M2Tech Hiface
Απάντηση: Re: Απάντηση: M2Tech Hiface
αληθεια !ποσο παει αυτο τωρα?
160€ το έχει ο Γερμανός.
http://www.thomann.de/gr/behringer_ultramatch_pro_src_2496.htm
Και είναι πάρα πολύ καλό!
O τρελλαμένος lampizator έγραψε ότι είναι από τα καλύτερα DACs που έχει ακούσει απείραχτο. Και δεν έχει άδικο...
http://www.lampizator.eu/lampizator/TRANSPORT/behringer/Behringer.html
ναι καλα πριν 2-3 χρονια αλλα τωρα....
το Zero dac ειναι καλυτερο με 100 ευρουλακια.
Καλούτσικο το βρίσκει ο τρελλάκης:
"OUT OF THE BOX - the DAC sounds really OK. Nothing exciting but really OK. Absolutely nothing to complain. I think I can recommend it to non-tweakers as well. You will not be disappointed."
http://www.lampizator.eu/lampizator/REFERENCES/ZERODAC/ZERODAC.html
Αλλά από συνδέσεις και δυνατότητες ούτε το 1/10 του Μπέρυ...
Ενώ για το Μπέρυ λέει αυτά:
"Normally - I hate devices which add complexity and add manipulation to the sound. I believe in less is better.
BUT
This device is different, Unlike oversampling - which we already know is VERY bad for music - upsampling may be sometimes VERY GOOD. It is not the panacea, universal Hi-Fi cure, but in my system, very revealing and transparent - I tell you as it was. YMMV.
I can tell you - after hitting the UPSAMPLE button on the Behringer - I was taken to heaven. The DAC strarted to behave like a magic box.
The normal signal, the normal sound - was taken to another level.
Something extraordinary happened. I have big problems putting it in words, especially English.
Music becomes smooth, liquid, magical. The same music which sounded just great without Behringer - with the process of upsampling sends the chill up my spine. Whhhooooa! Now this is another experience - this is high end. I CAN'T POSSIBLY GO BACK TO NAKED DAC. The whole thing is about the PLEASURE of listening. It increases much.
Now - the price context - we are not talking 100 000 Euro like for Goldmund heavy CD table. We are talking maximum 150 Euro, or even less. "
βρε komhst μην προσπαθης να βγαλης ακρη με τον λαμπιζατορα.
τα ειχα και τα δυο και ξερω.
και τωρα εχω ενα μπερυ στο σπιτι.
Oversampling είναι η υπερδειγματοληψία σε ακέραια πολλαπλάσια της βασικής συχνότητας δειγματοληψίας, πχ για το CD-audio x2 (88.2 kHz), x4 (176.4 kHz), x8 (352.4 kHz), κτλ.
Upsampling είναι η υπερδειγματοληψία σε οποιοδήποτε μη-ακέραιο πολλαπλάσιο της βασικής συχνότητας δειγματοληψίας, πχ για το CD-audio 48 kHz, 96 kHz, 192 kHz, 384 kHz, κτλ.
α οκ τόσο απλό!!!!θένκς:137:
deleted user 10898
Απάντηση: Re: M2Tech Hiface
ωχ ωχ ωχ
http://www.computeraudiophile.com/content/M2Tech-hiFace-Asynchronous-USB-SPDIF-Converter-Review
After several months of listening and comparing I think M2Tech's implementation is a bit underwhelming. The hiFace offers good stand-alone performance and value while simultaneously disappointing me. The fact that I believe it's overrated has just as much to do with hiFace users' opinions as it does the hiFace's performance.
Φίλε vet μήπως είδες το jitter από τις μετρήσεις του;
To κόβω καλά στα 160 ps περίπου;
:111:
Χοντροειδες υπολογισμοι και βασικα τυφλοσουρτης,αλλα για μετρησεις περιοδικων φτανει και περισσευει.
Ο σωστος τροπος ειναι μετρηση του τζιτερ στο ψηφιακο πεδιο,και μαλιστα στο word clock αν μιλαμε για μαλτιμπιτ,και υπολογισμος του std dev.
Αλλα ξεφευγουμε.
Πλιζ κοντινιου....
deleted user 10898
τι κοντινιου... μετρηση jitter πλεον με ενα νουμερο ειναι μονο για τα περιοδικα και τα φορουμ. εχει πολυ μελλον το θεμα ωστε να αντιστοιχισουμε στις μετρησεις jitter την πραγματικη σημασια τους.
αυτο που εχει ενδιαφερον ειναι οι παρτιδες hiface που κυκλοφορησαν με προβληματικα ρολογια... στο εν λογω ριβιου μηπως υπηρχε τετοιο?
περιμενουμε την απαντηση...
Αλλα ξεφευγουμε.
Πλιζ κοντινιου....
Φίλε μου, όπως εξηγείται και στο κείμενο, είναι ο τρόπος του "STEREOPHILE", o μόνος τρόπος δηλαδή, που σαν καθιερωμένος πλέον, επιτρέπει συγκρίσεις μέσα από ένα πολύ μεγάλο αρχείο μετρήσεων!
:107:
deleted user 10898
:107:
για τα περιοδικα και τα φορουμ...
anquan
