vlasis
Φωτογράφος!
Απάντηση: DACS....και τελειωμο δεν εχουν !!!!!!!!!!!!!!!
AURALiC VEGA
για διαβαστε παρακαλω......κατι εχει να μας πει.........
With Sanctuary Audio Processor as heart, AURALiC introduces several cutting-edge technology for VEGA: 'Megahertz upsampling' algorithm processes all PCM music to 1.5MHz in 32bit; 'Femto Master Clock' provides an ultimate clock precision with jitter only 82 femtoseconds(0.082 picoseconds). Binding with other AURALiC's patented technologies such as 'ORFEO Class-A module' and discrete 'Purer-Power™ solution', VEGA will bring high resolution music playback experience to climax.
VEGA supports all high resolution music formats including DXD(352.8KS/s, 384KS/s in 32bit) as well as DSD stream at 2.8224MHz and 5.6448MHz. Five digital inputs include AES/EBU, Coaxial(set of two), Toslink and USB. The balanced and single-ended analog outputs can connect to power amplifier directly, adjusting volume in digital precision without dynamic loss. VEGA has six built-in filter modes allows its user to customize according to different music formats, tuning sound best to personal preference.
"VEGA is an unique design, It not just supports all high resolution music format, but also powerful in its advanced function. It is the approach to real high-end that most enthusiastic audiophile long for", said Xuanqian Wang, "like other creation from AURALiC, the ingenious design of VEGA bringing you enjoyment in both aural and visual".
Suggested retail price: VEGA: $3,499/ €3,299(incl. VAT)
Εγώ στην περίπτωσή μου θα ήθελα (2) αναλογικές εισόδους..........."τι άλλο θέλει κανείς;......
Και εσυ βρε Γιανναρε πως το εβγαλλες το συμπερασμα αυτο?Using the latest 32Bit Sabre DAC technology, it delivers up to 384kHz PCM and 64x and 128x DSD playback.
Παπαριες μαριτσα μου.
Αν μιλάς από άποψη υλικών,πολλά την δικαιολογούν..Μα φυσικά! Πιστεύεις δηλαδή πως τα άλλα έχουν κάποιον χειροπιαστό λόγο για να δικαιολογούν την 4ψήφια τιμή τους;
το οτι πληρωνουμε εκτος υλικων και λιγο brand name, ειναι γνωστο...ας χρεωνει ο καθενας οπως γουσταρει...ελευθερη οικονομια ειμαστε...Μα φυσικά! Πιστεύεις δηλαδή πως τα άλλα έχουν κάποιον χειροπιαστό λόγο για να δικαιολογούν την 4ψήφια τιμή τους;
δλδ vet, λες οτι ειναι καλυτερα αν καποιος απλα "ξυσει την επιφανεια" και το θελει για ν αναπαραγει αρχεια hd μεσω του pc και μεχρις εκει, ειναι περιττο να δωσει ακομα και αυτο το σχετικα μικρο ποσο σε σχεση με αλλα και να παρει μια "καρτα ηχου"?Αν η USB του δεν είναι ασυγχρονη θα παίζει χειρότερα από τα γνωστά οικονομικά dac.
Ένα άλλο " ευαίσθητο σημείο " σε αυτη την κατηγορια είναι το volume.
Ήταν το μοναδικο μειονέκτημα της impactt twin που ειχα.
κατσε βρε αγορι,δλδ vet, λες οτι ειναι καλυτερα αν καποιος απλα "ξυσει την επιφανεια" και το θελει για ν αναπαραγει αρχεια hd μεσω του pc και μεχρις εκει, ειναι περιττο να δωσει ακομα και αυτο το σχετικα μικρο ποσο σε σχεση με αλλα και να παρει μια "καρτα ηχου"?
πχ εσυ που ασχολεισαι με ενεργα και εχεις και καρτα ηχου, τη metric, σε ποιο κομματι της αλυσιδας τη χρησιμοποιεις?...χρησιμοποιεις και εξωτερικο dac, εκτος της metric?...εχει ασυγχρονο usb η συγκεκριμενη?
υ.γ. ψαχνω να βρω και το post που ειχαν γραψει για τις "σηκωμαρες"μετα απο τη χρηση metric, μπας και βγαλω ακρη
