Minidsp+dac/streamer+Dirac σε μια συσκευή.
Ripon δεν είναι πιστεύω. Η μ#€@κια είναι ότι κάποιοι το έχουμε πλερωσει. Κάτσε να δούμε τώρα τι θα πουν από minidsp. Έχει πέσει κράξιμο ήδη.
Μιας και το ξεκίνησα, παραθέτω και την απάντηση της minidsp. Αυτό που έχω αρχίσει να εκτιμώ πολύ σε αυτή την εταιρεία είναι ότι, μπορεί να έχει τα προβληματάκια της, αλλά γενικά υιοθετεί μια αξία που λέγεται "ανοικτή και ειλικρινή επικοινωνία". Όπως πρέπει να έχουν όλες οι εταιρείες πληροφορικής, γιατί για τέτοια πρόκειται, κατά τη γνώμη μου.
Dear All,
We'd be happy to share more information to re-assure everybody on the situation. Some of this information might be a bit technical and behind the scenes information, but then again, it's a good way to share what it takes to build a product.. I'm sure there will remain further questions but let's start with that "short" summary:
- SHD is a Streamer + DSP (miniDSP toolbox) + Room Correction (Dirac Live). These are 3 elements, 3 firmware and a 4th element to the equation when you add Roon support. They talk to each others to some extend but understand that these are different "Worlds".
- Roon is a licensed streaming solution that comes with a Certification program to achieve "Roon Ready" qualification . It involves sending some equipment to Roonlabs team that will then run a battery of test to "certify" the device. This is the active list of "Certified devices" kb.roonlabs.com/Partner_Devices_Matrix
Note: Providing you have some basic functionality, one device can still be discovered inside Roon as "uncertified" and stream audio. Think of it of a loophole that had some impact on Roon's ability to say it's not their fault if there are streaming issues. For that reason, they decided to turn off the ability to have a device listed as "uncertified" getting "enabled" and stream audio. It's a tough move as nobody will be happy.. In the end, I think that it will eventually lead to better experience for all customers.
- miniDSP started on the implementation of Roon last year. It involved coding for both the ARM + XMOS + DSP. Unit went for certification, passed all streaming tests with flying colors but came back with 2 major modifications that did put the final cert on hold:
a)Better latency management based on various sample rates and DSP path enabled. A useful feature for Roon's sync features
b)Real time Feedback on the active DSP chain back to Roon.
Let's go through them so you understand well:
a) Latency management: As you go through various sample rates or various DSP configs, the latency might change. In a basic DAC streamer without a DSP (i.e. Most of Roon Ready devices), it's not really an issue. On a DSP based solution with room correction and the ability to add delay to some outputs, that required some more modification at the DSP level (inside the SHARC code) to handle real time latency adjustment as you toggle presets, various Dirac build, etc.. It took a bit of time to code it, test it and as usual make sure we don't break something..
b) Real time DSP state feedback: This one is tricky one that required a lot more work. Basically we have more than 400 DSP addresses and initially the requirement was to provide realtime feedback on most of them... Unfortunately, in the world of embedded firmware (software running on chipsets), it's not like software on a pc.. You're dealing with some limitations on the architecture that may have no planned for it... In this case, it was very resource intensive to completely rework the whole firmware architecture for full feedback from the DSP to both the XMOS and ARM.. That's the main reason for the hold off to be honest.. In the last few weeks, we're grateful for the help from Roon team to propose an alternative to solve this.
Why we released a beta? Did we trick our customers?
- Some of you might think it was a terrible idea but we thought that as agile product dev comes, we'd want to get feedback on the streaming goes in a large setting (i.e. not few users). With the streaming part passing all tests, we felt confident and released the firmware for Roon as "beta". That allowed us to get confirmation from our community that indeed, the SHD was behaving very well for streaming/volume control/etc from Roon. We could be wrong but didn't hear back from you about some issues! Isn't it a great news we should be happy about? Cheer to all of you who've been testing this feature and giving us great feedback that everything worked as it should.. I bet you've been wondering why the device still isn't certified..
