Von Schweikert VR-4 SR MKII - The making of a dream speaker
Κώστας Φ.
"I don’t want a simulation, I want reality. When I sit down to listen, I want to hear the real thing, not some weak representation of the music. As with all ardent audiophiles, I want virtual reality, the phrase Von Schweikert audio uses to describe the sound of their VR speakers, and essentially what every audiophile is after. The claim is that the speakers have been designed to follow the recording microphone’s signal in reverse. But does this VR thing result in superior reproduction or is it a slick marketing campaign? That’s what I wanted to find out.
Listening to my favorite pieces was glorious with the 4SR2’s! After several equipment permutations, I have concluded there is virtually nothing that can be done with reasonable equipment to make these speakers sound poor. Conversely, their capacity to improve the listening experience along with equipment upgrades seems virtually unlimited. For the average audiophile, this can be the dream speaker that is never outgrown.
I cannot dream of living without them, so they have become my reference speakers."
Full Review: DAGOGO.com
Αναλυτικά specs:
System Type:
Dynamic-driver four-way system using a triple-chambered transmission line and two-piece stacking enclosure system to eliminate resonance and ensure image focus.
Woofer Tuning:
The triple-chambered transmission line is a hybrid design composed of three separate chambers coupled to the room by a tuned vent at 23 Hz. The chamber filling is acoustic foam and Dacron. The 4"-wide vent tube with 7" flare extends bass response without the "one note bass" problem found in other ported systems. Dynamic range is incredible due to the large amount of low frequency air movement.
Cabinet and Bracing:
A two-inch thick front baffle provides exceptional vibration control and image solidity, while one-inch MDF fiberboard interlocking braces provide exceptional rigidity and freedom from boxy colorations. The internal damping consists of thick acoustic felt and foam lining with Dacron stuffing to eliminate cavity resonances. Large carpet spikes are provided.
Size:
Midrange/Tweeter (14"h x 11"w x 24"d). Woofer (29"h x 11"w x 24"d).
System (44"h x 11"w x 24"d).
Weight:
Woofer module: 97 lbs.
M/T module: 53 lbs.
System: 150 lbs. each.
Driver Complement:
2-8.5" aluminum woofers from Norway, 1-7" carbon Kevlar-cellulose Aerogel midrange driver from France, 1-1.5" silk dual concentric ring tweeter from Denmark, 1-1" rear firing ambience mid/tweeter with fabric dome and transmission-line loading from Denmark. All drivers use our proprietary Advanced Motor System with low distortion design.
Crossover:
Acoustic fourth order, at 190 Hz and 1.9 kHz, optimized for flat off-axis response and phase consistency over a wide Global Axis. Very high quality parts are used from France, Germany, and the U.S., including Hovland film and foil capacitors, Solen film-foil capacitors, Solen perfect lay inductors, film-foil resistors, and Analysis Plus internal wiring.
Binding Posts:
Double sets of five-way rhodium posts enabling bi-wiring. Single wire can be used with optional Data Link connector.
Ambience Driver:
1" treated fabric dome with Wave Guide and transmission-line rear wave loading. Ambience circuit uses Dimensional Control (effects level) to compensate for room acoustics and soundstage depth. Provides a Global Axis polar response pattern to simulate live musical reproduction.
Frequency Response:
20Hz-25 kHz, +/- 3 dB, 18 Hz-40 kHz -6 dB, (+/- 1dB at midband).
Impedance:
6 ohms avg. (4 ohms 20 Hz-150 Hz; 8 ohms 150 Hz-20 kHz).
Recommended Power:
20 watts up to 500 watts
Sensitivity:
92 dB @ 1w/1m using 2.83V.
Warranty:
Ten years Parts and Labor, excluding burned voice coils due to amp clipping. Warranty is transferable to second owner.
MSRP: $12,000/pair
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Von Schweikert VR-4 SR MKII - The making of a dream speaker
Για ρώτα πόσο κάνουν και στο Ελλάντα...
Κώστας Φ.
