Wiim Ultra
5.2.709956 (In Progress)
Release date:
3 / 6 / 2025
What's New:
  1. Dolby 5.1 Surround: Enjoy wireless, low-latency Dolby 5.1 surround sound for an immersive audio experience. Learn More
  2. Recently Played Widget: Quickly access your listening history directly from your device screen.
  3. Soundtrack SDK Enhancement: Upgraded for smoother performance and an improved listening experience.
  4. Headphone Output Level Adjustment: Customize the headphone output level to match your headphones (requires an upcoming app update).
  5. Device Discovery Improvements: Enhanced stability for WiiM Home, Spotify, and TIDAL apps, improving device detection and connectivity.
  6. Wi-Fi Update: Updated Wi-Fi drivers for better router compatibility and improved connectivity stability.
  7. USB Indexing Enhancements: Improved album indexing for a better browsing experience (requires an upcoming app update).
  8. Clock Position Customization: Adjust the clock position on your device screen to suit your preference (requires an upcoming app update).
  9. VU Meter Mode: Choose whether the VU Meter reflects the original signal or output signal level (requires an upcoming app update).
Bug Fixes & Performance Improvements:
  1. Preset Playback Fix: Resolved an issue where playback stopped unexpectedly when selecting an empty preset.
  2. Qobuz Login Fix: Fixed an intermittent issue preventing Qobuz logins.
  3. USB Output Detection: Addressed a bug where the USB sound card was not being detected.
  4. Deezer Alarm Fix: Fixed an issue where Deezer Mix alarms were not functioning properly.
  5. General Enhancements: Improved overall stability, performance, and bug fixes.
Απορίες......
Υπάρχει μέσα στην εφαρμογή εικονίδιο για να κλείνω -βαζω σε stαnd by το Wiim και δεν το βλεπω????
Πρέπει πάντα να το κλείνω από το τηλ/ριο?
Και από το τηλ/ριο οταν πατάω το κόκκινο οκ κλείνει .Αν το ξαναπατήσεις ανοίγει.
Αν περάσει όμως λίγη ωρα αφού το κλείσεις και ξαναπατήσεις το κόκκινο εμφανίζεται η ώρα.....
Ποιός "φωστήρας" τα σκέφτηκε αυτα??
Το wiim έχει δύο rca line out. Αν συνδέσεις το ενα ηχειο σε κάθε rca με κάτι σαν το παρακάτω καλωδιο μάλλον θα παιξει:
2rca to 1rca
Δεν θα είναι stereo όμως, σωστά?
Υπάρχει κάποιο καλό ενεργό ηχείο (ζευγάρι) που θα μπορούσαν να παίξουν stereo?
Είναι λίγο πατέντα. Ωστόσο τα rca του wiim θα διαχωρίσουν το σήμα σε κάθε rca στερεοφωνικά. Η στερεοφωνια έρχεται από το wiim.
Μόνο με δοκιμή μπορεί να δεις αν σε καλύπτει το αποτέλεσμα.
θα το πρότεινες ως λύση ή με τα ίδια χρήματα θα αγόραζα άλλα ηχεία?
Εγώ δουλεύω το wiim με δύο tannoy gold 7 ενεργα με xlr to rca και παίζει άψογα. Το έχω δουλέψει με ένα JBL xtreme 3 με καρφί σε rca επίσης άψογα. Δύο bluetooth ηχεια δεν έχω σύνδεση πάνω του με rca για να δω τι παίζει. Το marshal είναι ήδη στερεο; Αν ναι τότε το συνδέεις σε ένα με κλασσικό rca καλωδιο και έχεις στερεοφωνια.
Το Marshall είναι για να παίζει μόνο του. Nομίζω παίζει stereo. Έχει 1 είσοδο RCA, 1 mini jack και 1 HDMI.
Οπότε με ένα wiim ultra και ένα marshal θα έχεις στερεοφωνικό ηχο. Έτσι το έχω δουλέψει και εγω με το JBL Xtreme 3. Αν τρέξεις και το room treatment του wiim θα δεις αρκετή βελτίωση.
Απλά σκεφτόμουν για 2 Marshall, όπως βάζουν 2 Sonos αλλά ίσως να είναι και λάθος σκέψη.
Πως μπορώ να συνδέσω το mac-mini με το wiim ultra, ώστε η έξοδος hdmi του mac mini να στέλνει εικόνα στην τηλεόραση (δεν εχει earc) και ήχο στο wiim ultra?
symos
You're not worthy!
Ένα audio extractor ίσως θα ήταν μια λύση, Bluetooth μια άλλη, αλλά θα ήταν χρήσιμο να μας πεις τι θες να πετύχεις. Και γιατί θες ο ήχος να πηγαίνει στο wiim. Το χρησιμοποιείς και ως DAC;
ναι το χρησιμοποιώ σαν πρό σε ένα συστημα με ενεργά kali και sub, έκανα room correction και το γραφείο πεταει απο ήχο. Τώρα ολη η φασαρία ξεκινά επειδή δεν βρήκα τρόπο μέχρι στιγμής να προσθέσω το app της berliner philharmoniker στο wiim για να μην την τρέχω μεσω bluetooth. Οπότε ξέθαψα το mac mini για player, to opo;io όμως δεν βλέπει to wiim σαν dac.
symos
You're not worthy!
Πάλι δεν κατάλαβα ακριβώς.
Η εικόνα σε ενδιαφέρει ή όχι;
Αν ναι, πως θα εξυπηρετούσε αν το app έμπαινε στο wiim; Αφού δεν έχει έξοδο εικόνας.
Αν όχι, γιατί δεν βάζεις το app στο κινητό και να παίζεις μέσω Chromecast;
μεσω hdmi earc?
βρήκα μία λύση με ένα αρχαίο prodigy dac που είχα και έχει είσοδο usb και εξοδο optical, οπότε με μια οπτική ίνα έκανα την σύνδεση και το αποτέλεσμα είναι καλύτερο του αναμενόμενου.
dapost
Rehdeko & Harbeth lover
Τί ωραίο μηχανάκι! Το έχω αρκετούς μήνες και είναι απόλυτα ικανοποιημένος. Χρήση ως στρημερ, σύνδεση USB με ντακ.
Ευχρηστία 10/10. Εφαρμογή με ότι χρειάζομαι, π.χ. add to tidal playlist, και που δεν κολλάει, δεν κρασαρει, δεν αργεί να δει το στρημερ, κλπ. Τηλεκοντρόλ με όλα τα βασικά ώστε να μη χρειάζεσαι συνεχώς την εφαρμογή.
Και τέλος, ήχος καλύτερος από macos players, πέρα από ψυχαναγκασμό και πλασημπο.
Παναγιώτης55
