Daniel Weiss - Ενδιαφέρουσα συνέντευξη
Manos58
εγχειρισμένη
Απάντηση: Daniel Weiss - Ενδιαφέρουσα συνέντευξη
Για ποιον το κατασκευαζει ξερετε???
Για τον Τσακιρίδη......για να σκοτώσει τους Τζαπανέζους ανταγωνιστές του :114::114::114:
Re- Daniel Weiss:Το χρήμα που ψύχεται σε θερμοκρασία...δωματίου ακρόασης
Όπως θα επεσήμαινε και ο Μογγόλος στοχαστής-πολεμιστής...Apo Kapu Khan (απόγονος γαρ του Genghis Khan:137:),τα παρακάτω ενδεικτικά αποσπάσματα ορίζουν με σαφή τρόπο τη διάκριση ανάμεσα στον εθισμό και τον...ερεθισμό του καταναλωτή προϊόντων υψηλής πιστότητας.
-A lot of people have problems understanding how data flows in a server based system, where the data is, where it turns to analogue, the effects of a digital transport and things like that. Is it a business challenge for you to overcome those misunderstandings so that people understand what the product is for?
To some extent maybe. But I think our job is to tell people how it is, and hint them that they can be victims of false misconceptions and false expectations. Some think WAV sounds better than FLAC because the FLAC is data reduced, but it’s not of course in the end.
-Not understanding the difference between lossy and non-lossy compression.
They probably think one must be worse because the file is smaller. When they listen they expect the WAV to sound better and then it sounds better.
-If you had a room and a system and choice of music that you have full control over, do you think you could tell a €200 CD player from a €15000 transport feeding one of your DAC’s?
I wouldn’t expect to hear a difference actually.
-Because of the jitter suppression?
Yes, provided of course that the data is read correctly.
-Then what about electric S/PDIF? There’s research showing that different cables can introduce different amounts of jitter. Is that something we can hear in a normal DAC, or with your jitter suppression?
That’s of course very much depending on the implementation or on the clocking and re-clocking. Our DAC’s are built such that it shouldn’t matter much.
-So you wouldn’t recommend a €1000 digital cable?
No. No, I wouldn’t.
-So that money would be better spent on something else.
Yes, on acoustic treatment maybe.
-There are several products coming out that have either wifi or wired ethernet built in, to read directly form a server. You have the MAN202 coming out, the Devialet amplifier will get an upgrade this spring for wifi, there’s the Resolution Audio Cantata which has ethernet as well. So those types of products are coming now. Is that just coincidence or are people being influenced by eachother?
I think they are seeing the general trend in high-end audio, that it’s going to be network based playback. So it’s a logical consequence of that.
-That’s a bit of a controversial topic, mains cables. What’s your personal opinion on that?
I’ve not done any comparisons. I’m kind of doubtful about mains cables in particular, because those people don’t care about the cable behind the wall.
-I think the argument is often that the part exposed in your room is basically an antenna, which needs to be shielded.
But the wires in the wall are also an antenna.
-So unless it’s a filter, it doesn’t really matter?
A filter is something different of course. But just a cable… of course it has some filtering effect in any case, but a cable shouldn’t do that much filtering compared to a mains filter which is a different thing.
-So you would recommend looking into a mains filter rather than mains cables?
Yeah, if you want to treat the mains part.
-Now there is the NAD M2, Lyngdorf, Devialet… Will you ever do a digital amplifier?
Oh yes, definitely. We did one earlier on but we are going to do a different one now. Smaller and cheaper.
-In terms of features, why should I buy a MAN202 instead of a Mac mini and a DAC202?
That’s up to you, of course. The advantage of the MAN202, or at least that’s the goal, is that it’s much simpler to set up, to operate and you don’t have to hassle around with the operating system, with drivers and upgrades, ripping formats etc. That’s the idea. You don’t have to have a computer in your living room, no keyboard and no mouse, no monitor. But of course you can get away with a mac mini and a DAC202, it’s perfectly fine, but not for everyone.
-So is the target demographic people who are a bit reluctant to go into computer based listening but have the financial resources to buy good equipment?
That’s it, yes.
-I noticed that when you talk about the DAC in the MAN202, you’re very careful to always say it’s of similar quality to the DAC202. You’re not saying it’s identical.
Yes, they are not identical. The MAN202 is a little bit better than the DAC202.
-Because it has more DAC chips?
