Home Cinema στο "termatogazi''
TERMATOGAZI
Bass!
Re: Απάντηση: Home Cinema στο "TERMATOGAZI"!
Σε τι διαστάσεις σκέφτεσαι να κάνεις την καμπίνα;
Με παθητικό ακτινοβολητή ή όχι;
http://tcsounds.com/product/drivers/vmp-passive-radiator/
οι διαστασεις θα ειναι 60χ60χ60 , θα βγει περιπου το μισο απο το re audio.
πιστευω οτι καλη περιπτωση ειναι και dual opposed αν παρω δυο.
για παθητικο ακτινοβολητη δεν το σκεφτομαι γιατι δεν θα κατεβαινει τοσο χαμηλα
TERMATOGAZI
Bass!
μολις εφτασε και η αναλυση του χωρου μου απο την auralex.τους εστειλα φωτογραφιες του χωρου μου και μια κατοψη με διαστασεις και σε 3 μερες μου απαντησαν "δωρεαν".
το προτεινω ανεπιφυλακτα σε ολους σας.
σιγα-σιγα θα ξεκινησω τις βελτιωσεις.
Dear Michael,
Thank you for turning to Auralex Acoustics, Inc. for help with your acoustical needs. I have attached a PDF document which includes a top-view drawing of your room as well as suggested product and product placement. Please keep in mind that these suggestions are prepared off-site, based on the information supplied, and the combined experience of Auralex Acoustics.
Given the dimensions and application of your room, I am recommending the following:
• Nine (9) 2’x4’x2” ProPanels – Impaling clips for installation included
• Two (2) 2’x4’x2’ Corner Traps – Impaling clips for installation included
• Wave6 Diffusor System
• ProPAD Monitor Isolators
• SubDude HD
Spread over the walls and ceiling as shown in the attached PDF, the ProPanels can help control harsh high frequency reflections between parallel surfaces. This can help to control “room ring” as well as any excess reverberation in the room. For additional low frequency control, you may consider using our 2” offset impaling clips (sold separately) to provide space between the wall and the panel. The air space between the two can help improve the overall broadband absorption of the panels, and should help improve overall bass response in the room.
Placing the Corner Traps in the upper corners and along the ceiling line as possible can help control the low frequency build up, which should help smooth out the overall bass response in the room.
The Wave6 System is to be suspended from the ceiling above the first reflection point. It can help redirect the first reflections from your speakers into the treatment above.
Consider floating your studio monitors on our ProPAD Monitor Isolators. The ProPADs decouple your monitors from the surface on which they are resting. This can help eliminate sound transmission and resonance through the surface, which can help prevent discoloration and improve the clarity and accuracy of your mixes.
Finally, consider floating your subwoofer on our SubDude HD. The SubDude decouples your subwoofer from the surface on which they are resting. This can help eliminate sound transmission and resonance through the surface, which can help prevent discoloration and improve the clarity and accuracy of your subwoofer.
Once again, thank you for choosing Auralex. I hope this has proven helpful. Please feel free to contact me with any additional questions or concerns.
Best regards,
Gregory Bacon
Application Specialist
Auralex® Acoustics, Inc.
9955 Westpoint Drive, Suite 101
Indianapolis, IN 46256
317-842-2600 | 1-800-959-3343
[email protected] | www.auralex.com
Follow us on: Facebook | Twitter | YouTube
Μιχαλη καλοριζικο το HC. Ωραιος χωρος μα μικρος για αυτα που θελεις να χωρεσεις μεσα. Οι παλλομενοι τοιχοι λειτουργουν σαν μεγαλη μπασοπαγιδα. Τη λυση στη προτεινε ο Σωτηρης κανε τους ακαμπτους!
TERMATOGAZI
Bass!
ευχαριστω Στελιο.
αυτο που λες ισχυει ,κυριως απο 40hz και πανω. βεβαια εχει και το καλο οτι δεν μπουμαρει ο χωρος με τιποτα.
θα δοκιμασω και με κατι δυνατο απο 40hz και πανω(jbl 4645c ή tcsounds 5400) , θα κανω και τις διορθωσεις με auralex και θα δουμε.
Απάντηση: Re: Home Cinema στο "TERMATOGAZI"!
ευχαριστω Στελιο.
μιχαλη δεν διαβασα τι σου προτεινη η auralex αλλα δεν χρειαζεται τιποτα κατω απο τα 500hz.
καμια μετρηση πηρες;
TERMATOGAZI
Bass!
Re: Απάντηση: Re: Home Cinema στο "TERMATOGAZI"!
προτεινει αποσβεστηρες στους τοιχους, διαχυτες στο ταβανι και μπασοπαγιδες στις γωνιες.
μετρηση θα παρω το ΣΚ και θα προσπαθησω να παιξω με την θεση του sub.
Απάντηση: Re: Απάντηση: Re: Home Cinema στο "TERMATOGAZI"!
περιμενουμε τι μετηρηση αλλα οι μπασοπαγιδες μαλλον ειναι αχρηστες στο συγκεκριμενο χωρο.
τα υπολοιπα ενταξει.
τους ειπες οτι οι τοιχοι ειναι ξυλινοι η μονο διαστασεις;
TERMATOGAZI
Bass!
Re: Απάντηση: Re: Απάντηση: Re: Home Cinema στο "TERMATOGAZI"!
ναι, ξερουν οτι ειναι ξυλινοι , τους εστειλα και πολλες φωτογραφιες.
Απάντηση: Re: Απάντηση: Re: Απάντηση: Re: Home Cinema στο "TERMATOGAZI"!
καλα κανε μια μετρηση να δουμε.
δεν μπορει να λενε ψεματα για να πουλησουν.
ισως κανω εγω λαθος.
Nickk
