Νέος δίσκος-τεστ από την Ortofon.
Σημ.
Dertonarm (Dietrich Breakmayer of Acoustical Systems)
John Gordon (Odyssey Tonearms)
Geoch (εγω)
john_gordon
04-10-2011 9:51pm
Geoch
As Dertonarm has avoided the issue yet again, (he only seems to respond to posts on which he feels he can appear to be right) and (if your question was genuine and not to provoke) perhaps I can help.
You said
I have a question for you (and it is a genuine one, due to my ignorance) :
The Talea, Schroeder, Clearaudio Satisfy are designed with adjustable arc on their rudimentary headshell. The Simon Yorke has circular headshell which does not shows any preference in cartridge angle. Moreover, there are some circular cartridge bodies also! How does the Newton's law applies there?
Newton (the famous hifi enthusiast), said that to all forces there is an equal and opposite reaction.Bear with me if you are familiar with the following, but I will say it for those that are not.
The friction of the stylus against the moving groove causes a force which is aligned along the groove and reacts against the arm mount. The resultant would pull the arm inwards and out of the groove, were it not for a force reacting against it, so a counter force needs to be applied in some fashion. VTF supplies some of this force and the remainder usually as an antiskate device of some sort near the pivot.
As you correctly state, Geoch, this force has to increase as the arm approaches the centre, because, while the overhang is constant, the radius decreases, therefore the inward force varies in proportion.
All good arms have antiskate/bias, adjustable in amount and in degree. Longer arms need less antiskate, as they have less overhang. (There are arms with zero or negative overhang (underhang). These have very small skating forces, but, unless fitted with a mechanism to maintain the cartridge parallel to the groove, will have large tracking errors.)
Whether a cartridge is cylindrical, cuboid, flower-shaped or whatever, is neither here nor there. It does not affect antiskate if correctly mounted.
The bottom line is that there is only a vector towards the pivot from the stylus, and a vector from the stylus along the groove, These result in an inward rotation of the arm.
It has nothing to do with cartridge offset angles, except inasmuch as the stylus contributes more or less to the frictional force along the groove, (eg elliptical versus conical) and certainly nothing to do with the cartridge body shape. I could explain further, but for now that is enough.
So, the question of round headshells, rotating headshells is all baloney in terms of antiskate. The arms DT mentions may well not have a specified offset and therefore provide a facility for adjusting whatever offset is desired, which is a good thing (although the way they do it doesn't look as smart to me as he seems to see it, as none of them apply the rotation at or around the stylus where it would be most useful (and where, should I ever (no! no!) design another tonearm, put it - (there's a hint for DT if he's designing an arm...god forbid)
Other stuff:
About weird shaped cartridges (in my opinion the result of designers /stylists who have more interest in being different, than in good, practical functional design)
Dert says
they avoid a pre-determined offset angle and thus are much easier to adapt to different alignments (calculations) without trade-offs due to the alternation of a "pre-determined" offset angle by a cartridge's body aligned in a different angle.
Well, he would say that, given his commitment to arc protractors: the more weird shapes there are, the harder it is to align using anything else. Cartridge manufacturers must be rubbing their hands at the prospect of being able to mount generators and cantilevers any old way...
Dertonarm says
Circular bodies further reduce the problem,which problem? he doesn't say, for it isn't antiskate.
but - unless they follow the Ikeda or DECCA/London cantilever-less principle - there is still the line of the cantilever which should be in line with the offset angle.
I hope every reader out there (with a Decca (or otherwise)) sees this error for what it is.
The Decca does not have a cantilever in the accepted sense, but has the equivalent nevertheless - the armature - it is just not visible. So it must be aligned like any other cartridge. If it wasn't cantilevered one could mount it reversed - try that with your client's Decca, Dertonarm, and you'll probably get a slap round the ear for being so stupid...
Also when we talk about cartridge offset angle, that term is usually accepted as encompassing the generator, cantilever and stylus, which ideally should all be in line. Errors here are an issue for cartridge designers and manufacturers. By all means line up to a cantilever, but that doesn't mean either the generator or stylus are lined up with the cantilever.
Geoch, Dertonarm shows his ignorance and arrogance by his response to you. Instead of explaining something he asks you for your ideas, perhaps because he is not truly clear in his thinking, as in the case of SME arms.
I realise your wisdom in avoiding getting too involved, but avoidance of bullying, for that is what it is, can lead to unwanted and unpleasant consequences, both here, in a small way, and, in the greater world, in a big way.
john_gordon
04-12-2011 5:22am
Perhaps it might be a good idea to go back to basics. There are two aspects to this issue. One is to acknowledge what the force is and how it originates. Second to see how it manifests itself on a record deck.
