High end ολοκληρωμένος
A
AKARL
Ρηβγιούερζ και ρηβγιούζ μ@λ@κί@ς το ανάγνωζμα πρόσχωμεν - Part Deux!
Karan Acoustics KA I180 Mk2
Mμιλάμε για μηχανάκι που κοστίζει καμμιά 15αριά αβουγουδού!
Just a glance at the front panel of the Karan KA I 180Mk2 will show that it’s been designed as a true ‘audiophile’ amplifier, because there are no tone controls, no loudness contour buttons, no speaker selectors, no record output selectors… there’s not even a headphone socket or a power on/off switch.
The amplifier is so ‘audiophile’ that these controls aren’t even labelled!
The second is that the Karan does not have a ‘Standby’ power mode, so it will always be ‘ON’ if you don’t switch it off, drawing 35 watts continuously from your mains power supply. This is apprently exactly as Milan Karan intended, because according to Radiance AudioVisual, Karan’s Australian distributor, ‘Karan designed the amplifiers to be ‘always on’ as this provides the best possible sonic performance. Milan believes that his amps need at least 48 hours of standby before they really sing.’
The volume control on the right of the front panel has a smooth action and what appears to be a LED inset into it. However, no matter what I did, I couldn’t get the LED to glow, so figured it was either not a LED at all, or it was not connected, or it was a LED and it was connected, but it didn’t work. All this guesswork was entirely wrong. It turns out that what I though was a LED is actually a cubic zirconia, which is intended to reflect light from within the room to allow easy identification of the rotational position of the control from any distance.
In fact the tactile ‘feel’ and feedback you get when operating the volume control is fantastic.
Speaking of the remote, it is very strange! Firstly, perhaps taking its design cues from Denmark, it’s circular, rather than rectangular. Second, it has only two buttons: Volume Up and Volume Down. In other words, you can’t use it to select input source, nor is there a ‘Mute’ function
I was pleased to find that either Karan or its Australian distributor had fitted good-quality alkaline batteries
All the connectors on the rear of the Karana KA I 180 Mk2 are gold-plated
Karan doesn’t want you to remove the lid on its amplifiers, because there are dangerous voltages inside, yet the company realises that many people will be curious about a hand-made amplifier, so it has included in the Owners’ Manual a very large photograph showing the inside of the amplifier with the caption: ‘This is your amplifier inside please don’t open.’
It also has that unique—as in ‘how does he do it?’—Class-A sound without Class-A inefficiency. (ΜΠΡΑΒΟ, ΕΥΓΕ!!!)
ΔΗΛΑΔΗ:
the Karan needed to consume more than a kilowatt from the 240V mains supply for the amplifier to be able to deliver such high power output levels.
(180 ολόκληρα βατ! :eek::eek::eek:) If you look at the power consumption figures you can see that the Karan KA I 180 Mk2 is fairly power-hungry no matter how you’re using it, and as it has no standby mode you should probably switch it off whenever you’re not using it.
Mains power consumption was very high, with the Karan needing to consume more than 100-watts from the 240V mains to deliver just one watt to the loudspeakers, and more than one thousand watts (1kW!) to deliver its rated output at 8Ω (180-watts). ΔΗΛΑΔΗ Class-A sound without Class-A inefficiency.!!!
Οπότε λογικό επόμενο είναι:
Because of this, I’d suggest considering installing a dedicated power-point exclusively for use by the KA I 180 Mk2 in order to ensure you can extract the best performance from this powerful, extremely wide-band amplifier. :rofl::rofl::rofl:
Look closely and you’ll see audiophile-approved names like Vishay and WBT in place of the standard fare. This not only adds to the cost of the product, but seriously ups the performance, as we’ll see.’
Also, the high-quality goldplated speaker terminals have no insulating shroud, so that if you use bare-wire connections, rather than pins or spades, you will need to make very certain that no stray bits of wire come into contact with each other, or with the chassis. :headbang:
the amplifier is ‘not recommended for loads less than 3Ω’ so you should take heed of this very specific recommendation also.