Έλα βρε, βάλε και το R&D για να βρουν σωστό τρόπο να το μεταφέρουν απο τη μία άκρη του Ατλαντικού στην άλλη. :mrgreen:
ΠΛΕΟΝ ΥΠΑΡΧΕΙ ΝΕΟΣ ΑΝΤΙΠΡΟΣΩΠΟΣ ΚΑΙ ΟΙ ΤΙΜΕΣ ΣΕ ΕΥΡΩ ΕΙΝΑΙ ΑΡΚΕΤΑ ΧΑΜΗΛΟΤΕΡΕΣ ΑΠΟ ΟΤΙ ΣΕ ΔΟΛΛΑΡΙΑ. ΝΕΟΣ ΑΝΤΙΠΡΟΣΩΠΟΣ MUSIC LOVER.
Αντε γεια ....
Κώστας Φ.
Απάντηση: Re: Von Schweikert VR-4 SR MKII - The making of a dream speaker
Αντε γεια ....
Γιώργο, σε πρόλαβα ή έφυγες?! :happy_8:
Τhank you για την ενημέρωση.
Μπορείς να γίνεις πιο συγκεκριμένος?
Αν τυχαίνει να γνωρίζεις την τιμή του ηχείου στη χώρα μας καλό είναι να μας την πεις για να μη μένουμε με την εικόνα που είχαμε για τις εξωφρενικές τιμές του παρελθόντος. :cool_4:
Re: Απάντηση: Re: Von Schweikert VR-4 SR MKII - The making of a dream speaker
Εγώ απλώς σας ενημέρωσα ότι ο αντιπρόσωπος άλλαξε και οι τιμές σε ευρώ είναι χαμηλότερες από αυτές που ξέραμε.
Κώστας Φ.
Απάντηση: Re: Απάντηση: Re: Von Schweikert VR-4 SR MKII - The making of a dream speak
Πολύ καλά έκανες.
Έλεγα μήπως ξέρεις και ακριβώς την τιμή, μπατ ιτς ολράιτ.
Αν κάποιος ενδιαφέρεται μπορεί να κάνει ένα τηλέφωνο στη Music Lover λοιπόν. :happy_4:
Re: Απάντηση: Re: Απάντηση: Re: Von Schweikert VR-4 SR MKII - The making of a dream s
Πολύ καλά έκανες.
Αυτό είναι και το ποιο σωστό. Κάθε διακανονισμός είναι και διαφορετικός, εξαρτάται και από τον τρόπο πληρωμής.
Κώστας Φ.
Summary
It wasn't until the final combination of products came together that the Mk2 became as fast and coherent as electrostatics, as Albert claimed. That is quite an achievement. True, my front end could use some upgrading, but I think I've pointed you in the right direction here. Be clear; this is a Real World loudspeaker that is capable of world-class performance in medium to moderately large rooms. To reach that goal, you will need to surround it with very fine components connected with high quality cables. Tweak your system and tune your room and you will be handsomely rewarded. The Sound Dead Steel Isofeet will be very helpful in this regard.
In small to medium size rooms the newer version of the JRs with the right amplification might do you very well. They've risen in price to $5695 and are on backorder as I write this in mid December 2007. If you wish to step up a notch or two consider the new Anniversary JR at $6000/pr. in African Hazelwood or the Signature version in Steinway High-gloss black with Mundorf capacitors at $7500/pair.
Successful manufacturers have a knack for properly pricing their products. Overpriced or under-selling products have a way of falling by the wayside as the technology evolves. Albert Von Schweikert and his staff are clearly among the very elite manufacturers of our time. It came as no surprise that the VR-4SR Mk2 was as good as it was. What surprised me was how good it became with the addition of the modest Sound Dead Steel Isofeet and the new Von Schweikert speaker cable. Not only is it as good, if not better than other American made loudspeakers at much higher prices, given the weak United States dollar, it trumps most everything in its league from abroad. In this upper echelon, the VR-4SR Mk2 loudspeakers have outstanding value. If you are on the verge of purchasing a new loudspeaker, this could easily be the one, which is to say it has my highest recommendation. If you can't find them locally, book a flight and go have a listen.