- Anyway, our plan was always two fold. a)Beta release b)Full release for certification. We didn't try to trick anyone (inc Roon labs), we didn't advertise a Roon Ready logo, we were actually quite clear that it was in Beta mode at this stage.. In between, we've got to admit that like every engineering team, our resources are limited, Covid19 got in between to put our world upside down and we just got busy trying to fit other tasks in between to please everybody. Bottom line, we fall on our sword for not solving this faster but to be honest, if Roonlabs didn't work with us to simplify the feedback, it would be really hard... In the end, all ends well!
Where we're at now:
- Great news is that we have a plan of action. From both our standpoint (miniDSP + Roonlabs), please understand that we want to solve this and no we're not ignoring customers, we not dodging the issue, we're not an "enemy" of Roon.. So "please" let's not try to think too much, life is a lot simpler behind the scenes.. With this latest change, we do have a path where we can indeed finalize the certification and are working together with Roon to make this happen. No exact timeline but it's indeed our top priority so there is no downtime.
A very important detail:
- Now there is a lot of confusion on this topic so let's try to make it clear to all:
- Roonlabs stated in few posts now that "If you are currently playing to ANY device successfully, you WILL NOT LOSE ACCESS TO THAT DEVICE ON SEPTEMBER 21."
This is very important to most of you who are a)Enjoying Roon as is b)Were thinking to add Roon license. If you do not change your system, you have nothing to worry about... Only if you "remove" a device will you start to be in the case that you can't "re-enable" your roon device.
Good news is that soon, this issue will be moot asap we release an update and we'll all stop worrying and get back to enjoying what we're all about, Audio!
Hoping this clarifies. Have a great day, stay safe!
The miniDSP DevTeam
Το "δράμα" συνεχίζεται! Τελικά έβαλε λίγο νερό στο κρασί της η Roon και θα υπάρχει "μεταβατική" περίοδος χωρίς να έχουν επιπτωση η χρήστες αλλά θα πρέπει να συμπληρώσουν κάποια φόρμα πριν το deadline στο site της.
Σταύρος Λαγκαδιανός
Το αγοράκι με τα σπίρτα
Ασφαλώς. Ο καταναλωτής που έδωσε τα ωραία του λεφτά για μηχανήματα και συνδρομες, δεν φταίει για τα τζιβιτζιλίκια μεταξύ ρουν και κατασκευαστων. Στο ΗΠΑ τα δικηγορικά γραφεία καραδοκούν για το παραμικρό. ;);)
Έχουμε νέα από τη miniDSP.
Δύο νέα μετρητικά μικρόφωνα, το UMIK-2 και το UMIC-X.
To πρώτο είναι αναβάθμιση του UMIK-1 και το δεύτερο χρησιμοποιείται για πολυκαναλικές μετρήσεις - συνδυάζεται με την (επί πληρωμή) επιλογή multichannel measurement του REW. Η εν λόγω επιλογή πωλείται μέσω του site του REW, ενώ στην τιμή του UMIC-X, περιλαμβάνεται μία άδεια χρήσης της.
Τέλος, στο site της miniDSP αναρτήθηκε αναλυτικός οδηγός για τη χρήση των μικροφώνων της με το Multiple Subwoofers Optimizer (MSO) για - τι άλλο; - την ενσωμάτωση δύο subwoofers σε ηχοσυστήματα.
