Ηλεκτρονικό τσιγάρο
$54.95
Description
SMOKTech XPRO M80 Plus BOX Mod
The SMOK XPRO M80 PLUS is the big brother of the popular SMOKTech XPRO M50. The M80 PLUS can now fire up to 80 watts and has new temperature control settings. With two built-in 18650 Li-polymer batteries, the M80 PLUS has a high capacity of 4000 mAh. This allows most vapers to enjoy a longer and stronger vaping experience. There is now no need to unscrew the back of the mod to recharge your batteries anymore.
SMOKTech listened to your feedback and now the M80 PLUS now has a passthrough function which allows you to vape while charging the M80 PLUS. Also new to the M80 PLUS now offers adjustable temperature control settings from 200 Fahrenheit to 900 Fahrenheit! The M80 PLUS also offers a puff counter and date/time settings as well.
The M80 PLUS Mod is made out of a high precision, aluminum and zinc alloy. The device is a light weight, compact, and easy to operate. It also has air holes on the bottom of the device for increased heat dissipation and safety.
The device is variable wattage from 6 - 80 watts and is able to power atomizers with a resistance load as low as 0.1 ohm’s. The side of the mod has an extra large firing switch for comfortable operation, a LED screen, a plus and minus key, and a reset button. The base has a micro USB port for charging and a battery vent hole. The 510 connection on the top of the mod has an adjustable spring-loaded floating center pin.
Features and Specs:
    • Dimensions: 3-5/16" x 2-1/8" x 7/8"
    • 510 Threaded
    • 510 to eGo Adapter Included
    • Adjustable spring loaded pin
    • 4000 mAh high capacity
    • Battery type: (2) built in 18650 Li-polymer batteries (DO NOT Attempt to REMOVE the batteries)
    • Wattage range: 6W - 80W
    • Minimum resistance: 0.1 ohm
    • Mech Mode and VW Mode Shift
    • Shift between Mech Mode and VW Mode by entering the main menu
    • Vape while you charge passthrough functionality
    • Temperature control technology: 200 F to 900 F
    • Short Circuit protection
    • Discharge protection
    • If system halts, can be restarted from side hole
    • Vent Holes
    • Intelligent OLED display screen displays: battery capacity, wattage, resistance
με τοσα λιγα χρηματα ουτε το κουτι δεν παιρνεις.....λετε να παιζει κατι ;:rolleyes:
δεν το πηρες βρε ακομα το ipv mini ?
αντε παρτο τωρα για να μπορεις να δουλεψεις τον kanger σωστα..... γιατι με το istick δεν παιζει σωστα ακομα και στα ωμ που τον δοκιμασες....
Η αλήθεια είναι ότι το istick δεν δουλεύει σωστά .
ο kanger από αρώματα είναι πολύ κοντά στον kayfun το μόνο αρνητικό για εμένα είναι οι πολύ αέρατες τζούρες (δεν μου αρέσουν )
αλλά ρυθμίζεις τον αέρα σε μισή τρύπα .
προτείνετε 100%
χθες είχε πλάκα... που ο Νίκος έφτιαχνε αντίσταση με ότι έβρισκε μπροστά του... Μαγκάιβερ... :rolleyes: :laugh:
ΥΓ. Εαν έχει έστω και μια αμυχή..... δεν τον αγοράζω....:p :laugh:
όταν πήγαινες εγώ ερχόμουν :p:p:p
κατουρα και λιγο μ@ρη :p
σημασια εχει οτι τα πας καλα....ευγε.!!!
μολις παρω το δικο μου vaporshark θαρθεις για καφε κ.λ.π.να δεις τι παιζει
......και με αντιστασεις νικελιου....... και βλεπεις..;)
θαχουμε kayfun lite plus και five pawns - kanger subtank mini - erlprinz - expromizer .....γνησιους ετσι για να ξερουμε τι παιζει στο 100% του ατμοποιητη ...:drinks:
Δεν ξερω,αλλα μου αρεσει αυτος ο ατμοποιητης! Η γευση του ειναι πολυ καλυτερη απο τον kayfun πιστευω. Θα στησω και τους δυο με συρμα,και θα βαλω και στους δυο το ιδιο αρωμα να δω.
ενδιαφερον ....αναμενουμε
μπορει να παιζει ρολο και η αλλαγη που εκανες στο επιστομιο
Με τις δυο τρυπες ανοιχτες και το κλασικο επιστομιο ειναι μια χαρα η τζουρα,γευση και ντουμανι. Με την μια ανοιχτη εσφιξε πολυ η τζουρα και το ντουμανι μειωθηκε.
δεν ξερω αλλα και ο delta ii ειναι ωραιος στα 53e με ρυθμιση τζουρας καλυτερη μιας και ειναι συρομενο το ανοιγμα και οσο θελει ο καθενας..
JAndronikos
