Νκορίασις......πως λέμε ψωρίασις.
Y
Yiannis_B
Απάντηση: Νκορίασις......πως λέμε ψωρίασις.
What do numbers really mean and do high amplifier damping factors have a noticeable effect on performance?
http://www.butleraudio.com/damping1.php
CONCLUSIONS
It should be obvious at this point that the quoted damping factor of an amplifier is important only if the figure lies somewhere below 20 or so. Changing the damping factor from 2 to 20 does change the performance of the loudspeaker system (for better or for worse, depending upon the speaker). But trying to prove that a damping factor of 200 or even more is somehow better than one of 20 is pretty unconvincing because the effective difference in the practical case cited is only that between 1.25 and 1.32.
But someone is bound to insist that exhaustive tests have been made with such and such amplifier and that a very high damping factor is better than one down around 10 or 15. "The bass is just a little cleaner, just a little more natural and open" is the way the argument usually runs.
In a given situation, this may very well be true. R[SUB]s[/SUB] is a byproduct of negative feedback. The more such feedback that is thrown into a power amplifier circuit, the lower the generator impedance and the higher the damping factor. The point is simply that if a lot of feedback has to be used to lick the distortion in a particular circuit, fine - use it. But don't believe that the reason it sounds good because of some astronomically high damping factor.
When I get a letter from someone who is worried about buying a certain amplifier because it has a specified damping factor of "only" 15 to 16, I can't help but remember an old, old joke. It goes like this:
A scientist is giving a public lecture. During the course of his speech, he predicts that in 100 billion years human life will become extinct.
A man in the audience, obviously upset, asks the lecturer to repeat the statement.
"I said", quotes the professor, "that in one hundred billion years, human life will no longer exist."
"Oh, thank goodness", replies the man, much relieved, "I thought you said one-hundred million!".
Manos58
εγχειρισμένη
Βρε Γιάννη,
ποιός χρησιμοποιεί καλώδιο ηχείων 0,25Ω σήμερα ;
Και γι αυτό κάποιοι φωνάζουν πως καλό καλώδιο είναι το μη καλώδιο .
Αντε Παπακωστα ξεκινα την λειτουργεια............η ωρα περασε και οι πιστοι θα φυγουν!!:smoke:
Y
Yiannis_B
Βρε Γιάννη,
Το θέμα που θα έπρεπε να αποσαφηνίσουμε είναι αν η κότα έκανε το αυγό η το αυγό την κότα.
Η χαμηλή αντίσταση εξόδου είναι παρά-προϊόν της μεγάλης αρνητικής ανάδρασης.
Το ερώτημα είναι αν οι nCore παρουσιάζουν τα συγκεκριμένα ηχητικά χαρακτηριστικά
-γιατί είναι μια επιτυχημένη σχεδίαση (με μεγάλη αρνητική ανάδραση)
, ή
-αν έχει σχέση η ηχητική υπογραφή με το μεγάλο DF.
Είμαι της πρώτης άποψης.
Y
Yiannis_B
Το μέγεθος του DF δείχνει μόνο το μέγεθος της αρνητικής ανάδρασης.
Με βάση αυτό θα ψωνίζετε από δω και περά?
Από ένα σημείο και μετά είναι χαρακτηριστικό ΣΧΕΔΙΑΣΗΣ και όχι ποιοτικό χαρακτηριστικό.
Manos58
εγχειρισμένη
Μιά καλή σχεδίαση δεν περιμένεις να έχει ποιοτικά χαρακτηριστικά ;
Η και το ανάποδο ;Ποιοτικά χαρακτηριστικά δεν υποδηλώνουν άρτια σχεδίαση ;
Manos58
εγχειρισμένη
Αντώνη μου η πίστη είναι ..............σαν τα αντισώματα.
Άμα εγκατασταθεί δεν φεύγει με τίποτα.:wink:
Y
Yiannis_B
Ούτε την λέξη καλή ούτε την λέξη άρτια έχει ως επίθετο η ΣΧΕΔΙΑΣΗ στην πρόταση μου.
Αν σου έλεγαν ότι ένας ενισχυτής έχει πολύ μεγάλη αρνητική ανάδραση (και αρα μεγαλο DF), αυτό είναι ποιοτικό χαρακτηριστικό?
(DF< 50 μπορει και να ειναι ποιοτικο χαρακτηριστικο)
gonis
Luger
Προβλεπω ξενυχτι αποψε...
Οπως εγραψε και καποιος παλαιοτερα,
το μαρς ποιος θα το πει;
Manos58
εγχειρισμένη
Μην παίζουμε με τις λέξεις τώρα.
, ή
Re: Απάντηση: Νκορίασις......πως λέμε ψωρίασις.
Βρε Γιάννη,
Εγώ πάντως χρησιμοποιώ ακόμα κασέτα!!!
Καταραμένο facebook.....
Manos58
εγχειρισμένη
Δεν υπάρχει λόγος ξενυχτιού .
Δεν έχουμε να μοιράσουμε τίποτα,ούτε ο Ολλανδός δίνει μίζες στα παπαγαλάκια του .
Τελικά όλοι το ίδιο επιζητούμε.Την καλύτερη δυνατή αναπαραγωγή μουσικής.(μισή αλήθεια είναι αυτό)
Απλά παίρνουμε άλλα μονοπάτια και διαφωνούμε ποιανού είναι το γρηγορότερο προς την κορυφή .
Y
Yiannis_B
, ή
Είναι μια επιτυχημένη σχεδίαση με μεγάλη αρνητική ανάδραση.
Διαστρέφεις την λογική της κόκκινης πρότασης.
Μπορεί η επιτυχία της σχεδίασης να οφείλεται στην επιτυχημένη αρνητική ανάδραση, αλλά πουθενά δεν λέω ότι είναι επιτυχημένη σχεδίαση εξαιτίας της αρνητικής ανάδρασης.
Ημίθεος
, ή
Η ηχητική υπογραφή -όπως τη λες- έχει πάντοτε σχέση με το μεγάλο DF.
Manos58
εγχειρισμένη
Αν σου έλεγαν ότι ένας ενισχυτής έχει πολύ μεγάλη αρνητική ανάδραση, αυτό είναι ποιοτικό χαρακτηριστικό?
Ποσοτικό είναι.
Και η μεγάλη τροφοδοσία.
Και το PSRR
Και ένα σωρό άλλες παράμετροι.
Για να το πούμε λαϊκά...
Άμα μιά κούρσα έχει πάνω της όλα τα σύγχρονα καλούδια της τεχνολογίας και πoιοτικά υλικά δεν είναι λογικά αναμενόμενο να πατάει και καλά στο δρόμο ;
Σε όλους τους κλάδους της τεχνολογίας δεν ισχύει το ίδιο ;
COSTOPOULOS NIKOLAS
