300
ΔΙΑΒΑΣΤΕ ΤΟ ΠΑΡΑΚΑΤΩ ΑΡΘΡΟ
ΑΚΟΜΑ ΔΕΝ ΕΙΔΑΜΕ ΤΗΝ ΤΑΙΝΙΑ ΚΑΙ ΥΠΑΡΧΕΙ ΠΕΡΙΠΤΩΣΗ ΝΑ ΓΙΝΕΙ ΚΑΙ SEQUEL ΑΥΤΗΣ.
300 Sequel Very Likely, But Not 100% Confirmed
by Alex Billington
Although no direct questions on a sequel came about during press events for 300 yesterday, and especially given that Frank Miller was absent due to an injury, confirmation on a possible “sequel” to 300 was tough to get. However, producer Mark Canton did speak very briefly about the possibly. They are obviously currently waiting to see how successful 300 will be at the box office and then from there are planning where to go next.
However, Mark did say the following: “If it all works out I'm sure we'll all be scrambling Zack [Snyder] and Frank Miller and everyone to figure out exactly ‘301′. Where there's a will there's a way, honestly. And the thing about Frank, you just don't know - he has a lot of stories he may want to tell that may be associated or not, but we just want this one to satisfy first.”
Another interesting observation is that as the other press member was asking her question at the press conference, she stated first, “but you know there's no way to make a ‘301′” and Mark quietly said, ‘well…’ before she continued asking the remainder of her question. From the sounds of it, I assume it is likely and very possible, especially with what I overheard yesterday. And of course, Frank himself will have to create a new graphic novel first anyway, so confirmation is mostly up to him.
Στο φεστιβαλ του βερολινου χτες βραδυ εγινε ουσιαστικα η επισημη πρωτη παρουσιαση του 300 σε μια καταμεστη αιθουσα 1700 ατομων που χειροκροτουσαν για πολλη ωρα κατα την διαρκεια προβολης αλλα και μετα την θεαση της ταινιας.
lakiss51
Απάντηση: 300
Aυτες οι "κομ σι-κομ σα" στις φωτο ειναι οι ...δημιουργες του φιλμ; α, σκετο Σπαρτιατικο θαναι τοτε!
Όντας ένας από τους 1700 – όχι ακριβώς δηλαδή γιατί εγώ το είδα το προηγούμενο βράδυ - που ανέφερε ο Δημήτρης, θα ήθελα να πω πως δεν έγινε ακριβώς έτσι όπως το περιγράφει. Είναι κάτι παρόμοιο με αυτό που συνέβη στην αντίστοιχη πρώτη προβολή του Fountain στην Βενετία που προς τα έξω βγήκε πως το φιλμ χιουχαίστηκε του θανάτου, ενώ στην ουσία υπήρξε στο φινάλε ένας ανεγκέφαλος, που εξέφρασε την αρνητική άποψη του, πολύ φωναχτά, διόλου κομψά και κατά την προσωπική μου γνώμη εντελώς ηλίθια. Αφού μέσον υπηρετούσε γιατί δεν το έκανε εκεί?
Η συγκεκριμένη πρώτη που παρακολούθησα, όντας δημοσιογραφική προβολή δεν θα μπορούσε να αποτελέσει κριτήριο για τους δημιουργούς της, από την στιγμή που οι περισσότεροι εκ των θεατών της, μέσα στο δεκαήμερο περίπου της Βερολινέζικης διαδρομής τους, επιθυμούσαν να παρακολουθήσουν κάτι αμιγώς καλλιτεχνικό, που δίχως καμία αμφιβολία το 300 στο σύνολο του δεν εκφράζει.
Έχω ξαναπεί και στο παρελθόν πως είναι ανήκουστο να σχολιάζουμε ένα φιλμ με το αν και κατά πόσο στέκεται στην ιστορική πραγματικότητα. Κάποιος που έχει αντίθετη άποψη περί των όσων λέει για παράδειγμα ο Αλέξανδρος, η Τροία, το Περλ Χάρμπορ, το JFK ή και τώρα ο Λεονάιντας, δεν έχει παρά να πάρει μια handycam στο χέρι και να αποτυπώσει σε «φιλμ» την αλήθεια κατά τας γραφάς. Οι συγκεκριμένες ταινίες είναι κάτι το εντελώς διαφορετικό. Δίνονται – κάτι σαν μπαλάκι – στον θεατή με το σκεπτικό, πάρτην, θρονιάσου όσο πιο αναπαυτικά μπορείς στο χυτό σου κάθισμα, πιες κι έναν σκασμό σόδα και όταν φτάσει η ώρα βγάλε και ένα βογκητό, άντε κι ένα παλαμάκι για το ονόρε. Εκεί ανταποκρίνονται λοιπόν οι ψιλο-θριαμβευτικές εκδηλώσεις της προβολής που ακολούθησε της πρώτης πρώτης, δηλαδή αυτής του κοινού. Του αποτελούμενου από εφήβους κυρίως, που παρακινούμενοι από σωρεία πρακτικού μάρκετινγκ, είχαν στήσει αντίσκηνο στην πλατεία Ποτσντάμερ για να βγάλουν εισιτήρια μην τυχόν και χάσουν την κινηματογραφική επανάσταση.
