DACs - τελειωμό δεν έχουν
vlasis
Φωτογράφος!
Rockna audio -
WAVEQUEST D/A CONVERTER
http://www.rockna-line.com/products-Wavequest-DA.html
DIGITAL PROCESSOR :
  • MEMORY BASED ADPLL : 0.3 ps jitter (fixed mode setting)
  • ADPLL loop corner frequency : 0.5 Hz
  • DIGITAL FILTER : 2x-32x (max. 1.536 Mhz output rate), can be bypassed for NOS operation
  • DIGITAL FILTE TYPE : polyphase sin x/x interpolation , 4000 taps
  • DIGITAL FILTER STOPBAND ATT : -145 dB
  • DIGITAL FILTER PASSBAND RIPPLE : 0.5 udB max.
  • INTERNAL PRECISION : 63 bit
  • DITHER : 4 bit, gaussian ultrasonic
  • VOLUME CONTROL : custom multiplier array 256 steps
OUTPUT :
  • THD+N, 0 dB : 0.006%
  • DYNAMIC RANGE : 125 dB (A-weighted)
  • S/N RATIO : 140 dB (A-weighted)
  • IMPEDANCE : 5 ohm
  • MAX. OUTPUT : +/- 5 Vpp
vlasis
Φωτογράφος!
La Scala MKII D/A Converter
High performance proprietary DFD (Direct From Decoder) digital decoding without digital filter for purest digital signal quality
• Custom designed discrete circuit with high-speed photocouplers for Galvanic and magnetic isolation between Digital stage and Analog DAC ground
• Jitter free digital interface AQlink (I2S protocol), uncompromising digital connection to
La Diva cd transport
• Precision sign magnitude R2R ladder DAC with 4 Burr-Brown PCM -1704K arrayed in a true differential dual mono configuration
• Transformer current / voltage conversion (I / V)
• Zero S/PDIF Jitter design, digital receiver stage PLL (phase locked loop) technology
• High-performance AQ Discrete Regulator (MOSFET, J-FET, BJT) for analog and digital DAC’s power supply
• Valve-Mosfet direct coupling analog stage in pure class-A without negative feedback
• MOSFET Virtual battery circuit for analog anode supply
• Soft-start power up for extended tube life
• etherCON RJ45 (AQlink) input connection, employs CAT6 cable can connect both RJ45 and professional etherCON RJ45
• 2 separate low noise power transformers, one for the analog and one for the digital section
Regulated DC filament supplies with soft start for tubes
• Fully discrete analog stage, not even a single Op-Amp is used
• Proprietary USB Firmware / driver :
Apple MAC OS - Linux OS : USB asynchronous native support, no need to install drivers software
Fully upgradeable asynchronous USB module with resolution up to 24 bit and 192 KHz, operates with computers running OSX 10.7 and above, WINDOWS XP, 7 and 8 ASIO - WASAPI bit perfect high-speed
• Digital phase selector on front panel
http://www.aquahifi.com/la_scala.html#prettyPhoto_PhotoGallery1[PhotoGallery1]/1/
Βλάση μου γιατί το λες αυτό;
Παρέα με τα καινούργια της Naim και δυο τσίλικα ηχειάκια πας στα 500 χιλιάρικα.
Πολλά είναι;:headbang::headbang:
Gojakla
Αρχαιολάγνος πιουριτανίστας
Πέραν πλάκας πάντως... υπάρχουν κάποιοι που δεν ιδρώνουν με τα ποσά αυτά...
Πιθανότατα όμως δεν μένουν στο Ελλάντα...
Νομίζω είναι σαφές πως απευθύνονται σε πολύ ιδιαίτερο κοινό.
Αμέσως να μας καρφώσεις εσύ....
Κρύβε λόγια παιδάκι μου....
Πέραν πλάκας πάντως... υπάρχουν κάποιοι που δεν ιδρώνουν με τα ποσά αυτά...Πιθανότατα όμως δεν μένουν στο Ελλάντα...
"...they plan to make only 24 per year."...εντάξει....24 καθυστερημένους τον χρόνο...μμμ...ψιλοεύκολο μου φαίνεται...παίζει να βλέπω τόσους την ώρα στην τηλεόραση εδώ...