While we might call it antiskate, or bias, or whatever, the force which pulls the arm inwards is not specific to tonearms. It can apply in any situation where there are two forces opposing each other.
To illustrate the simple example of a linear tracker. (Those of you with linear trackers can start practising your smug grin.)
Say you hold one end of a short rope. You are the Tonearm bearing. You put a conical blob of blutak in the middle of the rope - the Stylus. Your wife holds the other rope end. She is Friction.
Friction acts on the Stylus by pulling it along the groove in a direction directly opposed to the Tonearm bearing. It reacts by holding on and pulling back. The rope is straight. The Stylus remains unmoving in the middle. As friction moves to the side, Tonearm bearing follows every move (hopefully).
Now a Pivoted arm.
Friction takes a different tack. She pulls at an angle. Tonearm bearing reacts against Friction. It is immovable. It holds on to the Stylus. but the rope wants to straighten, and Stylus will be pulled sideways, unless......
Help arrives. Another pal called VTF, stands on the Stylus. now it's harder for Friction to pull Stylus sideways. Then yet another pal, Antiskate, comes in and pulls the Stylus in a direction which stops the rope straightening, just enough to stop the Stylus moving without pulling it in the opposite direction.....
Ok, this is simplistic, but relevant. First, note that we have no mention of cartridges, only the stylus which is simply the name for a point on our rope. The angle we talk about is the angle formed by a line from pivot to stylus and stylus to groove. Which is not quite the same thing as cartridge offset.
Forget about cartridge offset for the moment and just imagine your arm with no cartridge, just a sewing needle on the end where the stylus would be, and then follow its arc on a record. Follow it beyond the inner groove, beyond the label, beyond the spindle, and out the other side. See how the angle between pivot, needle, and groove changes. Think of the rope story and in what direction the arm will be pulled. The angle changes towards the centre not varying much, but under 7cm radius, the closer to the spindle it gets the greater it becomes, until at 0 it is a right angle..
That is the basis of the antiskate issue. Does it exist as a force. It exists, yes, it definitely does. But why some people prefer no antiskate, that is for them to say. My arms had an antiskate mechanism, using lever and thread, which allowed for varying the force, and the ratio to some extent across the record, or it could be removed completely. But it was not any more sophisticated than that (It could even have been used to apply a reducing force like the Morsiani,though I am not aware anyone ever did, and not a negative antiskate as in their example of the blank disc; I think there's something wrong there.)
It would be possible to design a cam system given different leverages so as better to follow the average variation, though not the instantaneous.
Whether you can adjust for it totally and in every way, I doubt. As there are many other factors involved in the friction calculation. Some people are more sensitive to its effects than others. Personally, I always tried to compensate for it. I was concerned with its effects on imaging, soundstage etc
john_gordon
04-12-2011 5:49pm
I said
The angle changes towards the centre not varying much, but under 7cm radius, the closer to the spindle it gets, the greater it becomes, until at 0 it is a right angle..
What this means is that the inward force trying to rotate the arm stays more or less constant within a few percent reducing slightly following the tracking error curve of the arm (not the tracking distortion curve) which varies across the record. Depending on the overhang used and the arm effective length, at the inner null the force starts to increase rapidly.
So it would appear that the ideal would be to follow this curve, reducing slightly then increasing.
However, it has been shown that there are other factors which increase the friction force as the radius decreases, which would skew this result and make it more likely that the force should at least be constant then increase, or even gradually increase all the way across the record
When I designed my arm that's what I did, as I thought that, like tracking distortion it seemed to be worse towards the inner grooves, and less of an issue further out, and should be weighted that way. But it was all "suck it and see". So, really, a tonearm should perhaps give the user the option of trying different things.
The actual amount of antiskate needed is very much dependent on stylus profile and downforce. With enough downforce the stylus will never meet a modulation large enough for it to lose contact with the outside wall, or even throw it up out of the groove. However there will still be unequal forces on each side of the groove unless there is some kind of compensation.
As Dertonarm says, a longer arm has less skating force than a shorter one.
But it is still there, and it has to be dealt with somehow - you can't just sweep it under the mat....
- αυτό όμως θα ισχύσει εάν δεν υπάρχει εφηρμοσμένη δύναμη αντιολίσθησης , διότι άπαξ και αυτή ρυθμιστεί έστω και στο ελάχιστο , τότε πάντα θα τραβάει τον βραχίωνα προς τα έξω οπότε στο εν λόγω παράδειγμα η κεφαλή θα ''προσδισκωθεί'' μερικά αυλάκια προς τα έξω . . . εννοείται μιλάω για ακτινικούς ( όχι unipivot ) , άρτια οριζοντιωμένα συστήματα , και μηδενικές τριβές στο pivot
Νομιζω πως οταν διακοπει η επαφη της ακιδας με την επιφανεια τριβης, τοτε ο βραχιονας βλεπει το αντισκεϊτινγκ ως μεταβολη του βαρους αναγνωσης η οποια δεν ειναι ικανη δυναμη για να τον μετακινησει.