The sound quality of the Karan also reveals that it’s been designed by someone who really cares about sound, because it manages to combine the raw power of solidstate with the rich warmth of valves, so you get the best of both worlds: impressive dynamics and superb musicality.
the KA I 180 Mk2 easily met its specification into 8Ω loads, returning test result figures of 223-watts (23.4dBw) per channel at 20Hz
when driven into 4Ω loads, the Karan fell a little shy of specification, returning figures of 222-watts (23.4dBw) per channel at 20Hz :gotcha:
Δε διπλασιάζει, νταξ μωρέ δεν τρέχει και τίποτα, αλλά αυτός ο, στερεοκαταστασιακός θυμίζω, ενισχυτής μειώνει την ισχύ στα 4 Ω!!! :lol::lol::cry::cry::rofl::rofl::rofl:
Τελικά, έχοντας δγιαβάσει το ρηβγιού, πιστεύω ότι πρόκειται περί εξαιρετικού VFM ενισχυτή, που δικαιολογεί και το τελεφταίο (το 15ο ντε) αβουγουδού που ζητάει και παίζ΄ και πολύ παν απ΄ τα λ7 του!
dapost
Rehdeko & Harbeth lover
Εγώ είμαι απλός άνθρωπος.. :p
Ξέρουμε, βλέπεις βυζί, πατάς λάικ.
[DOUBLEPOST=1520854661][/DOUBLEPOST]Να γράψω και εγώ την π@π@ρι@ μου;
Η καλή η παραμόρφωση, η μουσική, χωρίς γρέζι, γενικά πληρώνεται ακριβά. Δείτε π.χ. πόσα σκάνε οι ηχολήπτες για ένα μυθικό μικρόφωνο για να βγάλουν μεταξένια τη φωνή της τραγουδίστριας:
https://www.sweetwater.com/store/detail/C800G--sony-c-800g-large-diaphragm-condenser-microphone
Απλά αυτοί ξέρουν ότι πληρώνουν για την καλή την παραμόρφωση. Και μην ακούσω ότι τέτοια καλή παραμόρφωση βγάζει και το dsp γιατί δεν παίζει σας λέω. Όχι ακόμη τουλάχιστον.
Γιατί, έμπορας τους είμαι;
Πες ότι θες , εδώ ο άλλος είπε ότι ο κραουν είναι το τέλος.... Τι άλλο νήμα θα συντονίσω εδώ μέσα θεέ μου...
[DOUBLEPOST=1520851637][/DOUBLEPOST]
Άμα θες pdf και γραφήματα πάρε ncore, άμα θες μουσική πάρε τον Diablo
:drinks::drinks:
Pink Noise RMS power...
Τι είπες τώρα!!! Έχω πέσει και παίρνω κάμψεις μόλις το είδα.
Αυτά που αναφέρει ο Αυστραλός στα χαρακτηριστικά του ενισχυτή του είναι αλλού για αλλού.
"...I was interested to see that Karan rates the power output of the KA I 180 Mk2 in the following way: ‘Pink noise RMS power: 180/300W into 8/4 ohms.’ It’s interesting because this is a measurement technique I have never heard of previously. It could be the industry standard for power measurement in Serbia..."
Και κανένας τους δεν τόλμησε να δημοσιεύσει τετραγωνικούς παλμούς...:sneaky:
Το αντίστροφο : Class A inefficiency without Class-A bias?
Λάμπα με τα όλα της,χωρίς τους...γλόμπους όμως.:laugh:
Εκανα Like στο πρώτο ποστ, και όταν έβαλες το δευτερο με auto merge, αναγκαστικά unlike...καταλαβαίνεις :D
Ένα like είναι αυτό,άστο και ας πέσει χάμω....:D
ναι αλλα ο εαρ που ξερει το αφησε το λαικ.
Εδώ σου άφησαν like και όσοι φάνηκαν να μην το έπιασαν το...υπονοούμενον.;)
Ωραία τα λέει ο Κώστας Ear. Μην τον αποπροσανατολίζεις. Αγαπητέ πως το βλέπεις και το Diablo 300? same shit ή όντως state of art?
