Απάντηση: Re: Θα μας πεις μια ιστορία??
Κάπου εκεί μέσα το παλουκάρι λέει οτι κάποια διαδικασία του ταχέως κορυφωνόμενου ρεύματος λαμβάνει χώρα 120 φορές το δευτερόλεπτο μέσα στους av ενισχυτές.Στον πλανήτη του μάλλον η συχνότητα του ρεύματος θα είναι 120hz. Δεν εξηγείται αλλιώς.
φαγωθηκες βρε νικκ
οριστε...
The Shunyata Research DTCD Analyzer is the first and only power analyzer designed specifically to measure the differences between AC power cables, wires and connections. Previously published DTCD measurements revealed dramatic peak-current and voltage delivery advantages when substituting a quality 12-gauge power cord (Shunyata's Venom-3) for any stock power cord. Some might assume these differences are related only to the wire gauge. Years of testing at Shunyata Research have confirmed that wire gauge influences measured performance, but is far from the only design parameter that affects impulse current delivery to AV, Recording and Mastering systems. The tests that follow illustrate just some of the many parameters that affect power cord performance.
Some observers may be surprised or confounded by the following graphs, which show that wire gauge is far from the only contributing factor in achieving optimal impulse current delivery between the wall and AV components.
http://www.shunyata.com/Content/DTCD-meas.html
για πες μου ΕΣΥ (οχι οι γνωστοι...) τωρα εισαι οκ?
