Ενεργά ηχεία
Στη γνωστή "διαμάχη" μεταξύ ενεργών και παθητικών ηχείων, βρίσκω εξαιρετικά χρήσιμη τη σύγκριση μεταξυ ίδιων ηχείων στις δυο διαφορετικές μορφές τους.
Εδω http://www.theabsolutesound.com/articles/atc-scm19a-loudspeaker/?page=2
έχουμε τους τυπικούς χαϊεντάδες του The Absolute Sound να ανακαλύπτουν τα ενεργά και να κάνουν τη σύγκριση, με τον χαρακτηριστικό τρόπο περιγραφής, (και χωρίς μετρήσεις :D) :
Σύγκριση μεταξύ ενεργού και παθητικού SCM40 της ΑΤC:
The idea of an active loudspeaker intrigued me but what really sparked my interest was an ATC demonstration of active versus passive at CES 2015. It was a shootout between the SCM40 and its active cousin the SCM40A—otherwise identical three-way, acoustic-suspension floorstanders. The latter, however, was equipped with an internal electronic crossover splitting the signal into tri-amplified power. The former was the traditional passive design and received comparable power from ATC amplifiers and traditional speaker cabling. The differences were startling. Improved imaging, a vastly greater sense of dimensionality and immersion, and a level of low-frequency control that said to me in no uncertain terms “there is no going back.”
Και παρακάτω συγκρίνοντας το παθητικό με το ενεργο 20αρι της ATC:
The key differences, and I do mean differences with a capital D, are the 19A’s improved imaging, immersiveness, and tight-fisted low-end control. The active version sounds like a stronger, more muscular version of the passive one—as if the little SCM19 has spent the last few months at the gym. It now resolves more ambient cues, and with a broader and more colorful palette of timbre and texture to draw from.
και
In the same way an Olympic gymnast “sticks the landing,” there is a grounding to the orchestral soundstage that once heard is difficult to forget.
Γιά όσους προτιμούν τις "εμπειρίες" απο τις μετρήσεις...
dapost
Rehdeko & Harbeth lover
+1!
Χμ, ΟΚ, χμ, τόσο μεγάλες διαφορές άκουσε ο αγαπητός ρεβιούερ της αγαπητής φυλλάδας; Μάλιστα...
Τέλος πάντων, μία πιο σε βάθος σύγκριση όμοιων ενεργών - παθητικών, με κάποιες (λίγες) μετρήσεις, υπάρχει εδώ:
http://studio-hifi.com/images/ATC_SCM50_aktiv-passiv-Stpl-4-2011.pdf
καθώς και λίστα με όλες τις δοκιμές των προιόντων της γνωστής φίρμας εδώ:
http://studio-hifi.com/review.php?selected=3&lang=en
Shepherd
Μόνιμος
Από την δική μου εμπειρία ,μετατροπή παθητικού σε ενεργό, ναι οι διαφορές είναι μεγάλες.
Αν μπορείς να το πεις έτσι.... είναι σαν να έχεις ενα ηχείο των 1000€ και να μεταμορφώνεται σε ηχείο των 2000€.
Φεύγει η ''κουρτίνα'' εντελώς και το πιο σημαντικό είναι ότι το ηχείο γίνεται ευκολοδήγητο για τον ενισχυτή.
Το μοναδικό μειονέκτημα είναι ότι υποχρεώνεσαι στο dac του κρος
Το οποίο είναι πλεονέκτημα, διότι σε βγάζει από τη λογική των χροιων των διαφορετικών ντακ.
Όπως και γενικά μιλώντας το ενεργό ηχείο, σε βγάζει από την λογική των χροιων των καλωδίων διασύνδεσης και των ενισχυτικών σταδίων.
Δηλαδή, σε μαθαίνει να σκέφτεσαι λογικά.
Shepherd
Μόνιμος
Ναι, κατάλαβα πως το λες αλλά θα μπορούσε να υπήρχε μια σύνδεση I2S για να συνδέσεις άλλο ντακ
Ναι, κατάλαβα πως το λες, αλλά δεν έχει λογική (στο χώρο αυτό των ενεργών) η σκέψη σου. ;)
γιατί δεν έχει λογική;
Δεν κουράζομαι να τα γράφω (σε απειλώ). :D
Η λογική (της παράνοιας) του χάι εντ, είναι:
- θέλω αυτό το ηχείο γιατί είναι όμορφο και ταιριάζει στο σαλόνι μου, βάση του προσωπικού μου γούστου και αισθητικής. Επίσης, μου άρεσε εκεί που το άκουσα, στην τάδε έκθεση.
- θέλω να μην ασχολείσαι με το σαλόνι μου, σιγά που θα σου πω λεπτομέρειες για την προσωπική μου ζωή κιόλας! Βρε ουστ αποδώ..
- θέλω αυτόν τον ενισχυτή, γιατί έχει ωραίες χροιές και ζυγίζει και 128 κιλά
- θέλω αυτό το καβλώδιο, γιατί το άκουσα και μου άρεσε, υπέροχα πρίμα, τι να σου λέω..
- θέλω αυτό το ντακ, γιατί παίζει παπάδες, σα βινύλιο ένα πράμα, τόσο "αναλογικός" ήχος
- θέλω αυτό το προενισχυτάκι με τις λάμπες, γιατί συμπληρώνει εξαιρετικά τον τελικό στο συνολικό ήχο, βγάζοντας αληθοφάνεια, σώματα, οδήγηση και πρατ και χωρίς γρέζι άμα λάχει
- θέλω ...
