Marantz SR7010 - SR7011
http://www.avsforum.com/forum/90-re...0-av7702mkii-owner-s-thread.html#post34845169
7/19/2016
- When customer connects the AV receiver with the specific BD player (Sony BDP-CX960 and Sony CX-7000 Blu-ray Jukebox) via the HDMI and playback the contents of "DTS-HD", the AV receiver doesn't recognize the audio of "DTS-HD". Therefore, the specific BD player outputs the audio signal with Multi ch PCM.
The symptom is a problem that the "DTS-HD" format signal is not output.
- In a network environment in which AV receiver is connected, the network module of the AV receiver reboots when Netflix APP starts on the iOS device.
The symptom is a problem that the network module of the AV receiver reboots when Netflix APP starts on the iOS device.
- The audio intermittently becomes interrupted when HD cable TV program switches from DD with DSU to PCM based commercial using Dolby Surround.
The symptom is a problem that the audio intermittently becomes interrupted when HD cable TV program switches from DD with DSU to PCM based commercial using Dolby Surround.
- When the customer plays a specific file by USB Memory device, the track name is changed one after another in 25 seconds. (File that the number (01 and 02, etc.) are recorded at the beginning of the name.)
The symptom is a problem that the track name is changed one after another in 25 seconds.
- When the customer inputs the 2ch audio signal with the following specific condition to the AV receiver, the Center channel output signal is distorted.
Sound mode: DTS Neural:X
Input signal: amplitude = over 440mFFS (40% vs full scale) and frequency= 720Hz / 2.7~4.1kHz
The symptom is a problem that the Center channel output signal is distorted by the specified condition.
- When the customer switches the sound mode from the marantz Remote App, the following failure occurs in the AV receiver.
Example:
The sound mode becomes the "Dolby Surround" even if the customer selects the "DTS Neural:X" in the sound mode.
The sound mode becomes the "DTS Neural:X" even if the customer selects the "Dolby Surround" in the sound mode.
The symptom is a problem that the sound mode is not correctly selected even if the customer selects the sound mode.
- When the black hole router was present between the Internet environment of the AV receiver and DPMS server (including the Internet service provider side equipment), the AV receiver might fail in the firmware update. (The black hole router is a router that destroy it when the divided IP packet cannot be forwarded.)
TERMATOGAZI
Bass!
Για ικανοποιητικές στάθμες που ανεβάζεις το volume του marantz ?? Έχω τον 5010..
δεν ειναι τοσο απλο.
τι ηχεια εχεις ?
τι τελικους αν εχεις?
εγω ακουω απο -3 εως 0 αλλα για καποιους αυτο ειναι πολυ δυνατα.
ικανοποιητικα για μενα ειναι απο -10 και πανω
Έχω elac b6 τελικούς όχι ααα εσύ παίζεις full τότε εχτες που έβλεπα ταινία το είχα στο 60 ας πούμε
Καλημέρα τελικός 70 τέλεια είδα ,thor 2 εχτες .. τελικά ήθελε το γκαζακι του
Για ικανοποιητικές στάθμες που ανεβάζεις το volume??
Ποτέ δεν κατάλαβα αυτή την ερώτηση, το ανεβάζεις μέχρι εκεί που χρειάζεται.
Γι' αυτό υπάρχει και γι' αυτό έχει επάνω κι απ' αυτό που χρειάζεσαι.
Vakis2000
Κλιψ κλαψ
Καλημέρα.
Επιλέγοντας την εντολή direct, σε αντίθεση με την Yamaha που έδινε μία επιλογή (pure direct), εδώ έχομε τρεις:
Direct
Pure Direct
Auto.
Ποια η χρησιμότητα της κάθε μίας περίπτωσης, καθώς και που επεμβαίνουν?
Πρόσεξα ότι στην επιλογή auto πχ το sub είναι ενεργό!
Sugah
Ζαχαρούλης
Καινούριος χρήστης με μηδενικό feedback και μάλιστα εις τριπλούν.
Μακρυά :)
  • Like
Reactions: PPG
Στο 397€ εννοείς; Δεν έχει feedback και ό,τι πουλάει έχει την ίδια τιμή. Απατεών.
Το ίδιο ισχύει και στον 742€, που είναι ο ίδιος.
  • Like
Reactions: PPG
Πάντως αυτή η τιμή που παίζει τις τελευταίες μέρες με τον 7011 στα 1399 ευρώ (και που μοιάζει να είναι η καλύτερη μακράν τιμή σε όλο τον πλανήτη για το συγκεκριμένο ολοκαίνουριο μηχάνημα) βάζει σε σκέψεις και πειρασμούς...
Τι λέτε αξίζει να γίνει η κίνηση;
Giorgost