Το μπαλάκι το πήραμε για τα καλά από τους πληγωμένους – επειδή φίλε μου Δημήτρη και το χειροκρότημα της λαικής τους ένοιαξε, αλλά και το ποδοκλώτσημα της δημοσιογραφικής επίσης – συντελεστές της ταινίας, όπως εμφανίστηκαν στην συνέντευξη τύπου. Την πιο εκούσια άδεια από κόσμο συνέντευξη που παρέστην κατά την διάρκεια των εκδηλώσεων. «το 300, λέει ο σκηνοθέτης (κατά την ταυτότητα και μόνο) είναι η κινηματογράφηση του κόμικ». Και κάπως έτσι πρέπει να το δούμε το φιλμάκι. Λίγο, υπερβολικά λίγο ως ταινία, σχεδόν ανύπαρκτο σαν σενάριο, αφού τα διαρκή αούα και τα ουαου, μάλλον το καθιστούν σαν υποψήφιο για Όσκαρ μη αγγλόφωνης παραγωγής, απίθανο τεχνικά για να τρέξουν όλοι οι hitechοδαυλοι να το αγοράσουν μόλις βγει σε Bluray και αυτό είναι όλο. Ένα κάτι που γρήγορα τουλάχιστον στην δική μου μνήμη θα ξεχαστεί.
Και τι θα μείνει να θυμάμαι? Το τι θόρυβος προηγήθηκε, το τι ΜΜΕ χαμός κινήθηκε παράλληλα του και η απορία μου αν ποτέ κανείς θα αποφασίσει εν τω Χόλιγουντ να κινήσει τις διαδικασίες για να δούμε κάτι ελληνικό, σε πιο ελληνική φόρμα. Αν και μας βλέπω να μένουμε άπαντες με το αποτέτοιο του Στέλιου στο χέρι – όχι του Γιαννακόπουλου, του άλλου των 300 που ευτυχώς που η μάχη των Hot gates δεν έπεσε στις 26 Νοεμβρίου, γιατί θα έπρεπε να κάνει και πάρτι για την γιορτή του.
Όσοι επιμένουν καλά και σώνει πάντως να δουν την πραγματική ιστορία του Λεωνίδα, του Μολών λαβέ και των Σπαρτιατών του, το πραγματικό 300 ήδη βρίσκεται στις ελληνικές αίθουσες από χθες και ακούει στον τίτλο Letters From Iwo Jima…
PS – Στο προπαγανδιστικό ύφος της ταινίας, όπως έκαναν πολλοί συνάδελφοι, δεν αναφέρομαι καν. Θα είναι ιδιαίτερα απρεπές να κάνω κάτι τέτοιο, δίνοντας στο 300 την ταυτότητα ολοκληρωμένου πονήματος, που έχει κάτι να πει – και η προπαγάνδα λόγος είναι και μάλιστα πανίσχυρος – αντί να κάτσω δίχως πολύ σκέψη και ΦΥΣΙΚΟΤΑΤΑ να το προτείνω ανεπιφύλακτα σε όσους θέλουν να ξεφύγουν από τις συνεχείς επαναλήψεις του Μπομπ Σφουγγαράκη, του Παρά Πέντε και της Μαρίας της Άσχημης!
Απάντηση: 300
Σε συνδυασμό με τα παραπάνω αλλα και της βόλτας μου από το cine.gr που αναφέρεται στα σχετικά περί προπαγάνδας , μου έκανε εντύπωση το γεγονός πως ακόμα και με την coca cola στο χέρι μερικοί είναι αδύνατον να χαλαρώσουν.
φιλε rosebud κατ αρχην ευχαριστουμε που μοιραστηκες μαζι σου τις εντυπωσεις απο την 1η προβολη του 300. :cool_4: :cool_4: :cool_4:
το quote που φαινεται παραπανω με βρισκει απολυτα συμφωνο.
ναι θα ειναι ψυχαγωγικη , τα special effects θα βγαζουν ματια , η καλλιτεχνικη της παρουσια θα φερει διχογνωμιες πιστευω αλλα θα πρεπει να την δουμε ως ενα προιον του holllywood προορισμενο για τα multiplex.
Oποτε λογικο ειναι οι εφηβοι να κατακλησουν την αιθουσα προβολης .
Αρα θα παμε με χαλαρη διαθεση να δουμε την ταινια και να δουμε πως μπορει ενα comic βοηθουμενο απο την τεχνολογια μπορει να γινει κινουμενη εικονα.
p.s.
Kανενα ζουμερο spoiler απο την ταινια εχουμε ??? :crazy_3:
ΠΕΡΙΜΕΝΟΥΜΕ ΚΙ ΑΛΛΕΣ ΑΠΟΚΛΕΙΣΤΙΚΕΣ ΑΝΤΑΠΟΚΡΙΣΕΙΣ ΣΟΥ ΑΠΟ ΕΠΕΡΧΟΜΕΝΕΣ ΤΑΙΝΙΕΣ ΓΙΑ ΕΝΗΜΕΡΩΣΗ ΟΛΩΝ
και κατι εγκυκλοπαιδικο ...
γνωρίζετε μήπως ποια ήταν η ηλικία του Λεωνίδα κατά την μάχη στις Θεμοπύλες?
(χχ)?
Κώστας Φ.
Απάντηση: Re: 300
(χχ)?
Η μάχη στις Θερμοπύλες έγινε το 480 π.Χ. και ο Λεωνίδας πιστεύεται ότι γεννήθηκε το 540 π.Χ. ή λίγο αργότερα - άρα ήταν σίγουρα πάνω από 50. Γενικώς λένε ότι πρέπει να ήταν από 50 εώς 60.
Ένα link που βρήκα στα γρήγορα: Click
Re: Απάντηση: Re: 300
Σωστά !!
Από μαρτυρίες του Ηρόδοτου η ηλικία του ήταν 62 !!
jimkalo83