Τουλαχιστον δεν μου ειχε συμβει ποτε.
Αυτό που λές είναι αδύνατον μια που οι δύο δυνάμεις είναι κάθετες μεταξύ τους . Η δύναμη του ant συνεχίζει να εφαρμόζεται και αν σηκωσεις τον βραχίονα . Ο λόγος που δε γυρίζει ο βραχίονας πρός τα έξω είναι γιατί υπάρχει τριβή μεταξύ του σημείου του βραχίονα που ακουμπά στο σύστημα ανήψωσης και συστήματος ανήψωσης . Μάλιστα αρκετές εταιρείες ( πχ technics αν προσέξεις στο σύστημα ανήψωσης έχουν ένα επιμήκες ελαστικό για να εξασφαλήσουν ότι η τριβή είναι αρκετή ώστε η δύναμη από ant να μη κουνήσει το βραχίονα όταν σηκώνεται . Και για να στο επιβεβαιώσω κάνε πολύ απλά το εξής : βάλε στο σύστημα ανήψωσης ένα πολύ λείο υλικό κάτω ακριβώς από εκεί που θα πατήσει το σημείο του βραχίονα και θα δείς μόλις το σύστημα ανηψωθεί ο βραχίονας τραβιέται εμφανέστατα προς τα έξω . Στο MK2 οδηγει μέχρι στη αρχική θέση λόγο της πραγματικά σχεδόν σημειακής επαφής του βραχίονα με το μηχανισμό ανήψωσης ( αρκεί να βάλεις ένα μικρό κοματι από το κάτω μέρος ενός CD κάτω από το σημείο στήριξης για να μειώσεις τη τριβή ) . Τα CD αποδεικνύονται πολύ χρήσιμα ........ εκτός από το να τα ακούμε .
Μπα, ούτε αυτή τη χρησιμότητα δε την έχουν (εδώ και χρόνια)
Για να διώχνουν τα περιστέρια είναι χρήσιμα! :D
Για να διώχνουν τα περιστέρια είναι χρήσιμα![/QUOTE
Όντως έχω γεμίσει το τόπο εδώ ( αλλά τα ................ είναι και έξυπνα )
[DOUBLEPOST=1488924651][/DOUBLEPOST]
Και κλασική απάντηση EAR !!!!!!!!
Πριν 2 αυτοκίνητα, ήταν χρήσιμα τα cd μόνο στο αυτοκίνητο, στο CD player.
Στα τελευταία 2 αυτοκίνητα, από USB stick και φλακ παίζει το ρημαδι το μαμά στέρεο. Ποια CD μωρέ; Ψόφησαν, τα θαψαν κιόλας.
Ζήτω το streaming. ;)
(Για το βινύλιο τα είπα, να μην επαναλαμβανόμαστε..)
Εκεί ακριβώς πάει το πράγμα . Απλά αναλόγως διάθεσης θές να δείς την κατσαρόλα να γυρίζει και τον διώκτη πουλιών να στροβιλίζεται ( βλέποντας από το πάνω τζαμάκι το μπλέ φωτισμό .... super mods) ......... σε φτιάχνει λίγο καμιά φορά . Άλλη φορά σου ανασύρουν και καμιά καλή στιγμή ...... ( τις κακιές τις έχουμε γραμμένες .... ) . Και όπως έχουμε ξαναπεί < όπως τη βρίσκουμε > καλά νάμαστε να λέμε και κανά δυο τεχνικά μπάς και το πάμε και λίγο παραπέρα .... ( δεν θα τρελαθούμε όμως κιόλας ... ) !!!!!!!!!
Παιδια φευγω για δουλεια. Στα γρηγορα να πω τα εξης :
Ολοι εχουμε δει να πωλουνται κεφαλες με την περιγραφη "Bended Cantilever"
Αυτο οφειλεται στην χρονια λαθος ρυθμιση του αντισκεϊτινγκ.
Η μετατοπιση του στελεχους απο τον αξονα του (συμφωνα με τον οποιο ευθυγραμμιζεται με την γεννητρια), διορθωνεται μολις ο βραχιονας σηκωθει. Κι επειδη (υπαρχει προβλεψη) δεν γλυστραει οσο κρατιεται στο συστημα στηριξης, η μονη σημειακη μεταβολη της ακιδας, (οταν ξαναπεσει στην επιφανεια του δισκου) ειναι η διαφορα του αντισκεϊτινγκ που πρεπει να μεταβαλλουμε, ωστε να μην τραβιεται το στελεχος.