Full Review: enjoythemusic.com
Κυριοι,
Ενα ΗΧΕΙΟ...ΔΕΝ ειναι το αθροισμα μερικων καλων μεγαφωνων...
Αν ηταν τοσο απλα τα πραγματα ο οποιοσδηποτε θα αγοραζε μερικα κορυφαια μεγαφωνα θα τα βιδωνε πανω σε ενα κοντρα πλακε θαλασσης και θα ητανε μαγκας...
Ο κ.Κογιας και ο κ.Μπλατσιος σε αλλο topic προτεινουν αβιαστα σε καποιον το B&W802D η τον Ερμη π.χ. της Audio Spectrum.
Λογω της ιδιοτητας μου δεν μπορω να εκφερω γνωμη δημοσιως για τα συγκεκριμενα προιοντα, απλα θα πω οτι ουδεμια σχεσιν εχουν με τα Von Schweikert...
...και θα προσθεσω οτι το συγκεκριμενο ηχειο (του topic) το ειχαμε στην εκθεση προς ακροαση...Προφανως δεν καταδεχτηκατε να περασετε απο το δωματιακι μας...Δεν πειραζει εσεις χασατε.
Επισης θα προσθεσω οτι η εταιρια μας ειναι η μοναδικη που πουλησε αυτουσιο το συστημα της εκθεσης σε εναν αγνωστο προς εμε κυριο χομπιστα ο οποιος ηταν τρομερα απογοητευμενος απο ενα συστημα υψηλης (αντιστοιχης) οικονομικης αξιας αλλα μετριου αποτελεσματος που ειχε ηδη σπιτι του.
Αυτα προς γνωση και συμμορφωση καποιων που λαμβανουν σοβαρα υπ'οψιν τις συμβουλες καποιων "ειδημονων" απο δω μεσα...
Gebreselassie
Μαύρος!
Ώπα Γιώργο! ΠΟΙΑ προς γνώση και συμμόρφωση? Το ότι μας είπες την άποψή σου για τα ηχεία που πουλάς είναι το ατράνταχτο επιχείρημα ή είναι ότι κάποιος τα αγόρασε ακούγοντάς τα στο περίπτερό σου στην έκθεση?
Ανάμεσα στα threads της high end, μπορείς να βρεις και να διαβάσεις τα συμπεράσματα όσων μελών μας πήγαν στην έκθεση. Αν βαριέσαι να το διαβάσεις ρώτα να σου πούμε πιο ηχείο έπαιζε καλύτερα με βάση τις απόψεις των περισσοτέρων. Και να σου πω και κάτι άλλο: Πρέπει να ήταν εντελώς ηλίθιος κάποιος για να αγοράσει ηχεία από έκθεση και να μην τα πάρει στο σπίτι του να τα ακούσει. Παράδειγμα προς αποφυγήν είναι ο τύπος που αναφέρεις ή ΕΝΤΕΛΩΣ ΑΣΧΕΤΟΣ με το σπορ.
- Λίγο μέτρο δεν είναι κακό. Σου τα λέω χύμα μπας και καταλάβεις πόσο κακό κάνεις στον εαυτό σου. Προς γνώση και συμμόρφωση δηλαδή.
Κώστας Φ.
Φίλε Γιώργο,
Κατ'αρχήν δεν καταλαβαίνω που κολλάει η τοποθέτησή σου-"κράξιμο σε Kόγια/Μπλάτσιο" σε τούτο εδώ το thread. Για το μόνο που μιλάει ο Σπύρος είναι η διαφορά τιμής US-GR και μάλιστα το σχόλιο, αν κατάλαβα καλά, αφορά την προηγούμενη αντιπροσωπεία της Von Schweikert και όχι την Music Lover.
Στο θέμα του ηχείου τώρα (το Von Schweikert δλδ - οι αναφορές σε άλλα ηχεία και την αξία αυτών είναι ψιλο-off topic αλλά με χαρά να το συζητήσουμε σε άλλο thread)....