Τέλος, στο site της miniDSP αναρτήθηκε αναλυτικός οδηγός για τη χρήση των μικροφώνων της με το Multiple Subwoofers Optimizer (MSO) για - τι άλλο; - την ενσωμάτωση δύο τουλάχιστον subwoofers σε ηχοσυστήματα
Fixed :biggrin:
Νόμιμη εταιρία όμως, κύριοι. Όχι σαν κατι άλλους χλεχλέδες
Fixed :biggrin:
Ρε νομοθέτη της κακιάς ώρας... "DUAL sub integration" τιτλοφορείται ο οδηγός! :biggrin:
Το MSO τι σημαίνει; ;)
Το έγραψα - Multiple. Ο οδηγός που αναρτήθηκε είναι για δύο subwoofers, το plug in είναι για πολλαπλά. :)
Το plug in με το UMIC-X, μια χαρά κάνει δουλειά για πολλαπλά subwoofers.
Οπότε με 750 δολλάρια τα έχεις όλα ;
Εάν ισχύει ...
Μιλάμε για τρομερή αναβάθμιση
Βέβαια το κόστος είναι 5πλασιο
αυτο το Mso είναι για το shd?!
Δεν το εγκαθιστάς στο SHD - το εγκαθιστάς σε laptop/PC. Κάνεις τις μετρήσεις στο REW, μέσω του SHD, τις "φορτώνεις" στο MSO, ρυθμίζεις το MSO, "τρέχεις" το optimizer, αποθηκεύεις τις βελτιστοποιημένες ρυθμίσεις, τις "φορτώνεις" στο SHD και τέλος.
Διάβασε τον οδηγό, ρε!:p
Έχει μόνο δυο έξτρα εξόδους το SHD ;)
Προφανώς το συγκεκριμένο έρχεται ως παραδοχή του ότι το νέο Dirac Live Bass Management για τα πολλαπλά σαμπ (έστω δυο) δεν μπορεί να ενσωματωθεί στο SHD. Κρίμα, γιατί είναι αυτοματοποιημένο και ευκολότερο από το MSO για τον απλό χρήστη.
Καταλαβαίνω τι λες και συμφωνώ.
παιδιά να ρωτήσω....σε macOS Big Sur θα εχω θεματακια με το shd?!
διάβασα σε ξένο φόρουμ ότι δεν ανοίγει η εφαρμογή κάτι τέτοιο.
έχει κανείς άποψη;
Kotsidis John
Photography
έχει κανείς άποψη;
εκανες αναβαθμιση σε νεο λειτουργικο αμεσως, χωρις να τσεκαρεις πρωτα συμβασιμοτητα κλπ κι αν παιζουν σωστα οι εφαρμογες που χρειαζεσαι? εκανες αναβαθμιση χωρις λογο? η πηρες ( δεν ξερω αν παρελαβες βεβαια ...) ηδη τα νεα τσιπ με Μ1 ?
Επίκειται σύντομα μετακόμιση σε άλλη γη σε άλλα μέρη...Το χώρο δεν τον έχω ακόμη βρεί. Προσανατολίζομαι σε 2 ξεχωριστά συστήματα/χώρους. Ενα για AV multichannel και ένα μόνο για audio (αυτο το δικάναλο το γνήσιο).
Στο νήμα αυτό θέλω τη συμβουλή σας αναφορικά με το δικάναλο. 'Εχω ήδη ενισχυτή με pre-out & main-out καθώς και ηχεία. Ως πηγή θέλω να χρησιμοποιήσω το Spotify/NAS/Internet radio καθώς και πικαπ (αν υπάρχει δυνατότητα).
Συμπληρωματικά μιας και ο χώρος θα είναι νέος (και άγνωστος) θα ήθελα να έχω τη δυνατότητα του room correction που προσφέρει το minidsp.
Το ζητούμενο είναι ενα setup που να μου δίνει ευελιξία και προσανατολισμένο σε ψηφιακές πηγές (streaming) και να είναι - οσο το δυνατό - future proof που λενε και στο χωριό μου. Θεωρώ οτι το SHD studio με καλύπτει ώς προς το ψηφιακό κομμάτι, τι γίνεται όμως με το αναλογικό ? (πικάπ).
  • rose.athens
roberto_portale
