Νκορίασις......πως λέμε ψωρίασις.
Y
Yiannis_B
Απάντηση: Νκορίασις......πως λέμε ψωρίασις.
Απλα αντιλαμβανεται οτι flat δεν μπορουμε να βαφτιζουμε οτι ειναι φτηνο και συνοδευεται απο pdf.
Manos58
εγχειρισμένη
Δλδ , αν ήσουν θιασώτης των καλωδίων , τι θα έγραφες?
οτι έχουν βαθύ χαμηλό,μεταξένιες μεσαίες με άρωμα λεμονανθού και αέρινα πρίμα σαν παρθένα μουλάτα στο καρναβάλι του Ριο.
Και διάφορες άλλες μ@λ@κίες που λέγονται συνήθως .
Manos58
εγχειρισμένη
Are you talking to me ?
Y
Yiannis_B
Δεν σας κανει εντυπωση, που ακομη και πιο straightforward κατασκευαστες οπως η W4S, κανουν τετοιες δηλωσεις:
The wire we use in the mono's cost us much more than the stereos. As some of you may know, the TcX wire along with the silver wire we parallel it with is not very cheap to say the least. Also, we priced the stereo units much more attractively, which really put a damper on the profit margin, so we had to cut certain items out.-EJ Sarmento
http://www.avsforum.com/t/1005943/official-wyred-4-sound-amp-thread/360
Manufacturer's reply: One thing I noticed is that the unit you were shipped was the STP-SE model. It's an upgraded version with Kimber Tcss wire for the input/output wiring and better caps in the 2nd filtering stage (the 4 x 22,000uf caps). In the stock version, we use ribbon cables instead of the Kimber and all the same 22,000uf caps (as the 3 on the side of the board you had). We normally leave this as a customer option, call it the SE version and charge an additional $200. I think the easiest way to solve this is to change what I have on the site to STP-SE. If you could change what you have in the same manner and raise the price to $1999 so we're comparing apples to apples, that would be great. I'm sorry for the extra work as I know what it's like much more than others but I don't want to mislead anyone in their purchase. Do you think that this would be the correct way around it; or do you feel that it would be worth having two different versions just $200 apart? I just don't see that anyone would purchase the cheaper version if they could get a better one for just $200 more? The improvements were subtle but nonetheless real. - EJ Sarmento
http://www.6moons.com/audioreviews/wyred2/preamp_3.html
Αντε να δουμε και τον Bruno να διαφημιζει την εσωτερικη καλωδιωση.......:biggrin:
Manos58
εγχειρισμένη
Ναι βρε, που θες να μαθεις να ακους και flat. :roflmao:
Το φλατ είναι από τους χειρότερους ήχους .
Το έχουν εξηγήσει πολλές φορές εδώ μέσα .
Ενισχυτή που να μην βάζει τα δικά του "χρώματα" έψαχνα.
Το μουσικό περιεχόμενο είναι από μόνο του πολύ πλούσιο σε "χρώματα".
Η εκτίμηση μου είναι οτι τα Χιτάτσια το αναδεικνύουν και τα Belden το θάβουν .Πάντα αναφέρομαι σε αυτά σαν "σωστό,αχρωμάτιστο καλώδιο":wink:
Y
Yiannis_B
Υπαρχουν ενισχυτες που βαζουν τα δικα τους χρωματα, και ενισχυτες που βαζουν τον δικο τους κορεσμο χρωματων...αντιλαμβανεσαι την διαφορα?
Alas, the STP is far from just another preamplifier. Like the Esoteric and SMc Audio units, it belongs to that still quite rare but supremely promising category one might rightfully call activated passives. Such designs very deliberately combine two apparently opposing religions: the ultra resolution of traditional 'look ma, no power cord' passives; and the tone color depth, drive and dynamics of the best 'plugged in' active circuits. In fact, plugged in very much describes the intensity of energy transmission at work here. It's a function of speed and color. Usually 'fast' and 'saturated' are core qualities with a number of associated attributes which conflict. They tend to refuse to go hand in hand. The audiophile becomes perennially involved with strategically voicing between components for just the right overall balance. Tone versus speed. Transparency versus density. Here the ideal balance seems built in. It's really quite the wicked combination. It might have you question valves in low-level circuits - not valves per se but the need for them.
This is perhaps most noticeable in the midrange where transistors may not be anticipated to fully shine. Whoever claims that transistors only color with half the crayons in the box has never met the Wyred. Its general gestalt very much lays the music at your feet or in your lap. The performers do not require being sought after way back there behind the speakers. And this is not a function of forward perspective. It's the the power of projection instead, exactly what a prized orator does who, even when burdened with having to deliver a technically challenging and otherwise terribly odious lecture, has your attention by the shorthairs. A lesser presenter's personal aura does not extend remotely that far. Such a speaker has anyone outside of his reach fall asleep or at the very least adrift in the mind. Then lectures turn abstract. In the audiophile equivalent, music turns to remote viewing. But not here!
Μερικοι θα γελασουν, αλλα βρισκω σε αυτα τα κειμενα μια συνδεση με την εμπειρια μου.
Και με αυτά θα ταϊσεις τα ncore?
Manosmathiou