Κλπ κλπ κλπ
Η λογική του ενεργού είναι:
- θες χώρο με σωστούς χρόνους αντήχησης
- θες ηχεία στις σωστές αποστάσεις και κλίσεις, κατάλληλου μεγέθους για το χώρο σου και για την απόσταση ακρόασης που έχεις
- θες σαμπ αναλόγως όγκου του χώρου και απαιτήσεων σε στάθμες
- θες ενεργή ισοσταθμιση χώρου, πρωτίστως γιατί κανένας χώρος δε θα επιτρέψει στο ηχείο να παίξει όπως μπορεί, αλλά και δευτερευόντως για να βάλεις μια πινελιά από το προσωπικό σου γούστο ρε αδερφέ. Γι'αυτό σου βάλαμε ρυθμιστικά στην πλάτη του ηχείου. Άσχετε.
(Δεν είναι δουλειά σου να ασχοληθείς με τα ντακ, ούτε με τα ενισχυτικά στάδια, ούτε με τα σημεία και τις κλίσεις κρος, ούτε με τίποτα, αυτά τα έστησε σωστά ο μηχανικός μας που έφτιαξε το ηχείο που αγόρασες, σκάσε και άκου τη ρημάδα τη μουσική σου από σποτιφαϊ και μη μας πουλάς φουμαρα περί πρατ και γρεζιού, μάστορε της κακιάς ώρας)
:D:D:D:D
:p:p:p:p:p
:lol::lol::lol::lol::lol::lol::lol::lol:
Nick Arvanitakis
Audio Pro
Δεν έχει μείνει τίποτα όρθιο!
Lyravox Karl and Karlotta: Ενεργά high-end ηχεία
Η Γερμανική Lyravox είναι αρκετά γνωστή στους κύκλους του high-end με τα ολοκληρωμένα συστήματα που κατασκευάζει.
Αυτή τη φορά δημιούργησε δύο ενεργά ηχεία με τα ονόματα Karl και Karlotta. Πρόκειται για ενεργά δικτυακά ηχεία βασισμένα στους ενισχυτές module της Pascal, χρησιμοποιούν οκτώ από αυτούς συνολικής ισχύος 500W, και μεγάφωνα με κεραμικούς κώνους. Τα ηχεία αυτά είναι ικανά να παίζουν αρχεία ήχου υψηλής ανάλυσης τόσο τοπικά όσο και ασύρματα. Μπορεί να παίξει απευθείας μέσω των συστημάτων του δικτύου χώρας προέλευσης, από τις κινητές συσκευές ή υπηρεσίες streaming, ανάλυσης έως 192/24. Επίσης υπάρχει και Bluetooth aptX, αλλά και εφαρμογή app για τον έλεγχο τους.
Τα ενεργά ηλεκτρονικά εφαρμόζουν υψηλής ανάλυσης στο ψηφιακό πεδίο διαχωρισμό (κροσόβερ) συχνοτήτων, ισοστάθμισης και χρονισμό με τεχνολογία FIR.
Έτσι έχουμε ένα πλήρως ενεργό σύστημα με τις εξαιρετικές ιδιότητες.
Πρόκειται για ακριβές υλοποιήσεις που για την Ελληνική πραγματικότητα ανήκουν στη σφαίρα του φανταστικού.
Δημητρης 777
Spendorious
http://www.nakas.gr/prd/PRESONUS-ERIS-E-44-STUDIO-MONITOR-TEMAXIO
http://www.nakas.gr/prd/ESI-UNIK-05-PLUS-AITOENISXIOMENO-IXEIO-STUDIO-MONITOR-TEMAXIO
http://www.nakas.gr/prd/KRK-RP6-ROKIT-G3-STUDIO-MONITOR-MAIRO-TEMAXIO
http://www.nakas.gr/prd/M-AUDIO-M3-6-STUDIO-MONITOR-TEMAXIO
http://www.nakas.gr/prd/YAMAHA-HS-7-STUDIO-MONITOR-TEMAXIO
https://www.athensproaudio.gr/el/fostex-pm-04-n-pair.html
https://www.athensproaudio.gr/el/adam-a3x.html
https://www.athensproaudio.gr/el/focal-alpha-50-acousonics-mspad.html
https://www.athensproaudio.gr/el/genelec-8010a.html
https://www.athensproaudio.gr/el/mackie-cr5bt.html
Καλησπέρα, μιας και ειστε μαζεμενοι εδώ για να μην ανοιγω νέο θεμα και αφου μιλατε για ενεργα μπορειτε να μου προτείνετε 2-3 από αυτά για να περιορισω λιγο τις επιλογες ?
Καλως η' κακως το μπατζετ κυμαίνεται καπου εκει.... Θελω κοντα στις 5 ιντσες μοναδα για μικρο μέγεθος και ευκολη μετακινηση... Τα θελω για κουζινα, ταρατσα, υπνοδωματιο.. οποτε τετραγωνικα κλπ δεν εχουν νοημα... Ουσιαστικα θελω να μετακινω μονο τα ηχεια και το κινητο μου χωρις ενισχυτες κλπ... Σας ευχαριστω...
Δημητρης 777
Spendorious
Ενταξει παιδια μην σκοτιζεστε... ρωτησα αλλου και πηρα καποιες κατευθύνσεις.. Ευχαριστω....
Έλα βρε, συμβαίνουν αυτά.
Αυτά πάντως, αν και πολύ μου αρέσουν, είναι ασήκωτα.
Τα Presonus ζυγίζουν 5,4 κιλάκια μόνο.
Αν πρόκειται να μετακινούνται θα διάλεγα βινύλιο wrap και όχι μπογιά που θα γίνει pute.
Για τη χρήση που τα θέλεις εγώ θα κοιτούσα προς b&w zeppelin , τα διαφορά ασύρματα jbl, το Oppo...
Για την ευκολία μετακίνησης και συνδεσιμότητας
kchannel