The Sabre DAC chip has 8 channels. In the DAC202 we use 2 DAC channels per audio channel because we have the headphone output which has separate DAC channels for the volume control. So that’s the only reason. In the MAN202 we don’t have any headphone output, so we use 4 DAC channels per audio channel.
-What is it that becomes better?
You can parallel the DAC channels and add the output of those and for every doubling of channels you get 3dB more signal to noise ratio, in theory. Of course you reach some thermal noise level in the end.
I think you can’t expect your hifi system to sound like a concert hall. I know people try to reach that goal, some people at least, but they are two different things. There’s the recording process in between, which is an art form in itself. So you end up with a product made by recording engineers, by all the gear in between, so there is no point to try to achieve that concert hall feeling at home.
-But isn’t there a point in trying to get as close as you can get, or is that just bound to be frustrating?
I think it’s the second thing. Of course you can try to get as close as possible, but you can never reach it. You don’t have the people sitting around you at home, you don’t have the real acoustics, you don’t have the size of the orchestra.
-Do you have a turntable at home?
I do have one, yes. But I never use it (laughs).
-When was the last time you used it?
It must be a year or so ago.
-So you’re really true to digital.
I admit it, yes. But that’s one plugin for the MAN202, a vinyl simulator.
-I spoke to Michael Fremer yesterday, and he says that when he digitizes vinyl, it retains some of the qualities that he likes about analogue. But that in turn proves that digital is able to convey those traits. But he also says that when you press a vinyl, something happens to the sound that you can’t achieve any other way. Have you thought about what that could be?
Sure. Some parameters you can extract from vinyl, like channel crosstalk which is bad, or rumble noise.
-And frequency response.
Yes. I have to try to see if we can achieve something.
-How do you audition the equipment that you build? Do you do listening tests at all?
No, basically I don’t do that. I have some Strax headphones for some listening, but I don’t judge the electronics based on listening tests.
-Does anyone else in the company do that?
No.
-So it’s purely an engineering product?
Yes.
deleted user 10898
Re: Απάντηση: Daniel Weiss - Ενδιαφέρουσα συνέντευξη
όπως βλέπεις, δεν βαρεθήκαμε...
τι σχεση εχει αυτο το νημα με τις "χροιες" των περιοδικων απο οπου και το σχολιο μου?
και τα περιοδικα τον weiss θεο τον εχουν....
δεν ειδα κανενα να τα κατακρινει και για αυτο...
ε?
μηπως τα πληρωνει, τους βαζει διαφημισεις ή τους δινει τσαμπα μηχανακια?
και ένα χαλασμένο ρολόι, δείχνει 2 φορές τη μέρα σωστή ώρα.
αυτό δε σημαίνει ότι δε θα βρίζεις το χαλασμένο ρολόι....
Manos58
εγχειρισμένη
Ελβετικές ίντριγκες.......ποιός ξέρει :109:
Χεχεχε, απίστευτος ο μπάρμπα-Βάις..:615:..
Απάντηση: Re: Απάντηση: Daniel Weiss - Ενδιαφέρουσα συνέντευξη
Μέχρι στιγμής, έχουν σχολιασθεί οι απαντήσεις του Weiss. Μελέτησε όμως τις ερωτήσεις του δημοσιογράφου.
νομίζω πως μόνο σε μια ερώτηση τα βρήκε λίγο "σκούρα", αυτή με τη μέτρικ χάλο.
τέλος, με τα εξωτερικά ρολόγια έχει ένα "θέμα", αλλά αυτό συμβαίνει μάλλον γιατί δεν έχει ασχοληθεί αρκετά με το αντικείμενο αυτό, κάτι που εμμέσως πλην σαφώς το είπε κι ο ίδιος.
m1ts0s αν ασχολήσε με το hi-fi ή και το hi-end μου κάνει εντύπωση που δεν ξέρεις τα chario.Μαζί με τα sonus faber είναι οι πρεσβευτές των ιταλικών ηχείων και γενικότερα απ τα γνωστότερα audio ιταλικά προϊόντα.
m1ts0s
News poster
Μόνο τη Sonus Faber γνωρίζω εξ Ιταλίας. Αυτά τα Chario απ'ότι βλέπω είναι παθητικά. Περίμενα και εγώ ολόκληρος Weiss να παίζει με τίποτα Geithain ME 800K :119:
deleted user 10898
αμ τι, dac με pll την σημερον ημερα...
ειμαι με την μετρικ σε αυτο τον τομεα, που φτιαξαν ασυγχρονο firewire ναουμε.
