειναι σχετικά καλύτερο που θα βρούμε ;;;;
Υπάρχουν στην αγορά της Ελλάδας Mediaboxes με κανένα απο τα νέα τσιπάκια Realtek / Sigma ;;;;;;
-Το 1186
-Το 8643(ή 8642),τουλάχιστον υπο την έννοια ότι είναι το πιο δυνατό.
Τα media player που είναι βασισμένα στο 1186 υπερτερούν στο ότι αναγνωρίζουν full hd 3d,ενώ τα sigma είναι καλύτερα στην κίνηση.Το chipset της Sigma που θα αποκωδικοποιεί 3d είναι το 8910,το οποίο δεν έχει δωθεί στην κυκλοφορία ακόμα.
Ηδη έχει βγει το firmware v 1.0.3 open beta για το Med1000x3 όπου για 1η φορά σε player με realtek chip υπάρχει auto framerate.Οι 1ες εντυπώσεις για την κινηση είναι θετικές,αλλά όπως αναφέρουν στο φόρουμ του Mede8er χρειάζεται να το τεστάρουν ακόμη.
Να ετοιμάζει τα μηχανήματα ο loggeo παρακαλώ,γιατί υπάρχει μικρή πιθανότητα να παραλαβει και Παρασκευή,αλλιώς Δευτέρα ή Τρίτη!:126:
Τώρα να πάρουμε αυτό ή να περιμένουμε το sigma 8910 που έρχεται; Ποιό θα είναι καλύτερο;
gkontoletas
trouble in my brain
To Sigma 8910 θα είναι καλύτερο αλλά ακριβότερο
loggeo
Δε θα υπάρχει μόνο το 8910 της sigma που θα υποστηρίζει 3d. Θα έχει κι άλλα τσιπάκια χαμηλότερου κόστους. Όπως και να έχει δύσκολα θα δούμε player dune hd λχ σε κόστος αντίστοιχο με mede8er. Αλλά αυτά ας τα πούμε στο δίπλα θέμα.
Μια χαρα το βλέπω ώρα να αντικαταστησω το wd...αναμένουμε με αγωνία μια λεπτομερή παρουσίαση (όπως πάντα βέβαια) απο εσάς!!!
s channel