Δηλαδή 2 τεμάχια το μήνα.
Δεν είναι κι άσχημο ως έσοδο τριακόσια-τετρακόσια χιλιάρικα μηνιαίως.
Και να δεις που θα υπάρξει λίστα αναμονής...
Όχι ψιλοεύκολο απλώς....,πανεύκολο...
Gojakla
Αν "μελετήσετε" το πώς χειριστήκανε την καμπάνια τους (για το μικρομεσαίο DAC τους, Geek Pulse) μέσω του crowdfunding site Indiegogo, θα δείτε πως το marketing τους είναι άριστο.
Μερικές φορές σκέφτομαι μπας και πήραν στελέχη της Apple... :laugh:
Ήταν άριστο..μέχρι πριν λίγο...
Τώρα έχει αρχίσει η γκρίνια και κράξιμο,αργούνε.
Βέβαια το χρήμα έχει πάει τσεπέο,ενα μύριο και,οπότε στα τέτοια τους θα μου πεις.
Ποιος άλλος έβγαλε ένα μύριο από ντακ χωρίς καν να το έχει κυκλοφορήσει στην αγορά;
Για να δούμε,θα ακούγεται τουλάχιστον ή θα γελάσει ο κάθε πικραμένος;
Gojakla
Δεν έχει πέσει κράξιμο από κανέναν από τους ΣΥΜΜΕΤΕΧΟΝΤΕΣ.
Κράξιμο έχει παίξει από τους "έξω".
Επίσης, δεν υπάρχει καθυστέρηση.
Τα Pulse αναμένονται από Απρίλη αν δεν κάνω λάθος... και τα μηχανάκια με τα upgrades από Ιούνιο...
Μα Γενάρη δεν έλεγαν για το μικρό όταν ξεκίνησε το παραμύθι;
Gojakla
Για το Geek Out θα λές...
Δεν το έχω παρακολουθήσει καθόλου το μικρό ρε Σωκ...
Ναι,το out,Γενάρη είχαν πει,το επιβεβαίωσα απέναντι,από τα παιδιά που το έχουν προπληρώσει.
Και τώρα λένε Μάρτη και αν.
Όπως καταλαβαίνεις η κατάσταση οδεύει στο μη-ρόδινο από εδώ και πέρα.
Ειδικά από την στιγμή που η αγορά δεν είναι εγγυημένη,δωρεά θεωρούνται τα λεφτά που δόθηκαν.
Gojakla
Συμφωνώ απολύτως.
vlasis
Φωτογράφος!
April Music new D700 DAC with DSD
New DAC from April music implementing the ES9018 Sabre reference DAC Chip. With this model April music is trying to compete with the upper echelon high-end DAC's. More tech info after the jump.
1 AES/EBU, 2 COAX, 2 OPT, 1 USB 2.0,
1 AM-Link (High Speed April Music Link)
PC USB Link : Asynchronous using RISC Processor & CPLD
Mac OSX 10.6+
Linux with UAC2 Compliant kernel
Windows OS
SAMPLING FREQUENCY : AES/EBU, COAX, OPT up to 192kHz
USB PCM 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384kHz
USB DSD64, DSD128, (On Windows up to DSD256, DSD512)
ANALOG OUTPUT : 1 RCA, 1 XLR, 1 HEADPHONE
OUTPUT SIGNAL LEVEL : Unbalanced 2.4 Vrms
(fixed, variable selectable) Balanced 4.8 Vrms
OUTPUT IMPEDANCE : 50 Ohms
HEADPHONE : 1/4” HEADPHONE JACK,
Output Impedance 0.1 Ohms at 50 Ohms
DAC : ES9018S Sabre32 Reference Audio DAC
Dynamic Range 133dB
THD+N -120dB
FRONT DISPLAY DEVICES : 14 Segment Alphanumeric LED, 7 Digits
Full Function Remote Control
LINE VOLTAGE : 100 - 117 VAC/ 220 - 240 VAC
FREQUENCY : 50-60HZ
George Markop
