Στη γνωστή "διαμάχη" μεταξύ ενεργών και παθητικών ηχείων, βρίσκω εξαιρετικά χρήσιμη τη σύγκριση μεταξυ ίδιων ηχείων στις δυο διαφορετικές μορφές τους.
Εδω http://www.theabsolutesound.com/articles/atc-scm19a-loudspeaker/?page=2
έχουμε τους τυπικούς χαϊεντάδες του The Absolute Sound να ανακαλύπτουν τα ενεργά και να κάνουν τη σύγκριση, με τον χαρακτηριστικό τρόπο περιγραφής, (και χωρίς μετρήσεις
Σύγκριση μεταξύ ενεργού και παθητικού SCM40 της ΑΤC:
The idea of an active loudspeaker intrigued me but what really sparked my interest was an ATC demonstration of active versus passive at CES 2015. It was a shootout between the SCM40 and its active cousin the SCM40A—otherwise identical three-way, acoustic-suspension floorstanders. The latter, however, was equipped with an internal electronic crossover splitting the signal into tri-amplified power. The former was the traditional passive design and received comparable power from ATC amplifiers and traditional speaker cabling. The differences were startling. Improved imaging, a vastly greater sense of dimensionality and immersion, and a level of low-frequency control that said to me in no uncertain terms “there is no going back.”
Και παρακάτω συγκρίνοντας το παθητικό με το ενεργο 20αρι της ATC:
The key differences, and I do mean differences with a capital D, are the 19A’s improved imaging, immersiveness, and tight-fisted low-end control. The active version sounds like a stronger, more muscular version of the passive one—as if the little SCM19 has spent the last few months at the gym. It now resolves more ambient cues, and with a broader and more colorful palette of timbre and texture to draw from.
και
In the same way an Olympic gymnast “sticks the landing,” there is a grounding to the orchestral soundstage that once heard is difficult to forget.
Γιά όσους προτιμούν τις "εμπειρίες" απο τις μετρήσεις...
και