μου το ξαναγυρνας το γράψιμο σου....στο παλαιό γνωστό. :(
Για το Diablo 300 εχεις δει specs και γραφήματα? Αν ναι, πως τον βλέπεις?
Κανένα άκρο από τα δύο,καθότι εξακολουθεί ν'αποτελεί συμβατική υλοποίηση...Το state of the Art δεν απονέμεται σε οιαδήποτε συσκευή τυγχάνει να έχει χορταστική απόδοση υπό συγκεκριμένες συνθήκες.:sneaky:
Ιδού και τα...΄΄άπλυτα΄΄ του Diablo:
https://stereo-magazine.com/archive/?tx_archive_pi1[article]=66552&tx_archive_pi1[action]=download&tx_archive_pi1[controller]=Archive&cHash=13be165387aadb836aab7a50a0bd3438
Προσωπικώς θα ζούσα ανετότερα με έναν τέτοιο ολοκληρωμένο ενισχυτή,σε σύγκριση πάντα με τους προηγούμενους δύο.
(Και παρά τη μεδενική ολική ανάδραση,έχει συντελεστή απόσβεσης που τον αποδεσμεύει από τιμές αντίστασης σε καλώδια ηχείων και...πηνιοσύρματα woofer)
Απλά έχουμε πρόβλημα στον εγκέφαλο, δεν είναι τίποτα, όλα καλά :thumbsup:
Σαν τους παππούδες, λέμε τις ίδιες ιστορίες συνέχεια
Σε κάθε λύση αντιστοιχεί κι ένα πρόβλημα...Το συγκεκριμένο έγκειται στο ότι επειδή όλοι οι παράγοντες που μας κάνουν να βρίσκουμε ελκυστική την απόδοση μιας συσκευής κατά την ακρόαση είναι...αμέτρητοι,αναπτύσσεται ασυνείδητα η εντύπωση πως όσοι έχουν μετρηθεί δεν...ακούγονται κι εκείνοι εξίσου.
Όντως, χωρίς. Ούτε γκόμενα δε ρίχνεις.:gotcha:
Βέβαια, το συμπέρασμα είναι δεδομένο:
Και τελικά ο γκρύφωνας είναι όντως καλύτερο τεμάχιο, αλλά δίπλα στον state of the art crown, δε πιάνει ούτε τα 3 του.:lol:
Ear,σου αρέσει να...΄΄πλένεις πιάτα΄΄ στο φαγοπότι της υψηλής πιστότητας.Και πιάτα πλένεις και...ζηλιάρης είσαι.:roflmao:
Που ακριβώς εντοπίζονται τα άπλυτα? Διάβασα το review αλλά δεν εντόπισα κάτι. Εσύ η κάποιος άλλος τι βλέπεις σαν αρνητικό σε αυτόν?
Ο όρος άπλυτα δεν παρατέθηκε νέτος σκέτος...
Πού εντοπίζεται η γλαφυρότητα στην έκφραση και πού η...κυριολεξία;;)
Παραδείγματος χάριν,φράσεις από τις προδιαγραφές στις οδηγίες χρήσης του Diablo 300:
In the interest of ultimate fidelity, tone controls, balance controls and other unnecessary components have been banished from the signal path.
• Sabre ES9018 High-End D/A converter
(και η διχογνωμία αναπαράγεται,είναι τελικώς οι ΄΄Σαύρες΄΄ χαιενδ ή όχι;
• Temperature-compensated, ultra-low jitter crystal oscillator with better than 5 parts per million accuracy
(παρά την αντιστάθμιση στις εναλλαγές θερμοκρασίας,νάτος και ο...κόκκος,5 μέρη εις το εκατομμύριον)
• Super-Capacitor (12.5 Farad!) power supply for USB module - acts like a true battery supply
Επίσης η αντιπαραβολή προς την διακήρυξη περί απουσίας ανάδρασης:
"...All Gryphon designs are realized with an absolute minimum of negative feedback, which when present in large amounts can actually increase TIM distortion. All Gryphon preamplifiers are designed with zero negative feedback. Gryphon power amplifiers apply negative feedback judiciously for improved linearity and bandwidth."