Δηλ. η δυναμη ναι μεν ασκειται παντα, ομως δεν ειναι αρκετη να μετακινησει τον βραχιονα οσο κρατειται λογω της ελαστικης επιφανειας στηριξης. Αυτο ειναι που εκμεταλλευομαστε!
Φευγω τωρα.
- έχω κάνει το εξής : ''πειράζοντας'' την κρεμάλα , το νήμα απ΄ όπου κρέμεται το βαρίδι του antskating σχηματίζει ορθή γωνία με τον βραχίονα ( βλέποντάς το κατοπτικά ) στην αρχή του δίσκου , έτσι ασκεί την μέγιστη δύναμη , προχωρώντας όμως προς το κέντρο του δίσκου όπου μειώνεται σταδιακά η γραμμική ταχύτητα άρα και η ανάγκη εφηρμοσμένης δύναμης antskating , η γωνία αυτή γίνεται οξεία ( ή αμβλεία ανάλογα όπως το βλέπει κανείς ) οπότε εφαρμόζεται σταδιακά μειούμενη δύναμη antskating το οποίο είναι και το επιθυμητό
Όχι παιδιά δεν είναι έτσι
Η σχέση της υψηλής γραμμικής ταχύτητας/αραιογραμμένης πληροφορίας στην περιφέρεια του δίσκου με αυτήν της χαμηλής γραμμικής ταχύτητας/πυκνογραμμένης πληροφορίας στο εσωτερικό του μας δίνει την ίδια τιμή τριβής.
Το μέγεθος που μεταβάλλεται κατά την διάρκεια της αναπαραγωγής του βινυλίου, που με την σειρά του μεταβάλλει την δύναμη της ολίσθησης, είναι η απόσταση της ακίδας μας από το κέντρο του δίσκου.
Σχεδόν όλες οι τεχνικές εφαρμογής αντιολίσθησης έχουν λάβει υπόψιν τους αυτήν την παράμετρο και εφαρμόζουν τεχνικές προοδευτικής εφαρμογής της.
Mr Spock
demokratischer - sektor
- πως όμως ; . . . στο δικό μου πχ με βαρίδι αναρτημένο σε νήμα , δεν αντιλαμβάνομαι τέτοια προοδευτικότητα ( πέραν της πατέντας που εφαρμόζω )
Οι εφαρμογές με ελατήριο ή μαγνήτες είναι προοδευτικοί.
Εχω δει και με νήμα κάποια πατέντα της origin live σε rega, αλλά γενικά αυτοί με το νήμα δεν νομίζω
Mr Spock
- εκεί ναι , συμφωνώ
- επίσης οι vpi έχουν επίσης μία πατέντα εφαρμογής antiskating με προοδευτική συστροφή του καλωδίου μεταφοράς σήματος . . .
Πολύ σωστά γι αυτό και οι τιμές στη ρύθμιση του ant είναι < σχετικές - ενδεικτικές > με το βάρος ανάγνωσης και όχι < απόλυτες - > . Πχ το 2 στο ant είναι η προτεινόμενη θέση του κατασκευαστή για χρήση " βάρους " που αντιστοιχεί σε 2 γρ . και σε συγκεκριμένη θέση στο δίσκο ( μερικοί κατασκευαστές μάλιστα δεν κρίνουν σκόπιμο ούτε καν να έχουν ενδείξεις ) .
Mr Spock
Vpi anti skate
Για το συστραμμένο καλώδιο δεν το γνωρίζω.
- αυτό είναι optional antiscating που συνεργάζεται με το συστραμένο καλώδιο . . .
VPI has a unique solution to anti-skating: the coiled wire of the JMW Memorial Tonearm acts as a spring and pushes the arm back without affecting the sound quality. The VPI JMW-9 Tonearm Anti-Skate Upgrade now gives you the option of a mechanical anti-skate device!
http://www.elusivedisc.com/VPI-Anti-Skate-Device-for-JMW-9-Tonearms/productinfo/VPI-D1013/
Προς τις εσωτερικές σπείρες, αν παρατηρήσεις προσεκτικά, μεταβάλλεται προοδευτικά (μικραίνει) η κάθετη απόσταση του σημείου κρέμασης του βαριδίου από το βραχίονα. Επομένως μικραίνει αντιστοίχως προοδευτικά και η ασκούμενη στο βραχίονα ροπή αντι-ολίσθησης (βάρος x απόσταση).
rikos1316