Εγώ είχα την τύχη να το άκουσω και όντως ήταν από τους καλούς ήχους της έκθεσης... Από την άλλη όμως, αν θέλεις τη γνώμη μου, στην έκθεση (και για τα γούστα μου πάντα) δεν άκουσα τον super-ultra-extra HiEnd ήχο που να δικαιολογεί την τιμή κάποιων συστημάτων. Ναι μεν κάποια συστήματα ξεχώρισαν αλλά, τουλάχιστον εγώ, δεν άκουσα τον ήχο που θα μου μείνει στο μυαλό, τον ήχο που θα με ανατριχιάσει και που θα με κάνει να χρεωθώ μέχρι το λαιμό για να τον αποκτήσω... Έστω βρε αδερφέ τον ήχο που να με κάνει να σκεφτώ να πετάξω το μπουρδ3λο το σύστημά μου, που στην τελική δεν είναι και τίποτα φοβερό. Μια χαρά άκουσα και γούσταρα τη μουσικούλα μου από το "φτωχό" HiFi σύστημά μου όταν γύρισα σπίτι...
Δεν θα τα έγραφα όλα αυτά γιατί γνωρίζω πως οι εκθέσεις δεν είναι για να βγαίνουν συμπεράσματα, αλλά αυτό πρέπει να ισχύει είτε μας συμφέρουν τα συμπεράσματα είτε όχι...
Το ότι κάποιος αγόρασε το σύστημα που είχες στην έκθεση σίγουρα δείχνει άνθρωπο απελπισμένο και απογοητευμένο από το σύστημά του και, ίσως, άνθρωπο που ξεχώρισε, για γούστα του, το σύστημά σας από τα υπόλοιπα (που ήταν στημένα σε διαφορετικά δωμάτια, με διαφορετικά σύνοδα κλπ. κλπ.), αλλά μέχρι εκεί...
Εκεινο που εντυπωσιασε τον συγκεκριμενο κυριο ο οποιος παρεπιπτοντως δεν ειναι καθολου ασχετος ειναι οτι το ....22000 ευρω ΚΑΚΟΣΧΕΔΙΑΣΜΕΝΟ και γεματο περγαμηνες διεθνως ηχειο του, μπουμαρε στο σαλονι του των 80 τ.μ.! Το VR4SRMKII ΔΕΝ μπουμαρε στο δωματιακι των 15 τ.μ. σε ΡΕΑΛΙΣΤΙΚΕΣ σταθμες! Φυσικα μου ειπε εξαρχης οτι θα αγοραζε το 65000 ευρω αξιας συστημα ΜΟΝΟΝ εαν του το εστηνα στον χωρο του και επαιζε παρομοια η και καλυτερα (λογω μεγαλυτερου χωρου). Φυσικα το συγκεκριμενο συστημα δεν ειχε κανενα προβλημα να επαναλαβει το ηχητικο αποτελεσμα του ξενοδοχειου και φυσικα πολυ καλυτερα στο σπιτι του πελατη. Ετσι ο πελατης μενοντας απολυτως ικανοποιημενος το αγορασε!
Τωρα για το καυστικο μου μηνυμα προηγουμενως οσον αφορα τους 2 κυριους, συγχωρεστε με Νικο και Κωστα αλλα μερικες φορες.....βγαινω απο τα .....ρουχα μου..
Ειδικα οταν πολεμιοι του high end προτεινουν, ως "ειδημονες" του χωρου, συστηματα σε ενδιαφερομενους αδαεις πιθανους αγοραστες.
Gebreselassie
Μαύρος!
Ε, και τι σημαίνει αυτό ότι είναι χειρότερο ηχείο από το von πως το λεν? Ρε σεις χαλαρώστε λίγο με τα συμπεράσματά σας. Τελικά μάλλον είναι άσχετος.
Για την ιστορια η τιμη του ηχειου στην Ελλαδα ειναι 10000 ευρω.
Επισης θα πρεπει να αναφερω οτι ο κατα τεκμηριο κορυφαιος ηχοληπτης πανω στον πλανητη γη, ο Doug Sax των mastering Labs της Sheffield, χρησιμοποιει ως βασικα monitors στα studios του, ηχεια της Von Schweikert Audio.
Αυτο....λεει πολλα...
  • loggeo
Σωτήρης Καλύμνιος