Ας δούμε όμως και τι υποστηρίζεται με κάθε επισημότητα στον πρόλογο:
"...Because the electrical power coming out of your wall fluctuates wildly in terms of voltage and distortion, Gryphon incorporates heavily regulated multi-stage power supplies that act as effective mains conditioning filters. Displays and control circuits are fed by a separate power supply to isolate any digital noise artifacts and effectively prevent them from contaminating the signal path.
Λάμπα κανονική, γλόμπος.
Δε παίζει τίποτα "σωστά", τον κώλο σου κάτω να βαράς..
T
Tadakis
deleted user 10898
Τα άπλυτα στην φόρα το λέει για την φωτό του εσωτερικού του ενισχυτή
Να σας το εξηγήσω λίγο καλύτερα το άνωθεν.
Αν θες να ακούς τη μουσική σου, το βιολί βιολί στην laurie anderson και το τύμπανο τύμπανο στον Bob Marley, πάρε ncore, παίζει σωστά και μετράει και σωστά, παίζει και zz-top καθωσπρέπει, και Moby και kraftwerk.
Άμα θες Χάι εντ με ολίγην από πιστότητα, πάρε κάτι πιο ακριβό, σα το diablo, και το παίζεις και μουσικόφιλος που ψάχνει τις χροιές στην Dianna την krall και στις παρωδίες της sheffield labs αλλά και Linn records και των υπολοίπων χαλιεντοεταιριών..
A
AKARL
Λάμπα με τα όλα της, χωρίς τους...γλόμπους όμως.:laugh:
Βρε σα δεντρέπεστε λίγο, ο καλλιτέχνης είχε συγκεκριμένο όραμα για τη δημιουργία του: it’s been designed by someone who really cares about sound, because it manages to combine the raw power of solidstate with the rich warmth of valves!
Είναι, δε, άξιος συγχαρητηρίων (ο καλλιτέχνης) γιατί πραγμάτωσε το όραμά του: δημιούργησε τρανζιστοράτο ενισχυτή που δε λειτουργεί σε Τάξη Α αλλά καίει ρέβμα ωσάν να λειτουργεί σε Τάξη Α, δεν διαθέτει λυχνίες αλλά συμπεριφέρεται ωσάν να ήταν λυχνιακός σε φορτίο 4Ω! Και όλα αυτά σε μνιά τιμή χώμα!
ΑΞΙΟΣ!
Κορίτσια τρέξτε!
καπχιοι εδω μεσα μου θυμιζουνε τους 2 παπουδες του μαπετ σοου.,,,,,,,,
στο τελος παντα βγαιναν γελασμενοι.......
καθε προιον εχει το κοινο του......οποτε.......καθεις πσωνζει αναλογα με την ορεξη του
Ορθόν αν όχι κι ενδεδειγμένον...;)
Όταν όμως με πρωτοβουλία τρίτων κατατίθενται ορέξεις προς δημόσια κρίση,χρειάζονται και κάποιοι ΄΄παππούδες΄΄ να ξεδιαλέγουν τις...muppe(t)s από το show.:roflmao:
Τι 'ναι το καθος εδω βρε παιδια ? για πειτε να μαθαινωμε και πραμα ...
Το αειπάρθενο κατά τα άλλα σήμα διέρχεται χωρίς κάποια προστατευτική θωράκιση δίπλα και ανάμεσα από απαγορευμένους τόπους,όρα λ.χ. ηλεκτρολυτικούς πυκνωτές κι εστίες θέρμανσης...
Και τί ναι ρε η θωράκιση;Ζώνη αγνότητος ναουμ;;;:thumbsdown:
Πού είναι επίσης η υπεράνω πάσης υποψίας ένωση κατά τις διεπαφές σε πλακέτα και μπόρνες,οεο;
Κάθε παππούς εις το είδος του και ο ημίθεος στις άχαρες αλήθειες επί της δόμησης...
Christos Kourmouzoglou