και εαν δεν εχεις την τεχνογνωσια βαλε ενα εξωτερικο. ειδικα εκει που λεει για το jitter που εισαγει το εξωτερικο rubidium ρολοι επειδη δεν "τρεχει" στην ακριβη συχνοτητα και θελει μετατροπη... ειδα την τριχα του εαρ να σηκωνεται...
Την ίδια σκέψη κάναμε Νίκο:114:
Manos58
εγχειρισμένη
Πώσω πσιλά σικόθικε ;
Μας κρύβει η Κακιά Σκάλα την ορατότητα και δεν είδαμε:410::410::410:
Εγώ νομίζω οτι εμμέσως πλήν σαφώς απαντάει για τα εξωτερικά κλόκς και τη χρησιμότητα τους σε ένα απλό dac.
You said you have too many projects, but do you plan to branch out into other component types? MAN202, DAC202 and Medea have clock input, so will there be a CLOCK202?
Probably not. Or if we do it, only because of market demand. Technically it doesn’t make much sense I think. The clock should ideally be right at the DAC chip or ADC chip. So if you have this atomic clock, which is a bad idea anyway because you don’t need the precision of the clock really—what you need is good jitter performance—those 10MHz standard frequency rubidium clocks, you have to PLL to another frequency which introduces jitter again. It’s a bad idea, the whole rubidium thing. Regarding our firewire products, they are the clock master for the computer. So whenever you change the sample rate on the track, you would have to adjust the sample rate of the clock source, which is kind of difficult if it’s an external clock source. So I’d rather not have an external clock source.
Φυσικά δέν ερωτήθηκε για άλλα, πολύπλοκα πολυκάναλα συστήματα στα οποία η ύπαρξη του εξωτερικού κλόκ αποτελεί μονόδρομο.
μη το βασανίζεις, σε αυτόν τον τομέα είναι πίσω ο μπαρμπα-βάις. Απλά, δεν έχει προλάβει να ασχοληθεί ακόμα. Κι ως γνωστό, όσα δε φτάνει η αλεπού, τα κάνει ...κρεμαστάρια! (άνθρωπος είναι κι αυτός, μη σκας...)
Δε πειράζει, ασχολείται με άλλα, και κάνει πολύ καλή δουλειά. Να δεις (εδώ θά'μαστε) που θα αλλάξει "άποψη" όταν ασχοληθεί σοβαρά με τα ρολογάκια.
Πλάκα πλάκα, είναι απίστευτο που έχει καταφέρει τόσα πράγματα και τόσα προϊόντα μια ομάδα 10 ανθρώπων! Τους αξίζουν συγχαρητήρια!
m1ts0s
News poster
Οι περισσότεροι είναι απόφοιτοι του ETH στη Ζυρίχη, όχι τίποτα τυχάρπαστοι :126:
themiloc
Ο Weiss, είχε, όποτε ρωτήθηκε (βλέπε παλιά συνέντευξη Σταματάκου *) σαφή θέση για το περιττό του ρολογιού, σε οικιακά συστήματα και νομίζω οτι δίνει ιδιαίτερη σημασία στο τι είναι σημαντικό και επίσης στο που θάπρεπε να ξοδευτούν χρήματα για να υπάρχει βελτίωση.
Ποιά είναι η γνώμη σας για το κεντρικό clocking στα οικιακά συστήματα;
Ναι, γνωρίζω ότι υπάρχουν κάποια προϊόντα που προορίζονται γι' αυτή τη δουλειά. Δεν νομίζω ότι είναι απαραίτητα, πάντως. Σε ένα κορυφαίο σύστημα στο σπίτι το μόνο που παίζει σημαντικό ρόλο είναι το clock του μετατροπέα. Αυτό πρέπει να είναι εξαιρετικής ποιότητας, αλλά αν είναι, αυτό αρκεί. Αντιθέτως, σε ένα στούντιο έχουμε πολλές συσκευές με δικό τους clock του οποίου η ποιότητα παίζει ρόλο: Μετατροπείς a/d και d/a, sample rate converters κλπ. Εκεί το κεντρικό clocking με μια κορυφαίας ποιότητας συσκευή είναι, βεβαίως σημαντικό.
Ντάξει τα project φαντάζομαι τα δίνουν και σε ερευνητικά κέντρα.Δέν κάνουν μόνοι τους την έρευνα...έτσι λειτουργούν οι εταιρείες.
δε φαντάζεσαι πόση "δύναμη" έχουν 10 σκεπτόμενοι άνθρωποι...
Christos Kourmouzoglou
