Τα Δυο ΚΑΘΑΡΟΑΙΜΑ...(HARBETH 40.1)
Απάντηση: Τα Δυο ΚΑΘΑΡΟΑΙΜΑ...(HARBETH 40.1)
BBC Monitor History(LS 3/5).
The concept of this speaker was to suit those BBC environments where monitoring on headphones was not satisfactory and yet there wasn't sufficient room for a 'Grade I' monitor. A Grade I monitor can be used for critical tonal balancing of programme material, setting of microphone positioning, etc. Current Grade I monitors are the LS5/8 and LS5/9. A grade II monitor may be used for checking the quality of programme, but balance and mic positioning are normally Grade I-checked unless there is no alternative. It was recognized that what would be required was a small Grade II unit with some sacrifice of bass response and loudness reproduction, this being justified for the sake of achieving compactness. The likely users were, for instance, the production control areas of television OB control vans, where there producer needs to listen at a lower level than that used for the actual mixing.
Pictured is the model speaker the BBC used from 1972 until 1980, which represented a major step in the modeling process. Although it had its limitations, primarily in terms of its tonal quality and maximum power handling, components of this small loudspeaker were found to be of a sufficiently high quality to help fulfil the demand for the unusually compact monitor needed in outside broadcast use. This was therefore packaged and called the LS3/5 and showed the model experimenters to have achieved good results.
Acknowledgements
I am indebted to BBC Engineering for ensuring the accuracy of this article. Within the BBC the work of two people, T Somerville and D E L Shorter, must be considered as having laid the foundation for current standards. The particular work on the LS3/5A was carried out by Messrs H D Harwood of Research Department and both M E Whatton and R W Mills of Designs Department
Ενδιαφέρον άρθρο.
Καλά ρε παιδιά δεν σας έθιξε και την οικογένειά σας, για το ηχείο μίλησε ο άνθρωπος! Όπως έχετε το δικαίωμα να λέτε την άποψή σας δημόσια ότι είναι ένα κορυφαίο ηχείο, έτσι έχει και δικαίωμα κάποιος άλλος να λέει το αντίθετο!
Εμένα πάντως μου αρέσει το συγκεκριμένο ηχείο, αν και απόλυτα πιστό αναπαραγωγέα δεν το λέω...
για πες μου φίλε ep_blabla .... έχω το δικαίωμα να πω πως η εκκλησία του Αγίου Μάρκου στη Βενετία είναι ένα μπορντέλο με κόκκινα φωτάκια απ' έξω και μέσα γεμάτο χοντρόβυζες πόρνες ??? .... δεν θίγω κάποια οικογένεια άμα το πω... άρα μπορώ να το πω έτσι ??? Έχω το δικαίωμα... Και ξέρεις ε... στην συγκεκριμένη εκκλησία δεν έχω πάει ποτέ !!!
Φυσικά κι έχεις το δικαίωμα φίλε μου SU_ξουμουξου...
ΥΓ. αν ήταν έτσι πάντως θα είχα μεγαλύτερο κίνητρο να πάω...:116:
Απάντηση: Re: Τα Δυο ΚΑΘΑΡΟΑΙΜΑ...(HARBETH 40.1)
Επειδή κάποιοι κάνουν 'πλακιτσα' περί Harberth και καυσόξυλων θα ήθελα να υπενθυμίσω ότι όταν κάποιοι άνθρωποι στην Αγγλία, μηχανικοί ήχου με μεράκι είχαν την τεχνογνωσία και διέθεταν την ενέργεια τους για να έχουμε εμείς το BBC μόνιτορ, και τα μετέπειτα versions, εμείς εδω το μονο που τους προσφέραμε ήταν το φραπογαλο μας στα ελληνικά νησιά. Λοιπόν λίγο σεβασμός, δεν βλάπτει, σε ανθρώπους με άποψη που είχαν την ιδέα το μεράκι, κατείχαν την τέχνη, και προπαντός δούλεψαν συστηματικά και με συνέπεια για να την υλοποιήσουν. Μερικοι – μερικοί με απόψεις τύπου ‘Coyιa’ δεν είναι ανάγκη να μας περιχύνουν με τα φραπογαλα τους.
Eχω την εντύπωση οτι πίνει ελληνικό.
Συμφωνώ.
Ειμαι κατοχος Harbeth 40.1 και p3esr και ενα εχω να πω.Ειναι ηχεια αποδεχτα απο μουσικοφιλους σε ολον τον κοσμο,αρα η δικη μου αποψη περισευει.Οσο για αποψεις τυπου καυσοξυλου καλυτερα να αλλαξετε η να καθαρισετε τ'αυτια σας μπας και απολαυσετε σωστη μουσικη!Αληθεια ποσοι απο εμας γνωριζουν τι σημαινει σωστος ηχος;Ας αρχισουμε να μαθαινουμε να ακουμε σωστα
Σας παρακαλω.....
Re: Απάντηση: Τα Δυο ΚΑΘΑΡΟΑΙΜΑ...(HARBETH 40.1)
Και τι έγινε που έχεις και ακούς τα 40.1 φίλε Λεό... Άσε να τα πουν καλύτερα εκείνοι που τα γνωρίζουν από τις φωτογραφίες...
Όχι δε μπορείς, γιατί αφ'ενός μεν προσβάλεις τα χρηστά ήθη και αφ'ετέρου θεωρείται προσβολή θρησκείας.
Εκτός και αν τα harbeth είναι θρησκεία, οπότε σε προκάλεσαν.
Alan A. Shaw said:
Despite ones preconceptions that 'thick panels must be better' in the critical middle frequencies, it is clear that the opposite is in fact true: 'thin is much better' - thin panels are a better solution to controlling panel resonances, and making a speaker box that doesn't sound boxy. Thin can be tuned - thick can't.
BBC-style thin-wall cabinets. Why so special?
http://www.diyaudio.com/forums/mult...ad-i-found-lossy-cabinet-designs-harbeth.html
Μμμμμμ!!!! Γιατι το ξαναξεκνησες το θεμα ??? Ειχανε ησυχασει, τωρα????
:203:
το θεωρησα ενδιαφερον (εκτος και αν ειχε αναρτηθει ξανα), δεν ειναι αναγκη να γινει ο γ' παγκοσμιος:114:
Ναι, καλά! Και μου έφαλες φυτίλια τώρα! Δηλαδή, άμα θέλω να παίξω Ζαμπέτα με Harbeth, πού θα τα τιουνάρω; Φα ματζόρε ή λα μινόρε;
^^^ποσο χοντρα καλωδια εχεις?:143:
πως κρινετε αυτα που λεει ο μπαρμπα-Shaw?
To μέσα είναι πολύ χοντρό! Και μακρύ! Περισσότερα δε μπορώ να σου πω, είναι λεπτό το ζήτημα.
zakman35
Να με σχωρνάτε αλλά με τέτοια υλικά στο κροσόβερ και καλωδιάκια πιασμένα με κλιπσάκια, καθαρόαιμο δεν το λες ένα ηχείο...
Ναι τα κλιπσάκια σε πείραξαν, για τους ΜΚΤ και τα πηνιάκια με πηρίνα δεν έχεις να πεις κάτι?
Είστε άσχετοι και υσωπαιδοτικοί και δεν ξέρετε από αγγλικό ήχο και δεν σας αρέσουν τα καθαρόαιμα. Άντε τώρα!
zakman35
Αστραχάν σου λέω.
JAndronikos
